jenshb Posted September 19, 2021 Posted September 19, 2021 A quick question - will the Iconicair cowling and spinner fit the Tamiya fuselage for width and height?
Shogun Posted September 20, 2021 Author Posted September 20, 2021 Hey Jen, It fits, but around the external line.
Shogun Posted September 20, 2021 Author Posted September 20, 2021 If I had to, I would cut the top cowl in two down it's center, remove required amount, and glue it back together. BradG and ColinR 2
jenshb Posted September 21, 2021 Posted September 21, 2021 Thanks for that Shogun. That definitely won't fit the Tamiya kit then without a lot of chopping.
Shogun Posted September 22, 2021 Author Posted September 22, 2021 This fuselage looks goodGood to go... Thanks Guys! Fanes, MikeMaben, Landrotten Highlander and 6 others 9
Shogun Posted September 23, 2021 Author Posted September 23, 2021 This is a good look at the panel lines..... dmthamade, LSP_Kevin, MikeC and 1 other 4
Shogun Posted September 23, 2021 Author Posted September 23, 2021 I was(am), blown away by the intricate detail on these radiator screens. Can't wait to put them in. (they will fit) Thank you guys! LSP_Kevin, MikeC and Landrotten Highlander 3
Shogun Posted September 24, 2021 Author Posted September 24, 2021 After Cleaning up the inside a little, we can see what the side panel looks like.......The idea is to get what looks like TWO side panels, scvrobeson, Greg W, LSP_Kevin and 5 others 8
thierry laurent Posted September 24, 2021 Posted September 24, 2021 Hi. Good project. Mine is stalled because of a lack of info regarding the LG wells. The Greymatter nose does not mate the Revell fuselage as the cross sections are noticeably different. It was actually done for the Hasegawa kit. The Iconicair one is a far better option. I'm also hoping your Mastercasters resin pit is not underscaled as all the sets I saw were too small! I had to use plastic shims everywhere to use it. And finally tons of elements have still to be added. Indeed if there were not many differences between a Mk.IX and a Mk.24 cockpit, the FR47 was far more crowded. I should go back to that one! Troy Molitor 1
Shogun Posted September 25, 2021 Author Posted September 25, 2021 Hello there thierry! A little from this, something from that, and a bit from the other. I'm going to use the Mk.24 to fill in the gaps, like the gear bay detail. The wing of the Mk.24 and the Fr.47 look the same from the outside, except for the wing fold. My guess is they didn't change the internal structure all that much. Anyway, as the pilot in the movie The Battle Of Britain said, "Get that bowser out of here, We'll go with what we got! Uncarina 1
Shogun Posted September 25, 2021 Author Posted September 25, 2021 Landrotten Highlander, Alain Gadbois, scvrobeson and 3 others 6
Shogun Posted September 25, 2021 Author Posted September 25, 2021 some of the gap fillers Landrotten Highlander, LSP_Kevin and KiwiZac 3
Shogun Posted September 25, 2021 Author Posted September 25, 2021 LSP_Kevin, Alain Gadbois, BradG and 1 other 4
Shogun Posted September 25, 2021 Author Posted September 25, 2021 to look like one... Anthony in NZ, Alain Gadbois, Fanes and 4 others 7
