Miloslav1956 Posted April 10, 2020 Posted April 10, 2020 (edited) 1/32 Hasegawa model Wolpack conversion set Aires cockpit, oil cooler, landing gear cover & pylons All colours MRP All painting mask by Dead Design Edited April 21, 2020 by Miloslav1956 Gazzas, Kagemusha, dutik and 15 others 18
Miloslav1956 Posted April 10, 2020 Author Posted April 10, 2020 Aplied mask for surface control. 109, Rocat, BiggTim and 13 others 16
Hartmann52 Posted April 10, 2020 Posted April 10, 2020 1 hour ago, Miloslav1956 said: Aplied mask for surface control. HGW hawe sets for 32th "Hien'?
Kagemusha Posted April 10, 2020 Posted April 10, 2020 Looking good, how did you find the fit of the conversion?
Miloslav1956 Posted April 11, 2020 Author Posted April 11, 2020 (edited) 14 hours ago, Hartmann52 said: HGW hawe sets for 32th "Hien'? This set is Dead Design. Coming soon! 14 hours ago, Kagemusha said: Looking good, how did you find the fit of the conversion? Wolfpack set fit very good. Any problem. I recommended also cockpit set from Wolfpack. IsIt's better and more accurate than Aires. Edited April 11, 2020 by Miloslav1956 Kagemusha, Troy Molitor, Hartmann52 and 1 other 1 3
Miloslav1956 Posted April 11, 2020 Author Posted April 11, 2020 Basic colours applied. Dpgsbody55, Troy Molitor, Kais and 15 others 18
Miloslav1956 Posted April 12, 2020 Author Posted April 12, 2020 Thanks all ! Today update - left side. tomv87, Trak-Tor, TAG and 18 others 21
dutik Posted April 12, 2020 Posted April 12, 2020 Looks very nice Did you use different shades of metallics? And whats your opinion about MRP metallic colors? Had you any problems with the masks applied over metallics? Easy to airbrush? Smooth surface? Regards - dutik BiggTim 1
Miloslav1956 Posted April 13, 2020 Author Posted April 13, 2020 I have been using MRP for several years. I've never had a problem. Masks are applied 5-10 minutes after spraying. I will never put the mask directly, but first I put it on my hand so that the glue is not too strong. New masks from Dead Design are very accurate, there are several sets. Canopy, inspection holes, surface control dutik and Kagemusha 1 1
