LSP_Kevin Posted May 5 Share Posted May 5 I've been thinking a lot about the impact that Airfix's box art had on me as a nascent modeller in my youth, and even continues to have today - not just through nostalgia, which is real enough, but also because Roy's artwork still holds up today, and still evokes all the same feelings that it did all those years ago. And with the hobby being such an important part of my life for more than 50 years now, to the extent that even when I had long stretches away from the hobby, I still considered myself a modeller, Roy's passing feels rather more significant on a personal level than it otherwise might, even though he was, for all intents and purposes, a complete stranger. To that end, I've decided to do a tribute build, featuring the only Airfix kit I have that features Roy's box art: the venerable Handley Page H.P 42 Heracles in 1/144 scale. I haven't started any work on the kit yet, but hope to shortly. I'd also like to make this a relatively quick build, so hopefully I won't get too bogged down trying to fix or improve the kit. Stay tuned! Kev Ryan, themongoose, Mal_Belford and 10 others 13 Link to comment Share on other sites More sharing options...
Phantom2 Posted May 5 Share Posted May 5 You are in for a treat! Old as this kit are (1964), It´s a beauty, lacking some in detail, but goes together really well. Stefan LSP_Kevin 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted May 5 Author Share Posted May 5 21 minutes ago, Phantom2 said: You are in for a treat! Old as this kit are (1964), It´s a beauty, lacking some in detail, but goes together really well. Stefan I'd love a kit of this subject in 1/72 scale! Kev Link to comment Share on other sites More sharing options...
MikeC Posted May 5 Share Posted May 5 10 hours ago, LSP_Kevin said: I'd love a kit of this subject in 1/72 scale! Kev If you can find one and don't mind a vacform https://www.scalemates.com/kits/contrail-handley-page-hp-42-45--145617 LSP_Kevin 1 Link to comment Share on other sites More sharing options...
LSP_K2 Posted May 5 Share Posted May 5 Great idea, Kev, very similar to what I'm doing with the tiny Hawk Bf 109, and for the same nostalgia reasons. LSP_Kevin 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted May 7 Author Share Posted May 7 Making some progress with this one, though sadly at the expense of my other builds! Nevertheless, progress is progress. For some reason, my kit came with three fuselage halves: I've been using the spare to test some solutions for the window openings. My tests with clear UV-curing glue gel weren't really successful, for three main reasons: firstly, the gel itself is ever-so-slightly cloudy when applied in greater than wafer-thin layers; secondly, the tape I used on the outside to act as a dam caused a slight dulling effect on the surface, further reducing the clarity; and thirdly, due to the raised rims around the window openings, I couldn't stop tiny amounts of gel from leaking out. Perhaps with a more suitable clear gel I'd have better results, but after conferring with a fellow modeller who has recently built this kit, I decided to use the kit windows, which fit pretty well. Being rather thick, however, means that they have sink marks on both sides, so I started by filing them away with a coarse sanding stick: They're not 100% gone, but much improved. Next steps will involve restoring the clarity. On the assembly front, the wings and tailplanes went together without a single problem: In fact, the overall fit is surprisingly good for a kit that's a year older than I am: Conferring again with my modeller friend, he convinced me to reduce the prominent ribbing on the wings, as it's all-but invisible on the real thing, and could probably be removed altogether: I'll see how that looks under some primer, before deciding if I should take it further. More soon! Kev LSP_K2, Fanes, chrish and 9 others 12 Link to comment Share on other sites More sharing options...
Mark_C Posted May 7 Share Posted May 7 Kevin, This may be a workable alternative: "Model Master Clear Parts Cement (Glue) & Window Maker" https://www.modelroundup.com/product-p/test-8876c.htm I haven't used it, but if the windows are small it may work. TankBuster, LSP_K2 and LSP_Kevin 3 Link to comment Share on other sites More sharing options...
LSP_K2 Posted May 7 Share Posted May 7 I like Elmer's for small windows, despite the frailty, but those windows may be too large for that, hard to tell the size in the photos. LSP_Kevin 1 Link to comment Share on other sites More sharing options...
