Derek B Posted March 13, 2023 Author Posted March 13, 2023 15 hours ago, geedubelyer said: That's a feature I can't ever remember seeing modelled before. Fabulous attention to detail. This is an area I know well, as I used to pack the Lightning brake parachutes in the RAF at Binbrook during the late 70's, and more lately, also for the two Lightning aircraft at Bruntingthorpe airfield which belong to the EE Lightning Preservation Group (LPG). Another job I did occasionally at the LPG is also install them (as can be seen in the page images). Derek KiwiZac, ColinR, Anthony in NZ and 8 others 11
Guest Posted March 13, 2023 Posted March 13, 2023 1:1 scale models - isn't that cheating? Fascinating behind the scene pics = thanks for posting them Landrotten Highlander and Derek B 2
Victor K2 Posted March 14, 2023 Posted March 14, 2023 Good to see you haven't lost your lock wiring skills Derek. Amazing that you can get locking wire pliers that small Anthony in NZ and Derek B 2
Anthony in NZ Posted April 1, 2023 Posted April 1, 2023 As you know I have been following along on FB, but after seeing it on my big PC screen, I am even more impressed! Absolutely stunning, you sir are a master and I am blown away by what you are doing! Wow
Derek B Posted April 1, 2023 Author Posted April 1, 2023 4 hours ago, Anthony in NZ said: As you know I have been following along on FB, but after seeing it on my big PC screen, I am even more impressed! Absolutely stunning, you sir are a master and I am blown away by what you are doing! Wow Hi Anthony, High praise (and accolades) indeed from someone like you! - thank you. Like you, I try to push the limits of (in my case, meagre) modelling skills, but there are many other modellers on this site (including yourself) who far exceed my abilities! I have not posted any updates of late, but I have not been idle. I am doing battle with detailing the ventral tank before I can move on to complete the detail work on the remaining areas of the fuselage, so hopefully my next update will show some recognisable progress (as you know, riveting and making new panels is never ending and very much 'one step forward, and at least two back!). Cheers Derek Anthony in NZ 1
Derek B Posted April 3, 2023 Author Posted April 3, 2023 Work continues on the ventral tank. And it's on! This is what Trumpeter think the arrester should look like! Obviously, I will need to improve on this. Derek Tony T, LSP_Kevin, Landrotten Highlander and 12 others 15
jeroen_R90S Posted April 5, 2023 Posted April 5, 2023 What a difference, and top notch work! Derek B and ColinR 1 1
Derek B Posted April 5, 2023 Author Posted April 5, 2023 Still WIP, but you get the general idea of the ongoing arrester hook improvements (even just adding the spring blade to the standard kit parts alone would massively improve the appearance). The standard kit hook is on the right, and my modified version on the left. My scratch built blade is made from 0.8 mm ABS plastic sheet sanded down to 0.27 mm thickness in order to achieve close to scale thickness. Derek Cheetah11, LSP_Kevin, Daniel Leduc and 11 others 14
Derek B Posted April 8, 2023 Author Posted April 8, 2023 I think that it now looks something like an arrester hook. The rear cable duct fairings have also been streamlined - they actually differ in shape compared to the front of the cable ducts fairings. Derek scvrobeson, Daniel Leduc, Victor K2 and 7 others 10
mozart Posted April 9, 2023 Posted April 9, 2023 Superb detailed work as ever Derek. That Trumpeter arrestor hook is shockingly bad to the point of being laughable! Derek B 1
Derek B Posted April 9, 2023 Author Posted April 9, 2023 One very simple but effective correction/modification is to reshape the tailplane fuselage fairing by sanding a flat onto the forward part and cutting the actuation slot into it (the tailplanes themselves will require adjustment at the roots, but then again, they would need to be in order to get a good fit on the unmodified kit anyway!). Derek scvrobeson, LSP_Kevin, Tony T and 8 others 11
Derek B Posted April 9, 2023 Author Posted April 9, 2023 (edited) A better 'before and after' shot. As related before, Tamiya failed to mould the left rear fuselage position light (only the right one - see above image). I decided to remedy this by making a copy of the right one, which I wil fix onto the left side. To do this, I am using a new (for me) product called Blue Stuff thermoplastic to use as a mould for the new light. This stuff goes soft in three minutes after immersion in hot water and can then be used as an imprint mould. I did this for the right light (and for a static vent below the right cockpit, as I had damaged the opposite left one and needed a replacement part), after which I mixed some Milliput and forced it into the newly created Blue Stuff moulds - we'll see how they turn out! Derek Edited April 10, 2023 by Derek B mozart, scvrobeson, LSP_Kevin and 6 others 9
