Jeff T Posted October 23, 2020 Posted October 23, 2020 Great work Brian!......especially nice work on the engines and wheelbays. Cheer's, Jeff. Out2gtcha 1
Uncarina Posted October 23, 2020 Posted October 23, 2020 Dang Brian! Your build is so good I want to bust into my Hs.129! Cheerd, Tom Out2gtcha 1
Out2gtcha Posted October 24, 2020 Author Posted October 24, 2020 Thanks boys! Got a slow start to paint last night, and got the base insignia white on for the base of the home defense bands. I'll be putting the base white for the leading edge bands on after a later base of aluminum: The white really messed with the balance since the rest of it was all black. On to painting the Hinomaru, fuselage stripe and 53rd Sentai ans 93 on the tail. Then its on to an aluminum layer then the yellow leading edge stripes and camo. Cheers! Greg W, Kagemusha, Rocat and 10 others 13
Anthony in NZ Posted October 24, 2020 Posted October 24, 2020 Oh Brian...how did I miss this? I have been so focused on my Brit Phantom I missed this wonderful (actually stunning!) build...absolutely beautiful sir! You are a master at what you do....I am in awe Out2gtcha and Uncarina 1 1
nmayhew Posted October 24, 2020 Posted October 24, 2020 Brian great build as always! what’s the stand you are using? I need to get something that is fit for LSPs - my current one used on my Jug is a bit crap Out2gtcha 1
Out2gtcha Posted October 25, 2020 Author Posted October 25, 2020 Thanks gents! Nick, It's an Artograph 1530. Best thing I've ever purchased for modeling behind the Silouhette cutter. However I just learned that Artogtaph discontinued it for some reason. Back in a min with some pics........
Out2gtcha Posted October 25, 2020 Author Posted October 25, 2020 Ok, this weekend progress: Made some final size adjustments to the overall scheme and printed it out on the Silouhette (53rd Sentai tsil mark had to be shrunken later): Harder to see, but the cuts that get made are super fine: Hinomaru masks applied and the red shot: The Hinomaru turned out really well, but this is where I noticed how way too wide the fuselage home defence band was, so I shrunk it considerably per documentation: More......... Kagemusha, Starfighter, scvrobeson and 6 others 9
Out2gtcha Posted October 25, 2020 Author Posted October 25, 2020 53rd Sentai tail marking applied which was WAY more of a PITA than I had imagined, as the full right position of the rudder made it difficult to align: Ready and masked for some aluminum. This will also tell me where my remaining flubs are: That's all for now folks! I'll likely spray some aluminum here in a bit after the liquid mask sets up around the white boarder around thr 53rd Sentai markings. Cheers! Lothar, Uncarina, Starfighter and 6 others 9
Out2gtcha Posted October 25, 2020 Author Posted October 25, 2020 As one last follow up to this I do believe after looking at my chosen grey color, it was light enough, but almost too light and with not enough of a green tint. After some experimentation, I mixed up a combination of about 25/75 MRP Sky, and Mig-31 grey. This was not a super drastic change on its own, but once seen with earlier sprayed straight Mig-31 grey, it gives a much better IJA grey/green look I was looking for: Aluminum under layer up next, then leading edge yellow bands, then camo time. Cheers! Sepp, turbo, Lothar and 6 others 9
turbo Posted October 25, 2020 Posted October 25, 2020 Nice Brian! Yep, that IJA grey/green mix looks better. Out2gtcha 1
MikeMaben Posted October 26, 2020 Posted October 26, 2020 On 10/24/2020 at 12:31 PM, nmayhew said: Brian great build as always! what’s the stand you are using? I need to get something that is fit for LSPs - my current one used on my Jug is a bit crap Check here Nick : http://umm-usa.com/onlinestore/index.php?cPath=21_162 Out2gtcha 1
Out2gtcha Posted October 26, 2020 Author Posted October 26, 2020 Yes indeed, sorry Nick, I had it in my mind you were asking about the paint booth stand part, not the JH Models stand. Yes, Mike is correct, UMM is the place I got mine from. Not sure where the best place in the UK would be, but just make sure you get the 1/32-1/24th version. The 1/48-1/32nd version is just a bit too small for larger LSPs IMHO. MikeMaben 1
Landrotten Highlander Posted October 26, 2020 Posted October 26, 2020 I got mine directly from JHmodels, as at the time there were no UK stockists who had it in stock. http://www.jhmodels.eu/plastic-models/model-stands/no-3201-stand-new/ I got the 1/48 and 1/32 stands as depicted in this thread. They also have a version more geared towards biplanes (now in BOTH scales, not just 1/48). Very pleased with the stands AND the service. Highly recommended Out2gtcha 1
Out2gtcha Posted October 26, 2020 Author Posted October 26, 2020 15 minutes ago, Landrotten Highlander said: I got mine directly from JHmodels, as at the time there were no UK stockists who had it in stock. http://www.jhmodels.eu/plastic-models/model-stands/no-3201-stand-new/ I got the 1/48 and 1/32 stands as depicted in this thread. They also have a version more geared towards biplanes (now in BOTH scales, not just 1/48). Very pleased with the stands AND the service. Highly recommended Do you have the 1/48-1/32nd stand, or the 1/32-1/24th stand? I only ask, as I thought the prior was decent sized until I got the later. Its freaking massive. I love that it supports much larger models, but it takes up a damn lot of bloody bench space.
Landrotten Highlander Posted October 26, 2020 Posted October 26, 2020 1 hour ago, Out2gtcha said: Do you have the 1/48-1/32nd stand, or the 1/32-1/24th stand? I only ask, as I thought the prior was decent sized until I got the later. Its freaking massive. I love that it supports much larger models, but it takes up a damn lot of bloody bench space. I got both stands, as I do both 1/48 and 1/32 scales. Most of the smaller 1/32 planes - such as my Caudron - I could do on the smaller stand, but like you said, the 1/32-1/24 stand is massive and particularly useful for the jet-era, as these birds are typically much larger. For example, I coul do the Caudron on the smaller stand, but my current build (Fischer F9F-8T would be a bit too big for that stand - as would be the things like F-15 or A-10 in 1/32 as well as the larger birds in 1/48 such as Heinkel 111, PBY-5/a or Stratofortress the larger stand is much more useful. I also have the smaller biplane stand - not used it yet, but I will at some point in the future. Should work nicely on the stuff I got as I imagine that in the 1/32-1/24 range it will also be massive, but then again so will the airplanes be (i.e. much too large for the smaller stand). I reckon it pays to think about what you would need it most for, and go with that option - but that is purely my opinion. Out2gtcha 1
