sandbagger Posted August 2, 2022 Share Posted August 2, 2022 Hi all, The build of the Junkers J.1 is coming to a close. So next up is the 1:32nd scale resin/3D printed Lloyd C.V from 'Lukgraph'. On October the 4th, 1917, Feldpilot (Zugsfuhrer) Adolph Wiltsch and his Observer Roman Schmidt were flying Lloyd C.V Serial No: 46.01 from Flik 13 on the Russian Front. They were attacked by three Russian ‘Sopwith’ type aircraft. They managed to evade these attackers and Schmidt managed to shoot down one in flames. This was Schmidt’s third aerial victory. Mike themongoose, Rockie Yarwood, blackbetty and 4 others 7 Link to comment Share on other sites More sharing options...
themongoose Posted August 2, 2022 Share Posted August 2, 2022 Awesome, i love rare and unique aircraft! Will follow with great interest. Love the background story as well Link to comment Share on other sites More sharing options...
Rockie Yarwood Posted August 5, 2022 Share Posted August 5, 2022 Link to comment Share on other sites More sharing options...
europapete Posted August 5, 2022 Share Posted August 5, 2022 Nice choice Mike, on my "to get" list from Lukgraph. Link to comment Share on other sites More sharing options...
sandbagger Posted August 8, 2022 Author Share Posted August 8, 2022 Hi all, Having completed the basic chapters for the Lloyd C.V build log, I've found a few bits that will need adding. Addition lower wing support rods. Increased depth of support rods in upper wings. Cockpit cross bracing wires. Pilot cockpit control rods and wires etc. Pilot cockpit flight control cables. Plus the following. Mike Troy Molitor, chukw, Rockie Yarwood and 3 others 6 Link to comment Share on other sites More sharing options...
Bobs Buckles Posted August 10, 2022 Share Posted August 10, 2022 Good luck, Mike! Bob Link to comment Share on other sites More sharing options...
sandbagger Posted August 10, 2022 Author Share Posted August 10, 2022 (edited) Hi all, The six kit supplied 3D printed exhaust pipes are not chamfered at the ends and not bored out internally. Also, when fitted, the exhaust pipes should be angled slightly rearwards, which the kits pipes are not. Therefore, I discarded the kit pipes and replaced them with rod and rubber tube. The two supplied 3D printed halves of the cooling pipe are intended to be butt joined to the engine and to each other. This is a weak method of joining parts. Therefore I cut out and replaced the larger diameter portion of the front pipe and replaced it with Brass 1.4 mm diameter tube. The ends of the pipe were drilled and pinned into the engine, using 0.3 mm diameter Brass rod, Mike Edited August 14, 2022 by sandbagger LSP_Kevin, scvrobeson, blackbetty and 6 others 9 Link to comment Share on other sites More sharing options...
sandbagger Posted August 12, 2022 Author Share Posted August 12, 2022 Hi all, My assumptions for how the engine cooling system worked are: The engine driven water pump on the lower, rear of the engine, supplied water to the six engine cylinders. This supply was pumped through a pipe interconnected to the lower right of the cylinders. The water flowed up inside the cooling jacket of each cylinder and flowed out into the the return in the camshaft housing. From there it flowed through the external forward pipe over the camshaft housing and into the base of the radiator. It was then drawn around the inside of the radiator housing then down through the radiator to be drawn back to the water pump through the external rear pipe. The external overhead cooling pipe supplied in the kit is in two parts and joined together. The radiator just sits on the top of this pipe. However, it seems this is not correct as can be seen from the following photographs taken at the time. The supply to and the return from the radiator are separate pipes, which given the above would make sense. Mike blackbetty, Alex, Fanes and 4 others 7 Link to comment Share on other sites More sharing options...
sandbagger Posted August 15, 2022 Author Share Posted August 15, 2022 Hi all, I decided to modify the radiator pipes to better represent those fitted to the actual aircraft. The 3D printed rear pipe in the kit was discarded and a replacement made from 1.0 mm diameter rod with a 90 degree bend in the radiator end. A hole was drilled into the water pump on the rear of the engine and also into the underside of the radiator. The forward facing extension to the pipe was added with 1.0 mm diameter rod and 1.2 mm diameter tube. The forward 3D printed pipe in the kit was modified with a 1.2 mm diameter end tube and 1.0 mm diameter 90 degree bent rod. A 1.4 mm diameter tube was cut and fitted to the pipe stub on the top, front of the camshaft housing. A hole was drilled for this pipe in the underside of the radiator. Although dry fitted for now, it can all be added after the fuselage, with engine, has been closed up, Mike Landrotten Highlander, scvrobeson, blackbetty and 5 others 8 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted August 15, 2022 Share Posted August 15, 2022 Looking good, Mike. Kev Link to comment Share on other sites More sharing options...
sandbagger Posted August 19, 2022 Author Share Posted August 19, 2022 Hi all, The basic engine is nearly finished. Just the ignition leads to add. The control rods, pipes and exhaust pipes will be added later in the build. As usual, painting a complete 3D printed engine is not that easy. Personally I'd prefer to paint parts then assemble the engine, but that's the way 3D printing is taking us, Mike Alex, LSP_Kevin, Rick Griewski and 6 others 9 Link to comment Share on other sites More sharing options...
scvrobeson Posted August 21, 2022 Share Posted August 21, 2022 Great paintwork and additional details Mike. Always enjoy following you as you blaze the trail on these new kits. Matt Link to comment Share on other sites More sharing options...
sandbagger Posted August 22, 2022 Author Share Posted August 22, 2022 Hi all, The basic engine is now complete. I've added the ignition leads, spark advance and throttle control rods and other pipes. Mike RadBaron, Landrotten Highlander, scvrobeson and 7 others 10 Link to comment Share on other sites More sharing options...
sandbagger Posted August 29, 2022 Author Share Posted August 29, 2022 Hi all, The fuselage components have been prepared for assembly. The wood finish is 'Tamiya' Dark Yellow (XF60) over painted with Windsor & Newton’ Griffin (Alkyd) Burnt Umber oil paint. The ammunition drum is a spare from a 'Gaspatch' Parabellum set, as its more in-scale than the kit supplied 3D printed part. Now it's onto the control rods and cables before the fuselage is assembled and closed up with the engine, Mike Rockie Yarwood, Landrotten Highlander, LSP_Kevin and 4 others 7 Link to comment Share on other sites More sharing options...
sandbagger Posted September 1, 2022 Author Share Posted September 1, 2022 Hi all, The internal fuselage detail is now complete. I've added Control cables and cross bracing using 0.08 mm diameter mono-filament. The spark advance control rod is 0.4 mm diameter Nickel-Silver tube, as will be the throttle control rod. The throttle control rod will be added after the fuselage is closed up, so it can be passed through the left side of the instrument panel frame. I may add a map to the gunners table, Mike LSP_Kevin, Fanes, chukw and 5 others 8 Link to comment Share on other sites More sharing options...
