Dandiego Posted November 10, 2023 Author Share Posted November 10, 2023 Working on some small details. I have printed out a first version of my cockpit side walls and IP. They seem to fit so I will go back into Fusion and add some more details. Radio deck was received some wiring. Brake lines on the main gear. Dan Dekon, Landrotten Highlander, TankBuster and 12 others 15 Link to comment Share on other sites More sharing options...
Dandiego Posted November 12, 2023 Author Share Posted November 12, 2023 Here are some cockpit details. Paint tomorrow. Dan Dekon, geedubelyer, Martinnfb and 8 others 11 Link to comment Share on other sites More sharing options...
Dandiego Posted November 13, 2023 Author Share Posted November 13, 2023 (edited) I have painted the cockpit details and am now working on getting everything to fit. Some tweaking is needed to get everything to fit. Also I have noticed that there is enough room in front of the IP too add extra weight. This should finally solve the tail heaviness that has been a persistent issue. Dan Edited November 13, 2023 by Dandiego patricksparks, denders, R Palimaka and 11 others 14 Link to comment Share on other sites More sharing options...
Troy Molitor Posted November 13, 2023 Share Posted November 13, 2023 Looking good Dan. Martinnfb and Dandiego 2 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted November 13, 2023 Share Posted November 13, 2023 Nice progress, Dan. Kev Dandiego and Martinnfb 2 Link to comment Share on other sites More sharing options...
waxdart Posted November 14, 2023 Share Posted November 14, 2023 I love it Dan! Dandiego and Martinnfb 2 Link to comment Share on other sites More sharing options...
Dandiego Posted November 18, 2023 Author Share Posted November 18, 2023 When printing out resin models you will, eventually, need to vac form some canopies. My history of creating vac canopies was mediocre, at best. So when I sold a 1:48th scale F-103 I immediately ordered this all in one vac machine. Can't wait to use it. Here are the canopy blanks filled with Bondo to better survive the process. Wish me luck, Dan chukw, LSP_Kevin, denders and 6 others 9 Link to comment Share on other sites More sharing options...
Out2gtcha Posted November 18, 2023 Share Posted November 18, 2023 2 hours ago, Dandiego said: When printing out resin models you will, eventually, need to vac form some canopies. My history of creating vac canopies was mediocre, at best. So when I sold a 1:48th scale F-103 I immediately ordered this all in one vac machine. Can't wait to use it. Here are the canopy blanks filled with Bondo to better survive the process. Wish me luck, Dan Good luck Dan! I too have found that even with some very good high clear resin and a very capable resin printer I'm finding the end product wont be as acceptable as Id like. Close, but not. I also think they will be great at making some great blanks for pulling vacs, so that being said, I'm thinking I too will need a vac machine. I know lots have successfully made their own, but the off the shelf ones are not really that expensive, so I feel it would be a worth while investment. Dandiego and Martinnfb 2 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted November 18, 2023 Share Posted November 18, 2023 Let us know how you go, Dan. I'm looking at getting one of these machines myself. Kev Martinnfb and Out2gtcha 2 Link to comment Share on other sites More sharing options...
Dandiego Posted November 19, 2023 Author Share Posted November 19, 2023 Ok, I have done my first pull on the new vac machine. Couldn't have been easier. Prepare your blank, set it on the stage and raise it just a little to ensure a complete pull. Put your sheet plastic into the holder and lock it in place. Turn on the heating element. Wait until the plastic sags. Turn off heat, try on suction, lower the plastic down onto the stage. Whamo....you have vacformed a part. Dan denders, LSP_Ray, scvrobeson and 9 others 12 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted November 19, 2023 Share Posted November 19, 2023 Kev Out2gtcha, Martinnfb and Dandiego 3 Link to comment Share on other sites More sharing options...
Out2gtcha Posted November 19, 2023 Share Posted November 19, 2023 Great work Dan! What brand is the vac machine? Martinnfb and Dandiego 2 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted November 19, 2023 Share Posted November 19, 2023 1 hour ago, Out2gtcha said: Great work Dan! What brand is the vac machine? They're generic dental vacuformers, Brian. There's dozens of them on eBay that all look alike, and probably all come out of the same Chinese factory and re-badged to suit. A bit like those plastic spay booths that are everywhere under any number of brand names, but they're all basically the same thing. They're a couple of hundred AU dollars, so about $8.50 for you. Kev Martinnfb and Out2gtcha 2 Link to comment Share on other sites More sharing options...
Dandiego Posted November 19, 2023 Author Share Posted November 19, 2023 3 minutes ago, LSP_Kevin said: They're generic dental vacuformers, Brian. There's dozens of them on eBay that all look alike, and probably all come out of the same Chinese factory and re-badged to suit. A bit like those plastic spay booths that are everywhere under any number of brand names, but they're all basically the same thing. They're a couple of hundred AU dollars, so about $8.50 for you. Kev Kev pretty much nailed it. My machine has no name or identifying marks on it. When I was searching for one there were several for sale, almost all exactly the same. Mine cost $118. Dan Martinnfb and Out2gtcha 2 Link to comment Share on other sites More sharing options...
thierry laurent Posted November 19, 2023 Share Posted November 19, 2023 Those Chinese machines are very easy to use. No cheap but they give far better result than most DIY solutions. The only challenge is to reach the best plastic temperature but it is easy to get the feel. Dandiego, Out2gtcha and Martinnfb 3 Link to comment Share on other sites More sharing options...
