williamj Posted January 13, 2020 Posted January 13, 2020 Have a couple of Has. Hellcats on the go and was wondering if anyone has a link or pics as to the easiest way to attach the Trumpeter wings to the better shaped Hasegawa fuselage?? Thanks guys,Bill. BiggTim and Out2gtcha 2
Out2gtcha Posted January 13, 2020 Posted January 13, 2020 2 minutes ago, williamj said: Have a couple of Has. Hellcats on the go and was wondering if anyone has a link or pics as to the easiest way to attach the Trumpeter wings to the better shaped Hasegawa fuselage?? Thanks guys,Bill. I have both kits in my stash too Bill, and this has always been my plan for a "Trumpegawa" F6F. Although I have to admit, I dont have any idea exactly how Id do it...............Id be curious for any known steps to do this myself. BiggTim, LSP_K2 and williamj 3
williamj Posted January 13, 2020 Author Posted January 13, 2020 Thanks Brian,,ya there's a couple of ways I can do it (lot of work) but not sure if I'm missing the easiest. Do know someone on LSP a long while back did this conversion,can't remember though.
Astro32 Posted January 13, 2020 Posted January 13, 2020 I don't remember if the Trumpy wings have the center lower fuselage attached to the wing center section like the Hase kit does, but in any case you'll need to retain the Hase fuselage center section, and attach the Trumpy wings with a carry-through spar, much like the real aircraft does. Hope this helps!
Kagemusha Posted January 13, 2020 Posted January 13, 2020 I remember someone at least starting such a project, have both kits to do likewise. Hopefully I can find the thread. williamj 1
Jack Posted January 13, 2020 Posted January 13, 2020 Guys, can't recall the "wing-issue" on attaching the trump wing to the Has-fuselage: was it a matter of over-riveting, or too less recessed lines on behalf of the Hasegawa wing, that brougt up the idea of joining these two together or what? HTH Jack
Kagemusha Posted January 13, 2020 Posted January 13, 2020 It was to save on engraving, also the wheel Wells being more detailed/accurate, from what I remember.
williamj Posted January 13, 2020 Author Posted January 13, 2020 23 minutes ago, Jack said: Guys, can't recall the "wing-issue" on attaching the trump wing to the Has-fuselage: was it a matter of over-riveting, or too less recessed lines on behalf of the Hasegawa wing, that brougt up the idea of joining these two together or what? HTH Jack Hey Jack...the Trumpeter fus.is too fat aft of the fire wall..you can't miss it. So some have been mating the Trumpeter wings which are good (especially the wheel wells) Even the engine is much better..but the rest you can keep. Out2gtcha 1
LSP_Ron Posted January 13, 2020 Posted January 13, 2020 There was a build thread here at one point with a member doing just that. I had a quick search and couldn't find it williamj 1
petrov27 Posted January 13, 2020 Posted January 13, 2020 (edited) Below was my attempt - the announcement of the Airfix 1/24 kinda took the wind outta my sails though Ha - disregard - I don't know what I was thinking - I did not use the Hasegawa fuselage - I was just trying to correct the Trumpeter kit But, that said, after narrowing the Trump fuselage I fit a "spreader bar" of heavy sprue-rod inside the fuselage at the wing-root to force it just wide enough so that the wings still fit without major putty work - that may be the way to go for fitting the Trumpeter wing to the Hase fuse.... Edited January 13, 2020 by petrov27 williamj 1
Kagemusha Posted January 13, 2020 Posted January 13, 2020 Found one on Britmodeller, RFI. I think this was also the one mentioned on here. williamj 1
D.B. Andrus Posted January 13, 2020 Posted January 13, 2020 I'd like to know, too. Cheers, D.B. williamj 1
williamj Posted January 14, 2020 Author Posted January 14, 2020 Thanks all appreciate the effort... D.B. Andrus 1
BiggTim Posted January 14, 2020 Posted January 14, 2020 Honestly, I just gave up and built the Hasegawa kit. Lot of re-scribing on the wings, but I still think it was less work than a wing swap. Good luck to you! williamj and MikeMaben 2
D Bellis Posted January 14, 2020 Posted January 14, 2020 DougN was the guy on LSP that did it a while back. The 'why' has to do with Hasegawa's wings looking like they're made of plywood sheets with irrigation ditches between them, and the Trumpeter fuselage looking like a clown's balloon toy sporting a 1/24 scale canopy. HTH? D rafju, Astro32, Kagemusha and 5 others 3 5
