Shawn M Posted November 30, 2020 Share Posted November 30, 2020 Hi gang, figured I'd toss up a WIP on my latest LSP project. I picked up the kit at Hobby Lobby ages ago with a 40% off coupon with a QF4 in mind. Somewhere also picked up a GT Resin Nose Correction and intake kit. Later on I added a RF4 Cockpit kit to address the boring, bland and under detailed Revell Cockpit. This was to be an in flight build, starting out I wanted to address the conversions and resin additions. The nose job. Lacking any instructions I sized up the new nose and comparing panel lines figured out my initial cuts. After completing them and receiving my cockpit set, I glued the front halves together. This highlights a diameter differene between the Resin nose and kit. To facilitate the pinch' I needed I cut off the "gun trough". This allowed me to get an allllllmost gap free fit from the new nose to the fuse. Once that was done I added the "gun trough" back on and added the 'G radar bulb. I still need to go back and rescribe panel lines etc. But getting this far was a lot of work. more to come! johncrow, HerculesPA_2, chrish and 11 others 14 Link to comment Share on other sites More sharing options...
Shawn M Posted November 30, 2020 Author Share Posted November 30, 2020 gear up, holes drilled for the drop tank knowing this was gonna be a HEAVY bird with all the resin, I drilled and pinned the drop tank with resin receiver blocks in the wing time to start the mods for the intakes Cutting at the noted distance I removed the front of the kit intakes. Test fitting showed an interference with the "floor" of the rear fuse, cut out the offending areas after assembling the rear fuse and test fitting to the wing I added a spreader to minimize the wing root gap while I had the sprue out I added a spreader at the nose to adjust for my mods and true up the fit to the lower panel next up, scratch building the forward 'pod' johncrow, Rockie Yarwood, Derek B and 13 others 16 Link to comment Share on other sites More sharing options...
Shawn M Posted November 30, 2020 Author Share Posted November 30, 2020 (edited) ahhh, the pod... After debating about sculpting it from Milliput I decided to use the plethora of spares the kit provided to scratch build the unit. Luckily I took a lot of pics of a QF4E a few years ago. I grabbed a sparrow missile half as the base, sheeted the aft section to give me the filler for the bay. Then cutting up a few other kit missiles I made the over all shape. The trick was to get that compound curved blend at the forward section. While not exact, its close enough for me and one detailed out should look the part just fine. Next up is the final fit and mods to accept the intakes and starting the cockpit. As mentioned I bought a GT Resin RF4 cockpit kit, yes I know there are differences I've already moded the IP and combing. Pics to come as you're now caught up to where I am! Edited November 30, 2020 by Shawn M Rockie Yarwood, johncrow, Derek B and 15 others 18 Link to comment Share on other sites More sharing options...
Anthony in NZ Posted November 30, 2020 Share Posted November 30, 2020 Oh fantastic, another Phantom build up on LSP...just what I need for keeping my mojo going on my Brit one! Lovely work so far! Shawn M 1 Link to comment Share on other sites More sharing options...
F2G_lover Posted December 1, 2020 Share Posted December 1, 2020 Very cool project. I'd like to build one of the all orange QF-4B's myself. Shawn M 1 Link to comment Share on other sites More sharing options...
Fanes Posted December 1, 2020 Share Posted December 1, 2020 Nice to see you back with a build Shawn! I feel the Phantom phever kicking in Shawn M and Anthony in NZ 2 Link to comment Share on other sites More sharing options...
Shawn M Posted December 2, 2020 Author Share Posted December 2, 2020 Thanks Fanes! I've been lurking while working on non LSP stuff. Using some sheet stock and cut bits from the kit intakes I added some further details. currently working on the dorsal spine fairing Anthony in NZ, Rockie Yarwood, johncrow and 10 others 13 Link to comment Share on other sites More sharing options...
aircommando130 Posted December 2, 2020 Share Posted December 2, 2020 That's awesome! The F-4G Wild Weasel was a badass bird. One of my pilots at Kadena was a former G model pilot. Unfortunately...your drone will end up on the wrong end of a F-22 kill out over the Gulf or in the desert at White Sands Missile Range..... Cheers....Ron Anthony in NZ and Shawn M 2 Link to comment Share on other sites More sharing options...
Shawn M Posted December 2, 2020 Author Share Posted December 2, 2020 Thanks Ron! Its a sad fate for such a great bird, but at least they went out with a bang! lol Link to comment Share on other sites More sharing options...
Shawn M Posted December 2, 2020 Author Share Posted December 2, 2020 Starting with a German SC500 bomb half from my spares I set about creating the dorsal fairing found on the QF4E/Gs. It was the right length and general plan form, so after some liberal sanding and filing I glued it on. Once on it was apparent that it was WAY to tall so I lobbed half of it off and capped it with some sheet. I also got around to adding an antenna on the fin cap with its mounting "band". Brett M, Piero, Starfighter and 8 others 11 Link to comment Share on other sites More sharing options...
aircommando130 Posted December 2, 2020 Share Posted December 2, 2020 That's super cool! Gonna be awesome with the old gray faded paint from the desert at DM with the orange wingtips and tail. Cheers...Ron Link to comment Share on other sites More sharing options...
Shawn M Posted December 2, 2020 Author Share Posted December 2, 2020 yes! plus the kit has the markings for the bird Im modelling, saves a LOT of time. While the kit assembles into manageable sub-assemblies, positive locations for these assemblies are lacking especially after removing so much for the resin bits. I added some resin stub blocks to help locate and provide a stronger glue joint for the nose to wing/fuse joint. I've also been adding tabs along major seams to provide more gluing surface and strength. scvrobeson, Marcel111, Derek B and 8 others 11 Link to comment Share on other sites More sharing options...
Marcel111 Posted December 3, 2020 Share Posted December 3, 2020 Great to see you tackling the G! Marcel Shawn M and Anthony in NZ 2 Link to comment Share on other sites More sharing options...
Shawn M Posted December 4, 2020 Author Share Posted December 4, 2020 ty Marcel! Im in the not so exciting process of sanding out the seams now in prep to mate the wings to the rear fuse half. I'll get some more pics up when there is something worth looking at lol Marcel111 1 Link to comment Share on other sites More sharing options...
Shawn M Posted December 17, 2020 Author Share Posted December 17, 2020 wo whooo progress! Rear fuse to wings joined, filled and sanded Nav lights added Cockpit painted up to get stuffed into the fwd fuse, only 1 seat to paint! panels seat Landrotten Highlander, LSP_Kevin, Derek B and 6 others 9 Link to comment Share on other sites More sharing options...
