alaninaustria Posted April 12, 2018 Share Posted April 12, 2018 (edited) I'm just thinking outloud here - any idea when we might see the F version hit the market?? Glen - any idea? Cheers Alan Edited April 12, 2018 by alaninaustria David66 1 Link to comment Share on other sites More sharing options...
dodgem37 Posted April 12, 2018 Share Posted April 12, 2018 'any idea when we might see the F version hit the market??' I'd groove on an F-20, too. Sincerely, Mark David66 1 Link to comment Share on other sites More sharing options...
Spaced Marine Posted April 12, 2018 Share Posted April 12, 2018 "44" was written off in late September 1984. Based on photographs taken between May 1983 and February 1984, BuAer 159882 (AF serial 74-1481) was still flying in early F-5E configuration. I couldn't find any photographs of 159882 showing the aircraft between February and September. Doesn't mean there aren't any... Maybe 159882 had the sharknose and later LERXs retrofitted, maybe not... Either way... Even if the sharknose and later LERXs had been retrofitted, you'd still have to trim the VOR/ILS antenna, fill the canopy ECS vent, sand down the RWR bumps and rear fuselage RWR fairing mounting plugs. IP and ejection seat can be used "as is". HTH Erik Maybe it's just laziness on my part, but I don't trust myself cutting the lerx parts. I probably will in the end to do a silver bird, I've just got to get my confidence up. Either that or hunt down a silver or ADC gray bird that takes little surgery to make. Link to comment Share on other sites More sharing options...
Rob Colvin Posted April 12, 2018 Share Posted April 12, 2018 measure twice.......cut once! David66, Luca, Spaced Marine and 1 other 4 Link to comment Share on other sites More sharing options...
Spaced Marine Posted April 12, 2018 Share Posted April 12, 2018 measure twice.......cut once! Truth. Link to comment Share on other sites More sharing options...
f5guy Posted April 12, 2018 Share Posted April 12, 2018 (edited) "44" was written off in late September 1984. Based on photographs taken between May 1983 and February 1984, BuAer 159882 (AF serial 74-1481) was still flying in early F-5E configuration. I couldn't find any photographs of 159882 showing the aircraft between February and September. Doesn't mean there aren't any... Maybe 159882 had the sharknose and later LERXs retrofitted, maybe not... Either way... Even if the sharknose and later LERXs had been retrofitted, you'd still have to trim the VOR/ILS antenna, fill the canopy ECS vent, sand down the RWR bumps and rear fuselage RWR fairing mounting plugs. IP and ejection seat can be used "as is". HTH Erik Gents, I found a shot in my slide collection that I took back in May of 1984, and NFWS #44 does in fact have the duckbill (sharknose) nose cone, and wing root LEXs. So for Spaced Marine, you could build it OOB with the KH kit, just be sure to use the duckbill nose cone, and remove the radar from the instrument panel, and RWR antenna's from the nose, and you're there. HTH, Fred K. Edited April 13, 2018 by f5guy David66 1 Link to comment Share on other sites More sharing options...
f5guy Posted April 12, 2018 Share Posted April 12, 2018 (edited) Maybe it's just laziness on my part, but I don't trust myself cutting the lerx parts. I probably will in the end to do a silver bird, I've just got to get my confidence up. Either that or hunt down a silver or ADC gray bird that takes little surgery to make. SM, If you did either the sliver or ADC gray 425th TFTS jets, you'd need to cut the LEXs off of the wings. If you don't want to monkey with it, then there are several awesome NFWS options on the Furball sheet that could be done OOB. HTH, Fred K. Edited April 12, 2018 by f5guy David66 1 Link to comment Share on other sites More sharing options...
Luca Posted April 12, 2018 Share Posted April 12, 2018 measure twice.......cut once! David66 and Harold 2 Link to comment Share on other sites More sharing options...
scjh Posted April 13, 2018 Share Posted April 13, 2018 I got the kit a few days ago, and noticed that the doors to the fold-out boarding steps and external canopy handle are also on the starboard side when they should only be on the port side. Hasegawa did this too. Also the oval panel of the AOA probe is below the canopy emergency release access instead of above. SC LSP_K2, dutik, Harold and 4 others 7 Link to comment Share on other sites More sharing options...
Seversky Posted April 13, 2018 Share Posted April 13, 2018 Such a set can not cost as much as the manufacturer wants. ((( Link to comment Share on other sites More sharing options...
f5guy Posted April 14, 2018 Share Posted April 14, 2018 I got the kit a few days ago, and noticed that the doors to the fold-out boarding steps and external canopy handle are also on the starboard side when they should only be on the port side. Hasegawa did this too. Also the oval panel of the AOA probe is below the canopy emergency release access instead of above. (I would post photos but haven't figured out how to yet.) You can see these in the photos already posted on this thread. Great catch SC! Thanks! Fred K. Link to comment Share on other sites More sharing options...
mgbgtv8steve Posted April 14, 2018 Share Posted April 14, 2018 Looking to acquire this kit as soon as it lands in the UK and to finish it as 73-0897 in the unique - one of a kind! - "Frog" scheme. So with that in mind, I've been looking at the FS numbers 33717 tan, 34052 green, 30111 'chestnut brown' and light grey 35622 and relating them to current Mr. Paint products. So far I've only been able to marry up 35622 as MRP225, the rest have eluded me. As this scheme was designed to mimic Soviet Frontal Aviation Floggers, any suggestions as to which MRP paints to use as my knowledge and references on Soviet aircraft is very limited. To me this kit looks as though it'll be a good basis for a decent F5E given a bit of work which, after all, is what scale modelling is meant to be about - isn't it?! Best regards, Steve S. Link to comment Share on other sites More sharing options...
Guest Airfixer Posted April 14, 2018 Share Posted April 14, 2018 First three kits arrived half an hour ago. Clear parts look fine on first inspection. Everything else as expected. David66, LSP_K2, SharkOwl and 2 others 5 Link to comment Share on other sites More sharing options...
Guest Airfixer Posted April 15, 2018 Share Posted April 15, 2018 (edited) [EDIT] 17-04-2018 Mystery solved. Found some pics. _______________________________________________________________________________ Do any of you fine gentlemen happen to have photographs showing the starboard side of 72-1402? Applicable timeframe: early 1985. Bad Google mojo today... I need to puzzle out the actual alignment of the stbd side Emergency Entrance Markings. The aligment varied quite wildly on similar 425th TFTS aircraft between 1982 and 1989. Thanks in advance! Erik Edited April 17, 2018 by Airfixer David66 1 Link to comment Share on other sites More sharing options...
Daniel Leduc Posted April 15, 2018 Share Posted April 15, 2018 Would someone be so kind as to measure the kit seat in width and height? Thanks in advance. Here you go Harold... In comparison with the CAM seat. And there is two seat in the kit, if you want one, I'll be happy to sent it over budy. Reggards, Dan. Harold, Tomcatfreak, LSP_K2 and 3 others 6 Link to comment Share on other sites More sharing options...
