HotWaffle Posted April 9, 2020 Author Share Posted April 9, 2020 (edited) I've begun shading the rib tapes. The underside tapes will be slightly darker and the upper side tapes slightly lighter. I started by masking the top wing undersides (sorry for the out-of-focusness): After a light coat of tamiya smoke: The effect is very light, as I like all of my shading to be very subtle. Onto the rest of the wings... Edited April 9, 2020 by HotWaffle LSP_Kevin, Landrotten Highlander, BiggTim and 1 other 4 Link to comment Share on other sites More sharing options...
HotWaffle Posted April 11, 2020 Author Share Posted April 11, 2020 And much masking was had by all... The decals lifted slightly under a test mask so I ended up using paper to cover the decals: The result: Onto the oils Gazzas, Lothar, BiggTim and 7 others 10 Link to comment Share on other sites More sharing options...
MikeMaben Posted April 12, 2020 Share Posted April 12, 2020 Link to comment Share on other sites More sharing options...
Gazzas Posted April 12, 2020 Share Posted April 12, 2020 Terrific!! Link to comment Share on other sites More sharing options...
HotWaffle Posted April 22, 2020 Author Share Posted April 22, 2020 I've finally got to my favorite part: Oil weathering! This is the first of many passes with the oils. I tend to add a little bit each day until I'm satisfied. KiwiZac, turbo, BiggTim and 8 others 11 Link to comment Share on other sites More sharing options...
Bobs Buckles Posted April 23, 2020 Share Posted April 23, 2020 Nice and subtle. Excellent work. vB HotWaffle 1 Link to comment Share on other sites More sharing options...
HotWaffle Posted April 29, 2020 Author Share Posted April 29, 2020 Mud splatters applied to the undersides Landrotten Highlander, BiggTim, scvrobeson and 5 others 8 Link to comment Share on other sites More sharing options...
RLWP Posted April 29, 2020 Share Posted April 29, 2020 On 3/7/2020 at 8:29 AM, dodgem37 said: Do you have a source for your ribbed piping? The 'ribbed piping' are the drive cables for the gun synchronisation system, running from the gearbox on the camshaft to the trigger motors on the bottom of the lMG/08s. This is the Zentralsteuerung system. This is the same system on a DR.I with an Oberursel: It makes positioning the guns in the airframe a whole lot easier than with some other gears! Richard Landrotten Highlander, HotWaffle, dodgem37 and 2 others 5 Link to comment Share on other sites More sharing options...
HotWaffle Posted May 4, 2020 Author Share Posted May 4, 2020 More oils added. I'll be adding a litte bit more of the starboard side before sealing it all in and starting final construction. BiggTim, Bil, LSP_Kevin and 3 others 6 Link to comment Share on other sites More sharing options...
HotWaffle Posted May 6, 2020 Author Share Posted May 6, 2020 Applied the last of the oil weathering, flare rack and tail control surfaces. LSP_Kevin, Lothar, MikeMaben and 6 others 9 Link to comment Share on other sites More sharing options...
HotWaffle Posted May 9, 2020 Author Share Posted May 9, 2020 Struts are on Ive started making the stand for propping up the back of the airplane. Eventually I'll be making a diorama for this model although it might not happen for a few months. Lothar, kkarlsen, scvrobeson and 2 others 5 Link to comment Share on other sites More sharing options...
HotWaffle Posted May 12, 2020 Author Share Posted May 12, 2020 Eyelets, turnbuckles and landing gear installed. Landrotten Highlander, scvrobeson, Lenny320 and 2 others 5 Link to comment Share on other sites More sharing options...
Bobs Buckles Posted November 9, 2020 Share Posted November 9, 2020 What became of this beauty, Mr Waffle? von B Link to comment Share on other sites More sharing options...
