spartacus2000 Posted May 28, 2021 Share Posted May 28, 2021 (edited) Hi Antonio as you promises Original drawing From part list catalog. Hope that Help you in your decision Cheers Edited May 28, 2021 by spartacus2000 Antonio Argudo, Greg W, D.B. Andrus and 1 other 3 1 Link to comment Share on other sites More sharing options...
Antonio Argudo Posted May 28, 2021 Author Share Posted May 28, 2021 Thank you spartacus2000 great info, I found also this drawing for earlier version and no evidence of that detail so I guess will be filling and deleting it, thanks so much for your help again, cheers Paul in Napier, Greg W, Uncarina and 1 other 4 Link to comment Share on other sites More sharing options...
Antonio Argudo Posted May 29, 2021 Author Share Posted May 29, 2021 after some more research I think it is clear that detail should be gone coogrfan, D.B. Andrus, Paul in Napier and 1 other 4 Link to comment Share on other sites More sharing options...
Antonio Argudo Posted June 21, 2021 Author Share Posted June 21, 2021 after a break, I put a XF62 base color next some Neutral grey, cheers MDuv, Uncarina, LSP_Kevin and 8 others 11 Link to comment Share on other sites More sharing options...
Antonio Argudo Posted June 21, 2021 Author Share Posted June 21, 2021 couldn't resist to weather that OD Fanes, Uncarina, coogrfan and 11 others 14 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted June 21, 2021 Share Posted June 21, 2021 Wow! Kev Antonio Argudo 1 Link to comment Share on other sites More sharing options...
Antonio Argudo Posted June 22, 2021 Author Share Posted June 22, 2021 20 hours ago, LSP_Kevin said: Wow! Kev Thanks Kev, it's paint time, finally my first insignia paint with a mask, my fault didn't aligned it perfectly but it's ok lol, after you try there's no point back to decals ever.... Cheers coogrfan, LSP_Kevin, TAG and 13 others 16 Link to comment Share on other sites More sharing options...
spartacus2000 Posted June 22, 2021 Share Posted June 22, 2021 Hi Antonio. to prevent white from showing on the edges below the blue I usually mask the outline of the mask 0.5mm or so on. Your work is still impeccable, the masks give the model a finish that the decals, even if perfect, fail to give Antonio Argudo and zaxos345 2 Link to comment Share on other sites More sharing options...
RaceFuel Posted July 8, 2021 Share Posted July 8, 2021 That really looks fantastic! What colors did you use in the marbling and weathering of this? Did you base the XF-62 with something or do any sandwich shading? Link to comment Share on other sites More sharing options...
Antonio Argudo Posted July 9, 2021 Author Share Posted July 9, 2021 (edited) On 6/22/2021 at 9:26 PM, spartacus2000 said: Hi Antonio. to prevent white from showing on the edges below the blue I usually mask the outline of the mask 0.5mm or so on. Your work is still impeccable, the masks give the model a finish that the decals, even if perfect, fail to give thanks for the tip, helpful indeed! cheers 5 hours ago, RaceFuel said: That really looks fantastic! What colors did you use in the marbling and weathering of this? Did you base the XF-62 with something or do any sandwich shading? thanks mate, I used Gunze H-304 over the tamiya base, I have applied some ink filter to make the OD more brownish, next is to paint full invasion stripes and cover them with RAF Dark green but also still kinda translucent and evident what's underneath thanks for watching , cheers Edited July 9, 2021 by Antonio Argudo easixpedro, Fanes, LSP_Kevin and 6 others 9 Link to comment Share on other sites More sharing options...
spartacus2000 Posted July 9, 2021 Share Posted July 9, 2021 Hi Antonio I don't know if it is a desired effect but it seems to me that the central area of the wings on the right and left are greener than the external areas that have a decidedly brown dominant. Maybe it's a photo effect but it looks like this on my monitor. Link to comment Share on other sites More sharing options...
Antonio Argudo Posted July 9, 2021 Author Share Posted July 9, 2021 36 minutes ago, spartacus2000 said: Hi Antonio I don't know if it is a desired effect but it seems to me that the central area of the wings on the right and left are greener than the external areas that have a decidedly brown dominant. Maybe it's a photo effect but it looks like this on my monitor. Yes, that was on intentionally, there was a lot of repaint done in those Razorbacks, here it is a real example from a P51B ammo wing panel, you can see the OD(brownish shade) the invasion stripes (black and white) and the top layer of RAF Dark Green paint, so that's what is my aim cheers MDuv, coogrfan, nmayhew and 2 others 5 Link to comment Share on other sites More sharing options...
spartacus2000 Posted July 9, 2021 Share Posted July 9, 2021 I assumed it was a desired effect. Great job, I really like it Link to comment Share on other sites More sharing options...
Citadelgrad Posted July 9, 2021 Share Posted July 9, 2021 On 6/22/2021 at 12:26 PM, spartacus2000 said: Hi Antonio. to prevent white from showing on the edges below the blue I usually mask the outline of the mask 0.5mm or so on. Your work is still impeccable, the masks give the model a finish that the decals, even if perfect, fail to give Can you explain this? I am getting ready to do my first mask markings. Thanks Link to comment Share on other sites More sharing options...
spartacus2000 Posted July 9, 2021 Share Posted July 9, 2021 Greg W, Citadelgrad and scvrobeson 3 Link to comment Share on other sites More sharing options...
