Chris_B-1B Posted November 4, 2020 Posted November 4, 2020 Is it ok to use Tamiya extra thin to attach clear parts? Am attaching forward windshields on 1/32 Corsair and 1/48 F-14 and I don't want to cause any fogging of the clear plastic. Thanks, Chris
Lothar Posted November 4, 2020 Posted November 4, 2020 I use nothing else for clear parts, never encountered the slightest problem. Just my two cents and experience. Lothar CANicoll, Whitey, Daywalker and 3 others 6
Daywalker Posted November 4, 2020 Posted November 4, 2020 51 minutes ago, Lothar said: I use nothing else for clear parts, never encountered the slightest problem. Just my two cents and experience. Lothar +1 CANicoll 1
Chris_B-1B Posted November 4, 2020 Author Posted November 4, 2020 Thank you guys. Just wanted to be sure before I committed glue to plastic.
nmayhew Posted November 4, 2020 Posted November 4, 2020 oh that's interesting - i would have bet money it would have fogged fwiw i use non-blooming CA for clear parts, but am tempted to give this a try! thank you
Helmsman Posted November 4, 2020 Posted November 4, 2020 It is ok to use with some precautions like keeping fingers away from joints. Lothar, MikeC and scvrobeson 3
mozart Posted November 4, 2020 Posted November 4, 2020 I always use Gator Glue or a similar PVA based substance. LSP_Kevin 1
LSP_Kevin Posted November 4, 2020 Posted November 4, 2020 2 hours ago, mozart said: I always use Gator Glue or a similar PVA based substance. Me too, though will also use CA or plastic cement as the need arises. On my Kitty Hawk P-39, I actually tried UV-curing gel for the rear section, but it didn't have the strength I was hoping for, and IIRC, resorted to TET in the end. Kev CANicoll 1
npb748r Posted November 5, 2020 Posted November 5, 2020 PVA for me as well however given this thread I will give extra thin a go - always assumed it will fog.
MikeC Posted November 5, 2020 Posted November 5, 2020 22 hours ago, Lothar said: I use nothing else for clear parts, never encountered the slightest problem. Just my two cents and experience. Lothar I use it for many clear parts such as the windscreens mentioned in the OP, or where structural strength in the join is desirable like for sideways opening canopies. But I tend to use PVA where there's a risk of glue runs etc. Formula 560 or Gator's Grip are my go-to brands. 19 hours ago, Helmsman said: It is ok to use with some precautions like keeping fingers away from joints. Sound advice. CANicoll, Rockie Yarwood and Lothar 3
Out2gtcha Posted November 5, 2020 Posted November 5, 2020 I don't use normal Tamiya extra thin on clear parts except when there is perfect fit and no pressure is needed. However, I have recently found Tamiya Extra thin "quick setting" which seems to evaporate super fast, and might be good for things like clear parts, where there are less chance of drips or the glue going somewhere it shouldn't. Rockie Yarwood and CANicoll 2
ChuckD Posted November 11, 2020 Posted November 11, 2020 Going against the grain here, but I had the canopy of a Trumpeter P-47D fog badly when attaching it with Tamiya Extra Thin (regular, not quick setting). The canopy was posed closed, so I surmised that fumes were trapped in the cockpit, causing fogging. In retrospect, perhaps there was a gap between the windscreen and canopy that allowed minute amounts of paint particles in while I airbrushed.
CANicoll Posted December 3, 2020 Posted December 3, 2020 I've recently started using the Tamiya Extra Thin and the benefit is that it 'melts' the clear part a bit so the canopy looks like it is tightly bound to the fuselage. I wick away much of the cement before touching the brush to the edge of the canopy. Chris MikeC 1
