dodgem37
9,911 -
Days Won
21
Posts posted by dodgem37
Nice problem-solving.
Sincerely,
Mark
Good show. Nice new products.
Sincerely,
Mark
Radu, it's not that I'm unaware of the use of 02, I also have a copy of the document of which you linked. In addition, I have seen color photographs of aircraft with 02 mottling. It is that I had not considered that this aircraft would have 02. It was an eye opening moment for me.
Thank you.
Sincerely,
Mark
'not a hard hat or pair of safety glasses in sight!'
Nor hearing protection, OR a spot of grease.
Sincerely,
Mark
I had not realized the aircraft had 02 mottling as well.
Sincerely,
Mark
- coogrfan, Stefano and Paul in Napier
- 2
- 1
Go Antonio, Go! Great work.
Sincerely,
Mark
Love this!
Sincerely,
Mark
Small update. A bit of a walk-around.
New roof paneling. Front view.
Side view.
Rear view.
Thank you for looking in.
Sincerely,
Mark
- Troy Molitor, Isar 30/07, rafju and 10 others
- 13
Been doing a little work on the wings and cowling.
No lightening holes in the wheel wells. Filled and sanded smooth.
Here too.
Replacement part for the oil radiator.
Roughly blanked off.
Not worried about accuracy.
Shimming and aligning.
First round of filling, filing, and sanding. Lots of shimming.
Other side. Still need to scribe panel lines.
Made it so it's removable.
Other side.
Weep holes. Still need to scribe panel line.
Nothing good happens when a model falls off the work bench.
Sincerely,
Mark
You got that right. Horizontal stabilizers too.
Sincerely,
Mark
Thank you, my Brother.
I don't get a lot done jumping back and forth between three builds, but I try to do a little something on everything each week. Here I worked on aligning the cowling with the fuselage.
I bonded two structures before shimming so the front end wouldn't split . I started with .010 before moving up incrementally until I reached .040 as the shim size.
Good on this side.
Same here. Erred so I had to add a shim to try and level things out.
Close enough for Government Work.
Thanks for looking in.
Sincerely,
Mark
Wonderful. Empennage is wood. Its' control surfaces are primer. Just sayin'.
Sincerely,
Mark
Good show, John.
Sincerely,
Mark
If the suspension is lacquer, it’ll be ok. Lacquer has a low freezing point. Water, not so much. Agent (gloss/matte) will thicken in the cold but thin out at room temperature. Medium, acrylic color particles, will be ok. Otherwise let me know and I’ll PayPal you the loss.
Sincerely,
Mark
God Almighty.
Sincerely,
Mark
Missed this entirely until now. Great work! Fantastic presentation.
Sincerely,
Mark
1/18 Curtiss P40C - Finished :)
in Works in Progress
Good show. Exposed fastener heads are a nice detail.
Nice grip sculpture. Fantastic finish, too.
Sincerely,
Mark
