Youngtiger1 Posted November 24, 2014 Share Posted November 24, 2014 Looking awesome Brian. The tint on the FLIR is looking great. It will make a huge difference in the end. Link to comment Share on other sites More sharing options...
geedubelyer Posted November 24, 2014 Share Posted November 24, 2014 As an alternative for the irridescent lenses it might be worth seeking out some wrapping foil. Many places now stock thin plastic sheet in different irridescent hues which is ideal for modern lenses. HTH Uncarina 1 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted November 24, 2014 Share Posted November 24, 2014 Brian Sweet update and all those Injector Pin Marks ... what a job removing them. Great idea of adding the weight to the FLIR. Keep 'em coming Peter Link to comment Share on other sites More sharing options...
Out2gtcha Posted November 24, 2014 Author Share Posted November 24, 2014 Thanks guys! As to the iridescent paint, it is a lacquer line made by Pactra, that is designed for lexan R/C Race car bodies, and to go on the inside, so it shows through the clear lexan, or in this case the clear IM plastic. I have experimented with the shimmery iridescent wrapping foil and on the right surface you are 100% right it works very well. However it was way too bulky for the super small detail work in this case. I think the disco ball on top may also be a bit small to get the foil to stick cleanly and show flatly inside of the ball/ upper light fixture. My plan for the disco ball is Im going to be to make a mix of Tamiya clear yellow, and clear red, and spray or brush it also on the inside of the upper light fixture, followed then by a coat of Alclad chrome behind that, to punch up the sparkly-ness of the light. Im thinking it wont really need to be color changing like the Pactra paint, (changes from purple to blue in different lighting) but the mix of clear orange with chrome behind it, in the inside it should be enough to make it more interesting looking. Pactra makes a whole range of crazy, outlandish colors (usually lacquer) that are quite bomb-proof, and are in shades you normally never see. Uncarina 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted November 24, 2014 Author Share Posted November 24, 2014 The "Window Tint" color is also something that I have heard is very similar to Tamiya smoke, and would be very interested to try it............ Link to comment Share on other sites More sharing options...
DoogsATX Posted November 24, 2014 Share Posted November 24, 2014 Looking good! I've got some super-thin iridescent film that I've been intending to use for HUD glass that I think could be excellent here - just need to figure out a way to glue and trim it. Ideally I'd love to figure out what AFV Club is using to do their line of anti-reflective canopies - it looks rather convincing and would do great for sensor glass. Out2gtcha 1 Link to comment Share on other sites More sharing options...
mark31 Posted November 24, 2014 Share Posted November 24, 2014 Nice work Brian. Can u explain what EZ line is for the cable bundels? I dondt find it Keep up the great work. Mark Link to comment Share on other sites More sharing options...
scvrobeson Posted November 24, 2014 Share Posted November 24, 2014 I really like your work on this so far Brian. It looks like the kit is a very solid base for some fun detailing work. I look forward to seeing the rest of what you come up with Matt Link to comment Share on other sites More sharing options...
Vandy 1 VX 4 Posted November 24, 2014 Share Posted November 24, 2014 (edited) Nice work Brian. Can u explain what EZ line is for the cable bundels? I dondt find it Keep up the great work. Mark Here Mark is some help on how it is used for aircraft http://www.wingnutwings.com/ww/product?productid=3046 http://www.berkshirejunction.com/ezline.html Edited November 24, 2014 by Vandy 1 VX 4 mark31 1 Link to comment Share on other sites More sharing options...
mark31 Posted November 24, 2014 Share Posted November 24, 2014 (edited) Thanks for the info. Mark After raeding back the topic I found it also I whas a bit to fast. Mark Edited November 25, 2014 by mark31 Link to comment Share on other sites More sharing options...
Kagemusha Posted November 25, 2014 Share Posted November 25, 2014 For the iridescent effect there's also http://www.ebay.com/itm/HUD-FILM-1-1-48-1-72-1-32-1-35-heads-up-display-iridescent-film-Aircraft-/151487100338?pt=Model_Kit_US&hash=item234555b5b2 Link to comment Share on other sites More sharing options...
Porkbits Posted November 25, 2014 Share Posted November 25, 2014 A fellow on Another Modeling Forum just posted a pic of his build (for MAI Magazine): LINKY Man, I cannot wait to get my hands on this thing. Link to comment Share on other sites More sharing options...
Out2gtcha Posted November 25, 2014 Author Share Posted November 25, 2014 Thanks guys! A fellow on Another Modeling Forum just posted a pic of his build (for MAI Magazine): LINKY Man, I cannot wait to get my hands on this thing. Yep, that is our own Tigger Wilkes! John said he was working on his Bronco, and as usual it turned out fantastic! As lovely as it is, as I suspected it and Im thinking many others built will be in the same desert scheme, which is why I chose VMO-4 with the 3 color wrap around camo. I did try several films for the iridescent qualities, but the two lenses in question on the front of the FLIR/laser ball are so small, its SUPER tough to get them to stick flush on the inside...........and the outside was out of the question for me, as it was much more evident it was a film on the outside, and no longer had the clear "see through" quality it has when on the inside, which is why in the case of these super tiny lenses, I chose to go with iridescent paint and not film. I spent last night getting the MM36622 camouflage grey down in the wheel wells, as well as masking off and shooting the inner parts of the fuse that show on the front wheel well. I found another issue (at least to me) for the VMO-4 scheme that I found...............The OOB KH instructions call out for MM36622 on the gear as well: However, when looking at almost all of the pics of OV-10s in the wrap around VMO-4 scheme have white on the gear as apposed to the camo grey: This isnt a huge deal, and there very well may be OV-10s out there with the grey on the gear, but for mixing the colors up a bit, and for the sake of accuracy in numbers for the amount of pics of seen with white, Im going with white for the gear on mine. More pics soon! Cheers Vandy 1 VX 4, Sharkmouth and allthumbs 3 Link to comment Share on other sites More sharing options...
shark64 Posted November 25, 2014 Share Posted November 25, 2014 nice work. I love the camo version in the above photo. I hope Eduard will have a large photo etched available soon for this plane. so much super detailing can be done with this one. Oliver Link to comment Share on other sites More sharing options...
Out2gtcha Posted November 25, 2014 Author Share Posted November 25, 2014 nice work. I love the camo version in the above photo. I hope Eduard will have a large photo etched available soon for this plane. so much super detailing can be done with this one. Oliver Thanks Oliver! Since every single one of the new KH OV-10s that Ive seen built so far has the desert scheme, I have opted for the above VMO-4 wrap around camo scheme for my build. I really like it too, and it seems very different when looking at the desert schemes. I do like the DS scheme, but I love the different, and think the Marine 3 color wrap around camo scheme is the doggies danglies!! Link to comment Share on other sites More sharing options...
