mozart Posted December 27, 2023 Author Share Posted December 27, 2023 (edited) Focussing on the tail end, rudder specifically, today. A detail that is missed on the PCM kit, the rudder horns and the balances "weights" on the trim tab: Checking against the Revell new tool Hurricane: I'll probably do a bit more to the figure later so I put together a "pot pourri" of shots from the Pathe News scramble video: I need to find a suitable ground crew figure too from somewhere. Edited December 27, 2023 by mozart Landrotten Highlander, MikeMaben, Fanes and 1 other 4 Link to comment Share on other sites More sharing options...
mozart Posted December 27, 2023 Author Share Posted December 27, 2023 Starting to look more and more like a Hurricane! The rudder control horns were some spares that I had over from the Silver Wings Tiger Moth and the trim tab balance is at the moment just a small strip of spare PE. The rudder was definitely worth separating and mounting individually....gives the model a bit of "attitude" in my opinion! dennismcc, R Palimaka, Landrotten Highlander and 6 others 9 Link to comment Share on other sites More sharing options...
Panzerwomble Posted December 27, 2023 Share Posted December 27, 2023 That’s looking rather great Max, personally prefer hawkers to supermarine and the lineage from all their 1930s biplanes is clear mozart 1 Link to comment Share on other sites More sharing options...
mozart Posted December 27, 2023 Author Share Posted December 27, 2023 (edited) 1 hour ago, Panzerwomble said: That’s looking rather great Max, personally prefer hawkers to supermarine and the lineage from all their 1930s biplanes is clear Thanks Guy, I have to agree 100% about the Hawker lineage....pedigree is everything! I'm going to be doing the Spitfire prototype before too long, K5054, but the Hurricane one, K5083, has been on my "to do" list for a long time. I think the PCM fabric wing is the only real candidate as a starter kit but I'll have to search hard for one of those. I have another Hawker Fury (the biplane) to do as well when time permits! Edited December 27, 2023 by mozart Panzerwomble 1 Link to comment Share on other sites More sharing options...
mozart Posted December 30, 2023 Author Share Posted December 30, 2023 This close-up was worth some scrutiny, especially the metalwork on the wings: I had lost some definition around the wing roots whilst achieving a smooth finish, and that fairly prominent row of "rivets" doesn't really feature very well on the PCM kit, so I measured and cut out the panel (including rivet locations) using Oramask, applied it to the wing then drilled out the rivet points. I put some fine plastic rod in each: and with a coat of silver, the rod sanded but it needs a bit more I think: I'm very tempted by these: though I don't envisage doing "an Andy (monthebiff)" and coating the whole plane in them. Useful addition though I think. Landrotten Highlander, denders, Alain Gadbois and 4 others 7 Link to comment Share on other sites More sharing options...
dennismcc Posted December 30, 2023 Share Posted December 30, 2023 Wow those look impressive, would need to make sure that my magnifier was handy. Cheers Dennis mozart 1 Link to comment Share on other sites More sharing options...
mozart Posted December 30, 2023 Author Share Posted December 30, 2023 (edited) 1 hour ago, dennismcc said: Wow those look impressive, would need to make sure that my magnifier was handy. Cheers Dennis Agreed and they're on order* Dennis! We'll see how useful they are, I can think of lots of applications for them already. *and apparently despatched already, within 2 hours of ordering, along with some precision tweezers and assorted nuts and bolts! Edited December 30, 2023 by mozart dennismcc 1 Link to comment Share on other sites More sharing options...
monthebiff Posted December 30, 2023 Share Posted December 30, 2023 12 hours ago, mozart said: This close-up was worth some scrutiny, especially the metalwork on the wings: I had lost some definition around the wing roots whilst achieving a smooth finish, and that fairly prominent row of "rivets" doesn't really feature very well on the PCM kit, so I measured and cut out the panel (including rivet locations) using Oramask, applied it to the wing then drilled out the rivet points. I put some fine plastic rod in each: and with a coat of silver, the rod sanded but it needs a bit more I think: I'm very tempted by these: though I don't envisage doing "an Andy (monthebiff)" and coating the whole plane in them. Useful addition though I think. Max, you won't regret buying these, I have a few sets from ANYZ and they are extremely easy to work with as long as you do the prep correctly. Take a look at the switches on the port side pilots panel on my Devastator (silver switches on a black triangular base) They look daunting but work really well. Super build so far Max. Don't forget to open up all those drain holes in the rear fuselage as well which is often overlooked. Regards. Andy Phantom2, mozart, denders and 2 others 4 1 Link to comment Share on other sites More sharing options...
mozart Posted December 31, 2023 Author Share Posted December 31, 2023 Drain holes Andy? Do tell. I’ve opened up what I assumed were jacking points: but look forward to correction/elucidation! Link to comment Share on other sites More sharing options...
MikeMaben Posted December 31, 2023 Share Posted December 31, 2023 (edited) Hi Max, they're in the ventral panel part. There's 2 sections with 6 in each section, 3 on each side. They're not easy to see but they are there. Edited December 31, 2023 by MikeMaben dennismcc 1 Link to comment Share on other sites More sharing options...
mozart Posted December 31, 2023 Author Share Posted December 31, 2023 (edited) Thanks Andy for the prompt and Mike for the info from “the Bible”, ie the wonderful Finnish Hurricane walkaround on BM. Drainage holes drilled in the aft floor pan, the forward one is next. I’ve also drilled out the entrance holes in the fuselage for the rudder cables: Edited December 31, 2023 by mozart Fanes, LSP_Kevin, Shoggz and 4 others 7 Link to comment Share on other sites More sharing options...
monthebiff Posted December 31, 2023 Share Posted December 31, 2023 Lovely job Max, this is cmong along very nicely indeed. Regards. Andy mozart 1 Link to comment Share on other sites More sharing options...
mozart Posted December 31, 2023 Author Share Posted December 31, 2023 1 minute ago, monthebiff said: Lovely job Max, this is cmong along very nicely indeed. Regards. Andy Cheers Andy, I’m loving the PCM Hurricane plus add ons, this is my kind of modelling! I’m really looking forward to the Revell Hurribomber but I’m a bit concerned that it might be a bit too “straightforward”, being the perverse bloke that I am! Which reminds me, I must finish this straightforward Spitfire: then decide which of these is next: (one of the Hart’s will be a Hind) and the Border Models Lanc is too big to be in shot! Happy New Year and good health to you all! Cheetah11, geedubelyer, MikeC and 8 others 11 Link to comment Share on other sites More sharing options...
monthebiff Posted December 31, 2023 Share Posted December 31, 2023 Happy New Year to you also Max and may I suggest a news years resolution( they are absolute rubbish) but build one of those Kotare Spits asap as they are just stunning and you know easy is not my thing either but just a real pleasure to build! Regards. Andy mozart and MikeC 1 1 Link to comment Share on other sites More sharing options...
mozart Posted December 31, 2023 Author Share Posted December 31, 2023 (edited) Thanks Andy, Kotare Spitfire it is then in tandem with the Revell Hurribomber. I had a message from Tim yesterday, bombs and carriers are ready and possibly even on their way! Edited January 1 by mozart denders and Shoggz 2 Link to comment Share on other sites More sharing options...
