Oldbaldguy Posted May 28, 2023 Share Posted May 28, 2023 I like what you did with the nose gear well. I sometimes think some resin parts are highly overrated and just not worth the effort if a little real modeling will get you to the same place. I also use stranded wire to simulate wire bundles but, rather than cutting the wire to fit the space, if I can I drill appropriately sized holes in the bulkheads, pass the wire through, and glue it to the outside of the part where you can’t see it. That way the wires always have a finished look and fit neatly with minimum fuss. I found that was by far the easiest way to fit all the pipes and such in the wing bay, assuming you are going to raise the wing on your Crusader. chrish, Marcel111 and easixpedro 2 1 Link to comment Share on other sites More sharing options...
chrish Posted May 28, 2023 Author Share Posted May 28, 2023 The wing will be down against the fuselage, wings extended. It was originally planned to do wheels up, pilot in the seat “in flight” due to the clean smooth lines of the aircraft. But after having bought the resin bits, I’ll settle for cockpit closed but on its wheels. Daniel Leduc, blackbetty and scvrobeson 3 Link to comment Share on other sites More sharing options...
scvrobeson Posted May 28, 2023 Share Posted May 28, 2023 The Crusader is such a cool aircraft, I like the progress you've made so far. Keep it up Matt Link to comment Share on other sites More sharing options...
Oldbaldguy Posted May 28, 2023 Share Posted May 28, 2023 6 hours ago, chrish said: The wing will be down against the fuselage, wings extended. It was originally planned to do wheels up, pilot in the seat “in flight” due to the clean smooth lines of the aircraft. But after having bought the resin bits, I’ll settle for cockpit closed but on its wheels. Closed my F-8 cockpit for exactly the same reason - just cause it looks so sleek and deadly. I’ve always liked the lines of this airplane. chrish 1 Link to comment Share on other sites More sharing options...
chrish Posted May 30, 2023 Author Share Posted May 30, 2023 A little progress... hearing that Archer stuff is going to be available again at some point, I added some rivets to the nose gear bay; painted and glued the parts together I cut some thin strips of scotch brand celo tape and stuck it to the intake, shot with a 1:1 mix of Tamiya flat and gloss whites Thanks for looking Alain Gadbois, Marcel111, Landrotten Highlander and 8 others 11 Link to comment Share on other sites More sharing options...
blackbetty Posted May 30, 2023 Share Posted May 30, 2023 this is whats left from the sheet, let me know scvrobeson, Anthony in NZ, F`s are my favs and 2 others 5 Link to comment Share on other sites More sharing options...
themongoose Posted June 1, 2023 Share Posted June 1, 2023 I’m super excited about this. Looking forward to your work on it! Link to comment Share on other sites More sharing options...
chrish Posted June 1, 2023 Author Share Posted June 1, 2023 On 5/30/2023 at 12:47 AM, blackbetty said: this is whats left from the sheet, let me know Thanks for the offer I'm thinking 149212 looks like a nice option I've noticed the LHS has another kit on the shelf....such a cool aircraft I think I'll grab up that one as well Link to comment Share on other sites More sharing options...
blackbetty Posted June 1, 2023 Share Posted June 1, 2023 if you want it PM me your adress Martinnfb 1 Link to comment Share on other sites More sharing options...
chrish Posted June 3, 2023 Author Share Posted June 3, 2023 Some crazy level of accuracy, the seat actually slides in and out on the rails a splash of paint and some assembly work continues Thanks for looking Marcel111, MikeMaben, F`s are my favs and 14 others 17 Link to comment Share on other sites More sharing options...
MikeMaben Posted June 4, 2023 Share Posted June 4, 2023 Link to comment Share on other sites More sharing options...
themongoose Posted June 4, 2023 Share Posted June 4, 2023 NICE cockpit, Link to comment Share on other sites More sharing options...
chrish Posted June 5, 2023 Author Share Posted June 5, 2023 Progress moving right along, the kit almost builds itself and, that with resin bits too. I've joined the fuselage halves and seam work is underway. a couple of sink marks and seam on the vertical stab needed filler Thanks for looking blackbetty, MikeMaben, easixpedro and 18 others 21 Link to comment Share on other sites More sharing options...
MikeMaben Posted June 5, 2023 Share Posted June 5, 2023 Shaping up nicely Chris ... chrish 1 Link to comment Share on other sites More sharing options...
themongoose Posted June 5, 2023 Share Posted June 5, 2023 Super nice, and that leather look on the cover over the coming pops! Link to comment Share on other sites More sharing options...
