Martinnfb Posted October 25, 2023 Share Posted October 25, 2023 The props are so much better, really makes sense to tweak them out since it's a focal point of the whole airframe. Joy to follow your progress Dan. Cheers Martin Dandiego 1 Link to comment Share on other sites More sharing options...
Volksjager Posted October 26, 2023 Share Posted October 26, 2023 This is a fantastic project and looking forward to more updates. The resin prints look heaps better for the props and wheels are awesome. Pity about the breakage on the prop. I would assume the breakage came from cleaning the supports off of the trailing edge of the blade? Martinnfb and Dandiego 2 Link to comment Share on other sites More sharing options...
Dandiego Posted October 26, 2023 Author Share Posted October 26, 2023 Yes, snapped off one blade while removing supports. Crap o la. Dan Martinnfb 1 Link to comment Share on other sites More sharing options...
Volksjager Posted October 26, 2023 Share Posted October 26, 2023 Just thinking out loud, I am doing some research into designing a continuous support in fusion, along an edge like the edge of the prop blade to avoid warping and the pockmarks you get from conventional supports. There is a post on Britmodeller about the subject. Going to look at using it for my cockpit sidewalls on the 109. https://www.britmodeller.com/forums/index.php?/topic/235127479-on-designing-your-own-continuous-supports-for-custom-parts/ Maybe something that might help in this situation for the blades, but I am not sure. Martinnfb and Dandiego 2 Link to comment Share on other sites More sharing options...
Dandiego Posted October 26, 2023 Author Share Posted October 26, 2023 8 minutes ago, Volksjager said: Just thinking out loud, I am doing some research into designing a continuous support in fusion, along an edge like the edge of the prop blade to avoid warping and the pockmarks you get from conventional supports. There is a post on Britmodeller about the subject. Going to look at using it for my cockpit sidewalls on the 109. https://www.britmodeller.com/forums/index.php?/topic/235127479-on-designing-your-own-continuous-supports-for-custom-parts/ Maybe something that might help in this situation for the blades, but I am not sure. Thanks I will look into it. Dan Martinnfb 1 Link to comment Share on other sites More sharing options...
Dekon Posted October 28, 2023 Share Posted October 28, 2023 Dan, when you remove the supports are you doing it pre or post cure? I've found that removing them pre cure they are much easier to remove and have less parts breakage. BTW an absolutely fantastic subject. Wish someone would release one of these. It looks like it is doing 500mph just sitting there; to bad it had to many issues to overcome and at a time when jets were coming into play. Martinnfb 1 Link to comment Share on other sites More sharing options...
Dandiego Posted October 28, 2023 Author Share Posted October 28, 2023 22 minutes ago, Dekon said: Dan, when you remove the supports are you doing it pre or post cure? I've found that removing them pre cure they are much easier to remove and have less parts breakage. BTW an absolutely fantastic subject. Wish someone would release one of these. It looks like it is doing 500mph just sitting there; to bad it had to many issues to overcome and at a time when jets were coming into play. I am removing the supports post cure. Perhaps I will give your suggestion a try. I am awaiting a shipment of some "tough" resin that should be a little more flexible. Hopefully this will help. If you are interested in this model I can produce one for you. I need to get everything figured out on my example and add some detail to the cockpit before I can produce them for others. Cost is yet to be determined. Stay tuned. Dan Volksjager and Martinnfb 2 Link to comment Share on other sites More sharing options...
Dandiego Posted November 6, 2023 Author Share Posted November 6, 2023 (edited) Well after a few days off I am back on track with the Moonbat. The props gave me a little trouble. After receiving some new "tough" resin I re-printed the prop/spinner combo. These turned out quite nice. However I did manage to snap off one blade that I had to glue back on. I also worked on getting as much weight as possible jammed into each spinner. Part of that solution was to use a solid metal rod as a prop shaft. This added even more weight to the assembly. Here is the completed and painted prop assembly in place. I have also done some more paint work top and bottom. Mostly just cockpit and canopy work that is left to do. And a quick shot of the tires with a little paint. Dan Edited November 6, 2023 by Dandiego Learstang, Landrotten Highlander, Dennis7423 and 17 others 20 Link to comment Share on other sites More sharing options...
Volksjager Posted November 6, 2023 Share Posted November 6, 2023 It looks fantastic, props came out great Martinnfb and Dandiego 2 Link to comment Share on other sites More sharing options...
denders Posted November 6, 2023 Share Posted November 6, 2023 Dan, you need some of this. It's basically lead powder for swing weighting golf clubs. I don't remember where I got it though. thierry laurent, Dandiego and Martinnfb 3 Link to comment Share on other sites More sharing options...
Jim Barry Posted November 6, 2023 Share Posted November 6, 2023 https://www.golfworks.com/powdered-lead-1lb/p/lp/?sku=LP&gad_source=1&gclid=Cj0KCQiAuqKqBhDxARIsAFZELmI4VeOoK7Jbi62RQuju75Nv-pRzrVvfKxwOkccktbj79Xd6mswKUFkaAqUzEALw_wcB Martinnfb 1 Link to comment Share on other sites More sharing options...
Martinnfb Posted November 6, 2023 Share Posted November 6, 2023 Wheels look fantastic! Dandiego 1 Link to comment Share on other sites More sharing options...
Dandiego Posted November 8, 2023 Author Share Posted November 8, 2023 Here is the Bat sitting on its gear. Balance is very precarious, and I will be drilling a hole in the forward side of the main gear well and inserting more weights. 5 pennies keep it nose down for now. The mostly complete wheel assemblies. And some cockpit details that I downloaded for free from Cults 3D. I will be using some of these items to dress up the cockpit. Thanks, Dan Volksjager, geedubelyer, LSP_Kevin and 13 others 16 Link to comment Share on other sites More sharing options...
Martinnfb Posted November 8, 2023 Share Posted November 8, 2023 Almost there Dan, she's looking really good. Dandiego 1 Link to comment Share on other sites More sharing options...
Dekon Posted November 8, 2023 Share Posted November 8, 2023 This is looking great! Dandiego and Martinnfb 2 Link to comment Share on other sites More sharing options...
