BloorwestSiR Posted April 4, 2018 Share Posted April 4, 2018 Thanks Patrick, that give me enough to take a crack at it. Carl patricksparks 1 Link to comment Share on other sites More sharing options...
patricksparks Posted April 11, 2018 Author Share Posted April 11, 2018 Propeller Factory... I whittled down one of the kits "Canoe Paddle" propeller blades and made a mold inching along... [/url]">http://https://postimg.cc/image/6a2cj6pi3/'> Kagemusha, Model_Monkey, LSP_Kevin and 4 others 7 Link to comment Share on other sites More sharing options...
patricksparks Posted April 13, 2018 Author Share Posted April 13, 2018 Some more progress.... bouncing around on different areas to avoid the dredded rutt.. Put the first set of casted propeller blades that I made up onto a hub to check the fit, seems to do the trick. Also I filled in the openings in the rudders that had to be lowered to match the vertical stabilizers and added the new openings. Word of caution, if you are building the HK B-25 check the rudder halves before you glue them together, I found that my kit's parts didn't want to close up on the trailing edges, don't know if it's an issue with shrinkage but I took a large sanding block to the insides of the halves to make sure they were flat enough that they would close up all the way before gluing. [/url]">http://https://postimg.cc/image/7bhqzpmwb/'> Trak-Tor, sandokan, Greg W and 7 others 10 Link to comment Share on other sites More sharing options...
Out2gtcha Posted April 13, 2018 Share Posted April 13, 2018 Outstanding! patricksparks 1 Link to comment Share on other sites More sharing options...
Martinnfb Posted April 13, 2018 Share Posted April 13, 2018 (edited) Joy to follow! Edited April 13, 2018 by Martinnfb Link to comment Share on other sites More sharing options...
patricksparks Posted April 20, 2018 Author Share Posted April 20, 2018 Finally got around to fitting the wings, you really have to remove a good amount off the hook tabs on the fuselage halves that key into the wings to get them to go on, I didn't want them too tight so that I can remove them for painting to make it easier to get in and around the engine nacelles. I wanted to get a look at the overall shape of the back-date so far.">http:// ">http:// chukw, Out2gtcha, sandokan and 12 others 15 Link to comment Share on other sites More sharing options...
Kagemusha Posted April 20, 2018 Share Posted April 20, 2018 Looks fantastic. patricksparks 1 Link to comment Share on other sites More sharing options...
rigor Posted April 20, 2018 Share Posted April 20, 2018 How cool it that. Bravo patricksparks 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted April 20, 2018 Share Posted April 20, 2018 Wow, terrific!! patricksparks 1 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted April 20, 2018 Share Posted April 20, 2018 Looks great to me. Carl patricksparks 1 Link to comment Share on other sites More sharing options...
dennismcc Posted April 20, 2018 Share Posted April 20, 2018 That looks amazing, nice job Cheers Dennis patricksparks 1 Link to comment Share on other sites More sharing options...
brahman104 Posted April 20, 2018 Share Posted April 20, 2018 Terrific work Patrick! That fuselage looks so clean you almost can't tell the work you've done with the re-shaping. Your propellors came up really nice too, much better than my efforts How are you planning on doing the rear clear part? Vacform, or clear casting? Craig patricksparks 1 Link to comment Share on other sites More sharing options...
patricksparks Posted April 20, 2018 Author Share Posted April 20, 2018 Terrific work Patrick! That fuselage looks so clean you almost can't tell the work you've done with the re-shaping. Your propellors came up really nice too, much better than my efforts How are you planning on doing the rear clear part? Vacform, or clear casting? Craig I'm planning on vacuum forming the tail cone. I still have to re-shape the bottom of the fuselage under the horizontal stabilizer as the earlier A/B/C's had a rounder cross section on the bottom, shouldn't be too bad though, it's only about the last inch. Link to comment Share on other sites More sharing options...
patricksparks Posted April 20, 2018 Author Share Posted April 20, 2018 I had a thought today on this project, I started thinking about maybe doing an early straffer, before they painted over the clear bombadier's glazing, it might be a twist to look in and see a bunch of 50 cals mounted under glass ??? BloorwestSiR 1 Link to comment Share on other sites More sharing options...
misha71 Posted April 20, 2018 Share Posted April 20, 2018 true masterpeace patricksparks 1 Link to comment Share on other sites More sharing options...
