Uncarina Posted March 9, 2022 Share Posted March 9, 2022 (edited) "At the time of its introduction the aircraft possessed, in combination, revolutionary features for a fighter. It had an all-round vision canopy, whereas most fighters had cockpits faired into the fuselage spine behind the pilot’s head, limiting rearward vision. It carried a 20 mm cannon in each wing, as well as a pair of rifle-calibre machine guns mounted in front of the pilot and synchronised to fire through the propeller. And it had an external fuel tank – a drop tank – that could be jettisoned in combat, the design of which was a masterpiece of engineering in its own right and which enhanced an operating range considered phenomenal at the time. The Zero-sen was the first truly long-range strategic escort fighter – a capability driven by Japanese strategic bombing experience in China that underpinned its extraordinary success during the first year of the Pacific War, coming as such a shock to the Allies." Millman, Nicholas. A6M Zero-sen Aces 1940-42: 137 (Aircraft of the Aces) (pp. 5-6). Bloomsbury Publishing. Kindle Edition. I started building the Tamiya A6M2 and left it around 2017. More recently I was inspired by the work of Sean (Madmax) in his build thread: where he with the aid of Ryan (A6M) put together what I consider the definitive build of the Nakajima-built Zero. To me they are real Senseis (Ones Who Have Gone Before). However, I've always leaned towards the Mitsubishi-built version, and decided to build P01C Tetsuzo Iwamoto's aircraft when he flew from the Zuikaku. When I left the build I had faithfully painted and assembled the cockpit according to Tamiya's instructions. I clearly had work to do! Over the years I have collected a fair bit of aftermarket: Not pictured are the AK Real Color paints I'm now using for the build, which I've read were developed in coordination with Nicholas Millman (http://www.aviationofjapan.com/). I decided to use the Quinta interior set, which meant that I had to scrape off all protruding surfaces, then paint with Mitsubishi Cockpit Green: The Quinta set had a slightly different color interpretation, so I carefully repainted these surfaces with diluted AK Real Colors paint. Note in this last photo you can see that I removed one of the tanks, which according to Ryan's notes is appropriate for a Mitsubishi-built Reisen. Until next time! Cheers, Tom Edited March 10, 2022 by Uncarina TAG, Iain, KiwiZac and 30 others 33 Link to comment Share on other sites More sharing options...
MikeMaben Posted March 10, 2022 Share Posted March 10, 2022 Looks great Tom Uncarina 1 Link to comment Share on other sites More sharing options...
dodgem37 Posted March 10, 2022 Share Posted March 10, 2022 Good show. Sincerely, Mark Uncarina 1 Link to comment Share on other sites More sharing options...
Troy Molitor Posted March 10, 2022 Share Posted March 10, 2022 A fine start indeed. Uncarina 1 Link to comment Share on other sites More sharing options...
Uncarina Posted March 10, 2022 Author Share Posted March 10, 2022 (edited) Thanks to you all! You might notice I removed the clock from the instrument panel, which Ryan pointed out was a common practice among pilots. Mike asked if the artificial horizon is supposed to be crooked when the aircraft is parked. Looks like this might be a mistake by Quinta. What are your thoughts? Cheers, Tom Edited March 10, 2022 by Uncarina Link to comment Share on other sites More sharing options...
Madmax Posted March 10, 2022 Share Posted March 10, 2022 2 hours ago, Uncarina said: Thanks to you all! You might notice I removed the clock from the instrument panel, which Ryan pointed out was a common practice among pilots. Mike asked if the artificial horizon is supposed to be crooked when the aircraft is parked. Looks like this might be a mistake by Quinta. What are your thoughts? Cheers, Tom Hi Tom, I'm amazed at the crisp detail the Quinta set provides - makes the macro shots a real pleasure to behold. Regarding the A/H, it would be quite normal for an uncaged instrument to lie any way it wants when the gyro runs down. I seem to recall being rapped on the knuckles however for leaving instruments uncaged during my ab initio training. Have fun, it is my favourite Tamiya kit to date! Sean MikeMaben, IainM and Uncarina 2 1 Link to comment Share on other sites More sharing options...
