Michael Scarborough Posted February 20, 2018 Share Posted February 20, 2018 Hi, Wouter, Thanks very much for taking the time to share your thoughts and do a little research for me. And, especially, for the words of advice re: resin conversions! I've actually been working with resin parts from Taurus to upgrade the engines on my AEG, and getting a lot of experience with working with SMALL parts in process. I have never done a resin conversion, but have done a major styrene conversion of the WnW HB W. 12 back to the prototype, pix of which I will post tomorrow in Ready for Inspection. But even with those experiences behind me, I think your advice re: tackling the Ju 388 conversion as a first seems solid. I'll order the Michulec book now. Any suggestions on which donor kit I should get should I want to try the V28? I don't want to hijack your thread with more questions, so will leave it at that. Many thanks! Cheers from NYC, Michael Wouter 1 Link to comment Share on other sites More sharing options...
Wouter Posted February 22, 2018 Author Share Posted February 22, 2018 Evening all, or goodmorning if you're somewhere else on the planet I have been procrastinating on finishing the cockpit, since I dread the tedious masking. So I turned my attention to some other things that needed to be done. First the landing gear. Since I don't have the G-factor undercarriage and the model is quiet heavy I was looking for a way to strengthen the kit parts. I came up with this solution: Unaltered kit parts clean the inside Hard metal rod and brass tubing fitted This was glued using 5 min resin. the gear was now rock solid. Somewhere along the way I found this picture You can see that the oleo is much more compressed then the Revell kit parts. I went back to reference photos and almost every plane has the compression. Besides that, on several Ju388 the oleo proctection covers (socks) are missing. Enough elements for me to alter the landing gear. Since altering the previously strengthened parts wasn't an option I needed a new pair . Luckily I was able to acquire a cheap Ju88 A1. I figured I could use the 'old' gear on that kit at a certain time in the future and use the 'new' ones for my 388. I approached the landing gear the same way like last time, but cutting out the covers. These were replaced with a piece of brass, representing the oleo. I made sure the brass pices were shorther than the 'socks'. both done Extra details added and the brake line So, pretty happy with that. Looks a lot more at what I can see in my reference. More... Gazzas, dutik, LSP_Kevin and 5 others 8 Link to comment Share on other sites More sharing options...
Wouter Posted February 22, 2018 Author Share Posted February 22, 2018 (edited) Next up; something that brought me back to this build. The fantastic replacement propeller set by Henri Daehne! Oh boy, if haven't seen these in real life yet you're in for a treat. Excellent casting, superb detail and very accurate. Ok, one minor flaw due to resin shrinkage, the hubs had a few dimpels. These where easliy fixed with some filler. The resin used is pretty hard but also flexible. The blades are razor sharp at the trailing edge, but due to the flexibel resin the can take a beating. You have to purposely bent them (to far) to damage or break them. Here is a blade compared to the kit part, it's like night and day in details and shape After a little cleaning, cutting to length and adding the counterbalancing weigths you quickly have eigth blades and after painting Pre assembly and finished. I place them beside the kit part for comparison. If you're qoing to build this kit, do yourself a pleasure and buy this easy and relatively cheap upgrade. Henri Daehne also makes a version without the hub for even more detail! Edited February 22, 2018 by Wouter LSP_Kevin, sandokan, chukw and 4 others 7 Link to comment Share on other sites More sharing options...
Wouter Posted February 22, 2018 Author Share Posted February 22, 2018 I'll finish with a few glamour shots (on the old legs by the way) Cheers, Wouter nmayhew, chukw, Hubert Boillot and 12 others 15 Link to comment Share on other sites More sharing options...
monthebiff Posted February 23, 2018 Share Posted February 23, 2018 Nice update Wouter, coming together very nicely indeed, your hard hard work is starting to pay off! Regards. Andy Link to comment Share on other sites More sharing options...
Gazzas Posted February 23, 2018 Share Posted February 23, 2018 (edited) Wow, that looks great. What a cool looking plane... well, except for the belly bulge. I've read that the ventral tubs on the early Ju88 and He111 cost like 25mph in speed. Gaz Edited February 23, 2018 by Gazzas Link to comment Share on other sites More sharing options...
nmayhew Posted March 11, 2018 Share Posted March 11, 2018 Wow that looks so cool! 😎 Link to comment Share on other sites More sharing options...
Rick K Posted March 11, 2018 Share Posted March 11, 2018 Great stuff on this beauty. Link to comment Share on other sites More sharing options...
alaninaustria Posted March 11, 2018 Share Posted March 11, 2018 Very nice work! What size of wooden craddle is that one in the pics? Cheers Alan Link to comment Share on other sites More sharing options...
Out2gtcha Posted March 11, 2018 Share Posted March 11, 2018 Wow, that looks terrific! The HD prop set looks really great too Link to comment Share on other sites More sharing options...
Wouter Posted March 12, 2018 Author Share Posted March 12, 2018 Thanks gents! progress is slow at the moment, work and life got in the way. But I hope to get back on the bench soon. Very nice work! What size of wooden craddle is that one in the pics?CheersAlan It's the JM models 1:24/32. Ju388 wingspan is 70 cm or 27.5 inch. Cheers, Wouter Link to comment Share on other sites More sharing options...
Michael Scarborough Posted March 12, 2018 Share Posted March 12, 2018 Super looking, Wouter. Great work with strengthening the under carriage, and a great reference shot. Is there a boot over the oleo? Cheers from NYC, Michael Link to comment Share on other sites More sharing options...
Wouter Posted March 13, 2018 Author Share Posted March 13, 2018 Super looking, Wouter. Great work with strengthening the under carriage, and a great reference shot. Is there a boot over the oleo? Cheers from NYC, Michael Thanks Michael. No, I didn't want the boot on the oleo, that's why I made a new version of the under carriage (besides the compression being off). Link to comment Share on other sites More sharing options...
Wouter Posted March 13, 2018 Author Share Posted March 13, 2018 Just had a very lengthy masking session with the upper canopy. Fresh blade, masking tape and a lot of patience. Now I can add the inner structure, moisture taps and other details. After painting I can glue the canopy in place, Woohoo! Can't wait to get there. sandokan, Rick Griewski, LSP_Kevin and 2 others 5 Link to comment Share on other sites More sharing options...
Michael Scarborough Posted March 14, 2018 Share Posted March 14, 2018 Next we'll find you in the operating room, Doctor...... Link to comment Share on other sites More sharing options...
