mc65 Posted February 23 Share Posted February 23 (edited) Ho Tolga, nice (and challenging) kit's choice! I did the very same subject a couple of years ago, another bug is about the guns position on the wing's leading edge. let see if I find my wip... here: Edited February 23 by mc65 Antonio Argudo, BiggTim and Tolga ULGUR 3 Link to comment Share on other sites More sharing options...
chaos07 Posted February 24 Share Posted February 24 There is something about the early mustangs . . . nice progress - looking forward to more! Tolga ULGUR 1 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted February 24 Author Share Posted February 24 Aires wheel well part installed. Isar 30/07, Shoggz, LSP_Kevin and 14 others 16 1 Link to comment Share on other sites More sharing options...
Biggles87 Posted February 24 Share Posted February 24 That looks like a good fit, I put one in my Mustang 1A but had to sand the roof to wafer thin to get it in. John LSP_Kevin and Tolga ULGUR 2 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted February 24 Author Share Posted February 24 1 hour ago, Biggles87 said: That looks like a good fit, I put one in my Mustang 1A but had to sand the roof to wafer thin to get it in. John Here too the outer corners of the set need sanding chaos07, Azgaron, Greg W and 4 others 7 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted February 24 Author Share Posted February 24 2 hours ago, Biggles87 said: That looks like a good fit, I put one in my Mustang 1A but had to sand the roof to wafer thin to get it in. John What you wrote encourages me to use the other set I have in the P-51A project. It is possible that I will bring this to my agenda as well. Thanks chaos07 and Biggles87 2 Link to comment Share on other sites More sharing options...
Biggles87 Posted February 24 Share Posted February 24 I’m pleased to hear it. I also used the Vector cockpit on my -1A, it’s beautifully detailed and fitted really well. John Tolga ULGUR 1 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted February 24 Author Share Posted February 24 36 minutes ago, Biggles87 said: I’m pleased to hear it. I also used the Vector cockpit on my -1A, it’s beautifully detailed and fitted really well. John Yes, Vector's set is great. I built one before with the Vector set. However, I left the wheel well as it was. Biggles87 1 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted February 25 Author Share Posted February 25 I started working on the fuselage. I made the exhaust slots more reasonable by using thin plastic sheet. I will use Aerocraft's exhausts instead of Trumpy's crappy ones phasephantomphixer, geedubelyer, Greg W and 15 others 18 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted February 27 Author Share Posted February 27 Some progress I decided to build this model with the flaps down. However, this requires some modifications in the fuselage. I made these areas with plastic sheet and putty HB252, scvrobeson, Isar 30/07 and 16 others 19 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted February 28 Author Share Posted February 28 Today's update: This is one of the most problematic parts of Trumpy's kit. As seen in the pictures, the area between the windows behind the cockpit is very wide. It is obvious that this is not the job of Trumpy's A team. Aerocraft released a clear resin kit a few years ago for this problem. It looks like it will work. The necessary parts of the fuselage were cut. Test fitting looks good. I keep moving forward, hoping I don't run into Murphy. Greg W, Landrotten Highlander, HB252 and 17 others 20 Link to comment Share on other sites More sharing options...
Martinnfb Posted February 28 Share Posted February 28 Muuuuuch better, you make it look easy Tolga, joy to follow . Cheers Martin Tolga ULGUR 1 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted February 28 Author Share Posted February 28 17 minutes ago, Martinnfb said: Muuuuuch better, you make it look easy Tolga, joy to follow . Cheers Martin Thanks Martin Martinnfb 1 Link to comment Share on other sites More sharing options...
Biggles87 Posted February 28 Share Posted February 28 A brave move with the flaps, and as Martin says you do make it look easy. John Tolga ULGUR and Martinnfb 2 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted February 28 Share Posted February 28 Well done, Tolga! I'll have to get the Aerocraft piece for my own build. Kev Tolga ULGUR 1 Link to comment Share on other sites More sharing options...