Uncarina Posted March 10, 2022 Author Share Posted March 10, 2022 Thank you Sean, it’s great seeing you here. Please feel free to keep me honest during the build, and now I feel better about leaving that A/H the way it is. Cheers, Tom IainM 1 Link to comment Share on other sites More sharing options...
Uncarina Posted March 10, 2022 Author Share Posted March 10, 2022 Just a couple of notes about using the Quinta set. I’ve used several so far and they all have these in common: 1) when wetted they become loose in seconds. I move them over to a section of paper towel to dry; 2) For areas with a big contact surface I use Future floor polish (or the equivalent) to allow repositioning as needed: 3) For smaller surfaces I use CA. However, like any resin these sets adhere immediately, so be precise when positioning; 4) Like any resin the parts are brittle. I had several of the wires break when bending and was luckily able to reattach them. 5) If the color doesn’t match the rest of the cockpit use a fine brush to apply diluted paint (almost a wash). Cheers, Tom D.B. Andrus, MikeMaben and Landrotten Highlander 1 2 Link to comment Share on other sites More sharing options...
IainM Posted March 10, 2022 Share Posted March 10, 2022 That looks brilliant so far! Can't wait to see the rest of the build as it goes along! Uncarina 1 Link to comment Share on other sites More sharing options...
Uncarina Posted March 10, 2022 Author Share Posted March 10, 2022 Thank you Iain! I appreciate your encouragement. Cheers, Tom IainM 1 Link to comment Share on other sites More sharing options...
Juggernut Posted March 10, 2022 Share Posted March 10, 2022 Great work Tom! Uncarina 1 Link to comment Share on other sites More sharing options...
Uncarina Posted March 10, 2022 Author Share Posted March 10, 2022 "Iwamoto was a China veteran already credited with 14 victories when he flew on CAP duties at Pearl Harbor, seeing no action. He made claims for four Hurricanes over Ceylon in April 1942 and further claims for SBDs and Wildcats the following month during the Battle of the Coral Sea. In August he was sent back to Japan to serve as a flying instructor with the Oppama Kokutai, returning to operational duties with 281st Kokutai in March 1943 and subsequently going to Rabaul in a reinforcing detachment. Here, Iwamoto served in 204th Kokutai, claiming 20 victories and five probables in a single month, and 253rd Kokutai. He then fought in the Philippines, over Taiwan and Okinawa with 252nd and 203rd Kokutais, surviving the war but dying of blood poisoning in 1954. Iwamoto’s technique of single hit-and-run attacks in near-vertical dives from very high altitude resulted in many claims that were not substantiated. However, his diary recorded 202 such attacks, and he has been credited with an estimated 80 victories, making him the IJNAF’s second highest and longest serving ace." Millman, Nicholas. A6M Zero-sen Aces 1940-42: 137 (Aircraft of the Aces) (p. 139). Bloomsbury Publishing. Kindle Edition. This is from the Eduard Tora Tora Tora! 1/32 decal set (EDUD32018). This set offers 12 options, along with detailed mini-bios of the pilots. My plan is to make masks for the markings. One of the tweaks with the Tamiya kit is that the area behind the cockpit has recessed rivets, whereas they should be raised. Archers rivets to the rescue! ...which I then painted with AK Real Colors Blue-Black: I first used AK Real Colors on my Shiden-Kai build, and something I've noticed is that I need around a 15:1 thinner-paint ratio, using the AK High Compatibility Thinner. Other than that the coverage and consistency are good. Until next time! Cheers, Tom dodgem37, denders, Antonio Argudo and 18 others 21 Link to comment Share on other sites More sharing options...
Uncarina Posted March 10, 2022 Author Share Posted March 10, 2022 2 minutes ago, Juggernut said: Great work Tom! Thank you Tim! I appreciate your support. Cheers, Tom Link to comment Share on other sites More sharing options...
dutchplanebuilder77 Posted March 10, 2022 Share Posted March 10, 2022 Great work. I love it. Uncarina 1 Link to comment Share on other sites More sharing options...
Troy Molitor Posted March 10, 2022 Share Posted March 10, 2022 Love it X 2..... Uncarina 1 Link to comment Share on other sites More sharing options...