Archimedes Posted May 7 Share Posted May 7 Bravo Kev, I admire the HP-42 greatly and your reasons for doing this build even more. Kind regards, Paul LSP_K2 and LSP_Kevin 2 Link to comment Share on other sites More sharing options...
Mal_Belford Posted May 7 Share Posted May 7 oh my dear.....what are you in for Kev. damn small, 144, are you nuts? i felt 1:72 is small lol but hey, i love crazinez, so keep em comin as i will be folowing this different model commin alive. /Mal LSP_Kevin 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted May 7 Author Share Posted May 7 Thanks, fellas. I've got some Microscale Kristal Kleer, but generally don't like using it. I did see another modeller use something similar on his build, but I'm not a fan of the stuff personally. I might use it on the smaller door windows, however. Kev LSP_K2 1 Link to comment Share on other sites More sharing options...
LSP_Ron Posted May 7 Share Posted May 7 Why not treat it like your 1/144 airliner builds and paint them out in black or dark grey? I've pulled out my Revell 747 Ed Force One kit. I think I am going to start that tonight, you've inspired me. LSP_Kevin, LSP_K2 and chrish 3 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted May 8 Author Share Posted May 8 10 hours ago, LSP_Ron said: I've pulled out my Revell 747 Ed Force One kit. I think I am going to start that tonight, you've inspired me. I nearly pulled that one out myself in order to continue the series, but got sidetracked with the 777. Kev LSP_K2 1 Link to comment Share on other sites More sharing options...
Tnarg Posted May 9 Share Posted May 9 One Man Model sells a 1/72 and 1/48 version of the HP 42 on ebay. They are 3D printed (filament) and much better than the vac form, at least in the wing attachment to the fuselage, but there are a lot of printing lines to smooth out/sand. I have the 1/72 scale version, but the engine exhaust pipes to the collector in front are not as nice as I'd like. Maybe I need to figure out how to 3D print them. I am considering designing a photo etch set to add some of the details, but it is still in the paper drawing stage. Arctic Decals sells a decal set for the 1/72 kit and it is truly amazing. Not just the wing codes, Inperial Airways logos and aircraft names, but you get wood detail for the cabin walls, plus two versions of the "Jacobean" fabric seat coverings. Something for the truly obsessed, but it looks beautiful. I had this Airfix kit before I decided to work on the larger one, and remember there was an aftermarket set of decals for it as well in 1/144. Good luck with this one, it is just an amazing plane. So "ugly", it is beautiful, almost Steampunk in appearance. Tnarg LSP_K2, Archimedes and LSP_Kevin 3 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted May 10 Author Share Posted May 10 4 hours ago, Tnarg said: One Man Model sells a 1/72 and 1/48 version of the HP 42 on ebay. They are 3D printed (filament) and much better than the vac form, at least in the wing attachment to the fuselage, but there are a lot of printing lines to smooth out/sand. I have the 1/72 scale version, but the engine exhaust pipes to the collector in front are not as nice as I'd like. Maybe I need to figure out how to 3D print them. I am considering designing a photo etch set to add some of the details, but it is still in the paper drawing stage. Arctic Decals sells a decal set for the 1/72 kit and it is truly amazing. Not just the wing codes, Inperial Airways logos and aircraft names, but you get wood detail for the cabin walls, plus two versions of the "Jacobean" fabric seat coverings. Something for the truly obsessed, but it looks beautiful. I had this Airfix kit before I decided to work on the larger one, and remember there was an aftermarket set of decals for it as well in 1/144. Good luck with this one, it is just an amazing plane. So "ugly", it is beautiful, almost Steampunk in appearance. Tnarg I'd forgotten about the One Man Model kit, which I might investigate. I have his Electra kit, so I certainly know what to expect! In fact, I know he has improved his printing quality since then, and now includes many resin-printed parts in his kits. For this Airfix kit, about the only thing I want for is some canopy masks, since I can't even see any frames on the kit part to apply my own. I know there are some about, but none available to me locally right now. Kev Archimedes 1 Link to comment Share on other sites More sharing options...
