Guest Airfixer Posted April 11, 2018 Share Posted April 11, 2018 (edited) Update on F-5E, 72-1405 (1975 timeframe) 1979 timeframe (different tail band colour, blue instead of yellow): Another shot of 72-1405 taken in 1982. Fresh from the paint shop, VOR/ILS antenna and Northrop Improved Seat retrofitted. Good news. Except for the required LERX surgery and the RWR bumps, you can build this a/c almost straight from the box. IMHO, one of the less appealing schemes, though... https://flic.kr/p/Zq6P5d Edited April 11, 2018 by Airfixer Luca, Out2gtcha, Seversky and 2 others 5 Link to comment Share on other sites More sharing options...
DonH Posted April 11, 2018 Share Posted April 11, 2018 I can see some Airscale instrument bezels and decals in my future... David66 1 Link to comment Share on other sites More sharing options...
SharkOwl Posted April 11, 2018 Author Share Posted April 11, 2018 True Details offered a 32nd scale F-5E seat set years ago. But I don't know whether it's still in production. Maybe you'd want to check ebay or Amazon to source one of these sets. For future resin aftermarket parts for this 1/32 Kitty Hawk F-5E Tiger II kit take a permanent oversight on KASL Hobby of Taiwan. In the past they, have produced quite interresting 1/32 parts for Tamiya and Academy F-16 ! And they have produced a lot of 1/48 parts for the AFV Club F-5E/F Tiger II. All the research is already done at KASL ! KASL Hobby facebook page here : https://www.facebook.com/KASLHOBBY/ SharkOwl David66 1 Link to comment Share on other sites More sharing options...
phantom Posted April 11, 2018 Share Posted April 11, 2018 When I was at the Phoenix airport, I saw two F-5's landing. Mike Link to comment Share on other sites More sharing options...
Guest Airfixer Posted April 11, 2018 Share Posted April 11, 2018 When I was at the Phoenix airport, I saw two F-5's landing. Mike Hence you're qualified to build the two of them. Tnarg 1 Link to comment Share on other sites More sharing options...
Spaced Marine Posted April 11, 2018 Share Posted April 11, 2018 It look like the lerx surgery is fairly simple, even for a hamfisted razor saw wielder like me. As much as I love the throwback f-5 scheme I talked about, the silver and yellow gunnery trainer is gorgeous. Harold and David66 2 Link to comment Share on other sites More sharing options...
Tony T Posted April 11, 2018 Share Posted April 11, 2018 Pleeeze Two Bobs, no generic sets. Just selected scaled-up examples with crew names etc., like the Grape scheme from the Alconbury Gomers sheet. Thanks Tony Link to comment Share on other sites More sharing options...
Guest Airfixer Posted April 11, 2018 Share Posted April 11, 2018 A clean, lean, mean machine. I'm seriously pondering over doing one... Sheer overall FS16473 F-5E eleganza: Dragon and David66 2 Link to comment Share on other sites More sharing options...
Spaced Marine Posted April 11, 2018 Share Posted April 11, 2018 That one looks killer too. Link to comment Share on other sites More sharing options...
LSP_K2 Posted April 11, 2018 Share Posted April 11, 2018 Really? I've never seen them on any other slide molded model. And what about that part is slide molded? It looks like a simple cavity mold part to me. That's tooled into the metal - for no reason. Zero quality control from what I can see. Referring back to this photo, it appears that these are two of the nose pieces, with the bottom of the nose facing us. On those bottom surfaces appear to be two deep depressions (one on each side of centerline, vents perhaps, but I really have no idea). These indentations would be next to impossible to create using conventional molding technology, so I assume these nose pieces are slide molded. I've seen similar slide mold marks on Airfix, Trumpeter, Hasegawa and Revell kits, to name but a few, and all are usually fairly easy to deal with, depending on the quality of the tooling, if not somewhat inconvenient. With any luck at all, I'll be eventually reviewing the kit (or at least that's what I'm counting on), and if so, will have a much better understanding of what's what, when I actually have the kit "in hand". David66 and Harold 2 Link to comment Share on other sites More sharing options...
Guest Airfixer Posted April 11, 2018 Share Posted April 11, 2018 (edited) One thing is for sure: Whatever it is, it shouldn't be there and should be removed, accordingly. However, I noticed these marks were almost always running along the crest lines of curved surfaces. Hence suspecting their presence was in any way moulding-related. The first kits I've stumbled across these marks were the 48th scale Trumpeter Su-15 and RA-5C. Edited April 11, 2018 by Airfixer David66 1 Link to comment Share on other sites More sharing options...
Guest Airfixer Posted April 11, 2018 Share Posted April 11, 2018 (edited) Another pic...looks like a channel. Also present on the lower fwd fuselage halves. And again, it's not supposed to be there. The position of the "channel" aft of the radome is indeed somewhat inconvenient... On Friday I'll know for sure when I see the actual plastic. Edited April 11, 2018 by Airfixer David66 1 Link to comment Share on other sites More sharing options...
Spaced Marine Posted April 11, 2018 Share Posted April 11, 2018 The ‘groove' is on mine too, and looks like a molding issue. Fortunately it's very fine and a few swipes of the sanding stick should make it go away. I hope at least.., David66, LSP_K2 and Harold 3 Link to comment Share on other sites More sharing options...
Spaced Marine Posted April 12, 2018 Share Posted April 12, 2018 (edited) How close is the kit to being able to build this one on the Furball top gun sheet? I see the notation for the big lerx and shark nose. Edited April 12, 2018 by Spaced Marine David66 1 Link to comment Share on other sites More sharing options...
Guest Airfixer Posted April 12, 2018 Share Posted April 12, 2018 "44" was written off in late September 1984. Based on photographs taken between May 1983 and February 1984, BuAer 159882 (AF serial 74-1481) was still flying in early F-5E configuration. I couldn't find any photographs of 159882 showing the aircraft between February and September. Doesn't mean there aren't any... Maybe 159882 had the sharknose and later LERXs retrofitted, maybe not... Either way... Even if the sharknose and later LERXs had been retrofitted, you'd still have to trim the VOR/ILS antenna, fill the canopy ECS vent, sand down the RWR bumps and rear fuselage RWR fairing mounting plugs. IP and ejection seat can be used "as is". HTH Erik Seversky, Spaced Marine and David66 3 Link to comment Share on other sites More sharing options...
