ericg Posted August 22, 2017 Share Posted August 22, 2017 (edited) Now that the Lukgraph Corsair was finished I have started another kit that was sent to me to be be built for the site. There is always talk of comparisons of various kits to standards such as `Tamiya quality' or `just like a Wingnut Wings kit'. I would like to now introduce another standard by which kits are compared or measured up to and it is this one. I have built many different types of kits by different manufacturers and will give almost any kit a go in 1/32 scale. This one is by far the best quality kit I have worked on so far and Richard of Aviattic should be congratulated for defining a new standard. Practically everything is included in the kit to build it, apart from the rigging material. I wont go into a huge amount of detail with the build, as the build log included in the Aviattic website here: http://www.aviattic.co.uk/uploads/4/5/1/3/45139653/balilla_build_log.pdf has as much detail as is required to replace the instructions in the kit. The box explodes with many ziplock bags containing all of the parts with a small business card with walk around type photos of the assembly. A couple of large high quality decals sheets, a fret of photo etch and much more awaits. First up was removing the bottom of the fuselage to start the more accurate depiction of the fuel tank. I then cleaned up the two engine bay bulkheads. These are nicely labelled with a part number on the casting block and had very minimal flash. More importantly, they are all dead straight and have no warpage. They both slotted straight into the fuselage. Edited August 29, 2018 by ericg Kendzior, Rocat, Lenny320 and 12 others 15 Link to comment Share on other sites More sharing options...
Kendzior Posted August 22, 2017 Share Posted August 22, 2017 What a magnificent kit! Keep my fingers crossed, as it seems to me (after looking at a build log) that this is not a shake'n'bake job. Best regards Hubert bstachel 1 Link to comment Share on other sites More sharing options...
seiran01 Posted August 22, 2017 Share Posted August 22, 2017 Ohhhhhhh yes! Hope to start my own one soon also bstachel 1 Link to comment Share on other sites More sharing options...
bstachel Posted August 22, 2017 Share Posted August 22, 2017 You have my undivided attention, Eric! thank you for the kind words... Best wishes, Richard Link to comment Share on other sites More sharing options...
ZachP319 Posted August 22, 2017 Share Posted August 22, 2017 Nice. Will be watching this. Zach Link to comment Share on other sites More sharing options...
monthebiff Posted August 22, 2017 Share Posted August 22, 2017 Very cool indeed........I really want one of these awesome kits. Regards. Andy Link to comment Share on other sites More sharing options...
Simmo.b Posted August 23, 2017 Share Posted August 23, 2017 Looking forward to this one mate Link to comment Share on other sites More sharing options...
Fooesboy Posted August 27, 2017 Share Posted August 27, 2017 Hi Eric, This kit looks amazing and I have been tempted to pick it up purely for that fact alone, unfortunately the aircraft just does nothing for me... I will however be following along with great interest as you turn out another masterpiece. Cheers, Link to comment Share on other sites More sharing options...
DonH Posted August 27, 2017 Share Posted August 27, 2017 Link to comment Share on other sites More sharing options...
DonH Posted August 27, 2017 Share Posted August 27, 2017 Just read the build log. Are you kidding me? I am speechless at the skill level required to do what you are doing. Great job! Link to comment Share on other sites More sharing options...
ericg Posted August 28, 2017 Author Share Posted August 28, 2017 Just read the build log. Are you kidding me? I am speechless at the skill level required to do what you are doing. Great job! Yes, it is quite apparent that this kit requires a step up in terms of skill level required above and beyond most kits I have worked on to date. A pleasing aspect of the kit has been the presentation of the photo etched parts. These have been taped along one edge to some card, which allows the modeler to slip some thick acrylic sheet under the fret and then cut each part off as needed. In this case, I have been using a micro chisel to cut each part free. Some of the cockpit parts including the rudder bar and control column. I am really impressed with how many fine parts have been included on one casting block. Careful planning is required to ensure that each part comes off cleanly without damaging the one next to it. I have to say that some of the photo etch assemblies look quite daunting. Made up of multiple small parts, they need to be carefully studied to ensure that they are assembled correctly. This is the control bar detail, which is optional, as it will not be visible once installed. I thought I would tackle all parts of the kit including the optional assemblies, just to say that I have done them! The parts are sandwiched together and then pinned through two holes with some 0.3mm brass rod (self provided). The build log also calls for the round tube to be scratch built from either brass or plastic. The cockpit floor and details built up. The foot straps on the rudder bar were replaced with tamiya tape, which I made slightly wider than the kit photo etch parts.I did try and use the kit straps, but when I annealed them, they melted! The control column features some microscopic gun triggers which will require care to not lose. Follownig the build log, I made the column articulated by carefully drilling and pinning it. Also noticeable is the higher of the two control rods, which I replaced with brass as recommended in the build log. The next assembly is the aileron transfer bar, which is lots of photo etch parts and brass pins (17 including the resin part that it attaches to). this part is also listed as optional, as it cant be seen. I felt that I would tackle it just for the challenge. Provided that you dry fit it and work out how the part actually works, it isn't that hard!. I have used superglue to assemble all assemblies so far. The parts starting to take shape, dry fitted at this stage. Alot of thought is already going into how I am going to paint all of it! The instrument panel. Crisp and clean castings combined with photo etch parts. I am looking forward to bringing this assembly to life. Kendzior, sandokan, Kagemusha and 9 others 12 Link to comment Share on other sites More sharing options...
ericg Posted August 28, 2017 Author Share Posted August 28, 2017 Hi Eric, This kit looks amazing and I have been tempted to pick it up purely for that fact alone, unfortunately the aircraft just does nothing for me... I will however be following along with great interest as you turn out another masterpiece. Cheers, I reckon this kit will be a 'bucket list' kit, that is, one that modellers should aspire to build given the amount of effort that has gone into producing it by Richard for us modellers and the very nature that sets it apart from other kits. I wasn't initially drawn to the aircraft either, but there are many features that I am becoming fond of and can't wait to do such as the bare metal cowls contrasting with the wooden fuselage and the topside wings 'digital cam' with the painted motif on the sides. Eric bstachel, Fooesboy, sandokan and 1 other 4 Link to comment Share on other sites More sharing options...
LSP_Ray Posted August 30, 2017 Share Posted August 30, 2017 Nice start, Eric! Waiting to see your rendition of the throttle quadrant - quite minute detail there, too! Link to comment Share on other sites More sharing options...
Bobs Buckles Posted August 30, 2017 Share Posted August 30, 2017 Two eyes firmly fixed on this build log. Good luck! vB Link to comment Share on other sites More sharing options...
TimW Posted August 30, 2017 Share Posted August 30, 2017 Most cool! This is not an aircraft you see much in any scale, IMO! Tim W. Link to comment Share on other sites More sharing options...
