zaxos345 Posted May 17, 2023 Share Posted May 17, 2023 19 minutes ago, D Bellis said: There are actually 5 mirrors in the Tamiya kit. Sprue B (horizontal stabilizers), parts 16 through 20: It looks to me as though you need part 18 for Butch Baby. HTH, D Kev, same as ''D'' here!!! LSP_Kevin 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted May 17, 2023 Author Share Posted May 17, 2023 2 hours ago, D Bellis said: There are actually 5 mirrors in the Tamiya kit. Sprue B (horizontal stabilizers), parts 16 through 20: It looks to me as though you need part 18 for Butch Baby. HTH, D Thanks, D! I do indeed have all three canopies, and as far as I can remember, the kit was new when I acquired it. It would have helped if Tamiya had included a parts layout in the instruction booklet, as the only RVM mentioned in the assembly sequence is the one on the clear sprue (so we're talking 6 all up, covering 4 different types). Well, at least I've now got that small but prominent feature covered. Thanks, everyone! Kev zaxos345 and D Bellis 2 Link to comment Share on other sites More sharing options...
D.B. Andrus Posted May 17, 2023 Share Posted May 17, 2023 On 5/16/2023 at 4:23 PM, LSP_Kevin said: ("Butch Baby" appears to have the surrounding area on the fin unpainted), Hey Kev The BMF patch around the tail warning radar is actually a raised plate that the antennae are attached to. HTH, Damian LSP_Kevin 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted May 17, 2023 Author Share Posted May 17, 2023 36 minutes ago, D.B. Andrus said: Hey Kev The BMF patch around the tail warning radar is actually a raised plate that the antennae are attached to. HTH, Damian I thought as much. I'll just mask off the shape and build up the area with some Mr. Surfacer I think - especially since it will help disguise the mess I've made! The Tamiya kit has a small piece of photo-etch that slides over the central loop on each side, which I'll be using to help as well. Kev D.B. Andrus 1 Link to comment Share on other sites More sharing options...
Furie Posted May 17, 2023 Share Posted May 17, 2023 Hi Kev, in fact it is a small square plate where the 2 antenna strands are in the middle as in the picture : BiggTim, LSP_Kevin and Model_Monkey 3 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted May 17, 2023 Author Share Posted May 17, 2023 Yep, that's the piece that Tamiya provides. The diagram below seems to show what Damian is referring to: Of course, I put the antenna in backwards! Kev MikeMaben 1 Link to comment Share on other sites More sharing options...
MikeMaben Posted May 18, 2023 Share Posted May 18, 2023 Diagram shows 3 seperate plates on each side, not that that makes a difference LSP_Kevin and BiggTim 2 Link to comment Share on other sites More sharing options...
Furie Posted May 18, 2023 Share Posted May 18, 2023 (edited) l NAA P-51 Mustang Walkaround Gallery (grubbyfingersshop.com) Hopefully this can help you Kev. Edited May 18, 2023 by Furie TAG, LSP_Kevin, Alain Gadbois and 3 others 6 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted May 18, 2023 Author Share Posted May 18, 2023 Superb photos, Denis! Many thanks for posting them. They confirm my basic understanding of the general arrangement of the antenna and its fixings. Kev Furie and Out2gtcha 2 Link to comment Share on other sites More sharing options...
Furie Posted May 18, 2023 Share Posted May 18, 2023 I'm glad these pictures can help you, Kev. And I hope that this little accident on your Mustang is soon fixed. LSP_Kevin 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted May 18, 2023 Author Share Posted May 18, 2023 2 hours ago, Furie said: I'm glad these pictures can help you, Kev. And I hope that this little accident on your Mustang is soon fixed. I think the situation is, mostly, in hand. Kev Link to comment Share on other sites More sharing options...
LSP_Kevin Posted May 18, 2023 Author Share Posted May 18, 2023 So a quick update! May I present to you, Darth Vader's Mustang: The sliding hood has now been masked off inside and out using the Montex masks. These required some additional help in the form of liquid masking fluid - in this case, Mr. Masking Sol Neo. I'm not a huge fan of the stuff, but at least it's easy to get off. The inside has been sprayed, and I'll do the outside in the next session. If I had any doubts about having the canopy open on this one, a proper test fit with the token slide rails in place shows that the sliding hood is too short to meet the canopy anyway: No doubt this is my own doing when cutting it out, but at least I have another option, and one that I had already chosen. Oh, here's how the tail antenna is looking after my attempts to blend it in: I've amped up the exposure on those last two photos, so that you have some hope of actually seeing something. Anyway, I think it looks OK, and as I mentioned previously, I intend to build up the surrounding mounting plate with Mr. Surfacer, and that should help even more, provided I don't get too much build-up on the antenna poles themselves. But that's a job for next time! Kev Tolga ULGUR, patricksparks, Furie and 10 others 13 Link to comment Share on other sites More sharing options...
Out2gtcha Posted May 18, 2023 Share Posted May 18, 2023 6 hours ago, Furie said: l Hell, at this point with that money shot, I would almost be tempted to strip off the PE and plate up that section with some styrene, then knowing they were round, bend 1 U shape and 2 rods for each side out of some jewelry wire................but yes, much more work and I usually never like stripping away something Ive already worked to fit. Either way, looking good! LSP_Kevin and BiggTim 2 Link to comment Share on other sites More sharing options...
BiggTim Posted May 18, 2023 Share Posted May 18, 2023 It would be pretty easy to mask out the extra panel and build it up with a couple coats of primer, then remove the mask and spray the final finish. It would leave a very subtle raised panel effect. LSP_Kevin 1 Link to comment Share on other sites More sharing options...
dennismcc Posted May 18, 2023 Share Posted May 18, 2023 Coming along nicely Kev, a stealth Mustang by the looks of it. Cheers Dennis LSP_Kevin 1 Link to comment Share on other sites More sharing options...
