HotWaffle Posted March 7, 2020 Author Share Posted March 7, 2020 46 minutes ago, Subodai said: So I have to admit, I opened this thread and got the last post first and was like. Holy cow, his first LSP is made of wood?! Then went back to appreciate all the work so far and read up to here, that's some _very_ nice work on that prop wood effect! Had me fooled for a second there!! Haha thanks! 41 minutes ago, dodgem37 said: Do you have a source for your ribbed piping? The ribbed piping is actually the kit part. I figure you could wrap thin wire around a thicker piece of wire like a guitar string to get a similar effect: You could also buy roundwound guitar strings if you need a piece with a diameter greater than 1mm. Link to comment Share on other sites More sharing options...
HotWaffle Posted March 9, 2020 Author Share Posted March 9, 2020 My new airbrush arrived yesterday and I promptly put it to work marbling the wings: While letting the marbling on the wings dry, I masked the fuselage markings: I then marbled the rest of the model, waited a few hours then laid down the aluminum dope layer. There is some edge cleaning to do, and the port side white cross is a little uneven relative to the black cross. My plan is to carefully sand down the metallic layer to correct these issues. MikeMaben, TorbenD, JefH and 8 others 11 Link to comment Share on other sites More sharing options...
Gazzas Posted March 10, 2020 Share Posted March 10, 2020 Sweet! The WNW Pfalz is really a treat to build. Link to comment Share on other sites More sharing options...
HotWaffle Posted March 12, 2020 Author Share Posted March 12, 2020 In the end I didnt mask anything as I didnt want to lift the metallic paint. Instead, I slowly chipped away the paint with an xacto blade, followed by brushing on some paint to help hide the edge. It's not perfect, but its better. Once fixed, I sprayed the underside of the loewr wing and the topside of the top wing. While that dried I added a wrap to the tail skid. I then removed all the engine and cockppit masking and started painting the primed metal hatches on the surfaces. BiggTim, Landrotten Highlander, KiwiZac and 9 others 12 Link to comment Share on other sites More sharing options...
Out2gtcha Posted March 12, 2020 Share Posted March 12, 2020 Very cool! I like the look of the RLM hatches on the dope silver HotWaffle 1 Link to comment Share on other sites More sharing options...
Kagemusha Posted March 12, 2020 Share Posted March 12, 2020 Nice marbling! HotWaffle 1 Link to comment Share on other sites More sharing options...
HotWaffle Posted March 14, 2020 Author Share Posted March 14, 2020 The coronavirus has shut down all school here in Spain, so progress should speed up on the pfalz in the next few weeks. Today I started painting the empennage chevrons. First, I masked for the yellow sections: Quick and light marble base: Unmasked: Again, not perfect but I'm satisfied with the result. Next up will be masking the yellow and spraying the light green. John1, Ol' Scrapiron, MikeMaben and 8 others 11 Link to comment Share on other sites More sharing options...
MikeMaben Posted March 15, 2020 Share Posted March 15, 2020 Nice Link to comment Share on other sites More sharing options...
HotWaffle Posted March 15, 2020 Author Share Posted March 15, 2020 Yellow stripes masked: Green was then sprayed and the masks removed.: Again, the edges are a little rough and some cleaning-up will be necessary. Gazzas, Tnarg, LSP_Kevin and 5 others 8 Link to comment Share on other sites More sharing options...
Bobs Buckles Posted March 15, 2020 Share Posted March 15, 2020 Lovely von B HotWaffle and Out2gtcha 1 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted March 15, 2020 Share Posted March 15, 2020 Agreed, that looks terrific. HotWaffle 1 Link to comment Share on other sites More sharing options...
Gazzas Posted March 18, 2020 Share Posted March 18, 2020 Perfect! HotWaffle 1 Link to comment Share on other sites More sharing options...
dodgem37 Posted March 18, 2020 Share Posted March 18, 2020 Dazzlingly good! Sincerely, Mark HotWaffle 1 Link to comment Share on other sites More sharing options...
HotWaffle Posted March 28, 2020 Author Share Posted March 28, 2020 Decals are on and soaking under some mirco sol LSP_Kevin, Lothar, Tnarg and 4 others 7 Link to comment Share on other sites More sharing options...
HotWaffle Posted April 7, 2020 Author Share Posted April 7, 2020 Started putting the wash on the smaller bits. I've also come across a problem: the propellor I used (Heine) doesn't fit inside the prop hub. I'm not sure if I'm going to carve the hub until it fits or display it disassembled. Landrotten Highlander, Bobs Buckles, LSP_Kevin and 3 others 6 Link to comment Share on other sites More sharing options...
