red Dog Posted December 14, 2020 Author Share Posted December 14, 2020 Getting near the end now that the windscreen issue is under control. The seat, pilot and Ip were glued in place, the inner framing painted black after the main frame received the two rear view mirrors and the centre handle. The canopy and windscreen were finally glued in place. A bit of sanding was required at the aft side of the canopy and a strip of self adhesive aluminium was taped at the front. With the windscreen issue under control, many details were added throughout the airframe: canards were glued in place, pitot and various antenna were added, the two parts engine nozzle was painted and weathered and inserted in the rear fuselage before the whole model received it's last coat of semi gloss. Next thing was assembling the gears. I wanted to have the gear in transit retracting during take-off. So I spend quite a bit of time studying the retraction sequence. The nose gear is usually the first in the well after the side door opens. The main gear are much slower as they first need to be pulled forward to be in line with the retraction axis inside the well. That's the exact moment I chose to set the gears: nose gear almost in and mains just pulled forward before they retract inboard. With the gear done, the stores were glued in place. 5th generation precision weapons on an airframe dating back to the late sixties. It was really the spark that kept me going on this difficult conversion. And it is now completed: The base is from Coastal kits. They had a great service to me as they initially sent the wrong order but were prompt to resend the correct one. The stand is a 4mm metal rod inserted just in front of the engine nozzle and going through all the inner fuselage to provide stability. The end result is not perfect and has its flaws but I'm happy with the final model which mix old and new on a very dynamic scene. I'll post more pictures in the Ready for inspection forum soon. Thank you all for following this one, it was a great venture and I'm convinced that the support of this forum has something to do with the completion of the model phantomdriver, Piero, blackbetty and 15 others 18 Link to comment Share on other sites More sharing options...
easixpedro Posted December 14, 2020 Share Posted December 14, 2020 Love it, brilliantly executed! Always love a dynamic scene and your skills look mighty impressive with that base to make everything pop! -Peter red Dog 1 Link to comment Share on other sites More sharing options...
Stokey Pete Posted December 14, 2020 Share Posted December 14, 2020 That is seriously nice. The lines of that particular type are rather attractive. I doff a virtual cap to you sir. red Dog 1 Link to comment Share on other sites More sharing options...
Grunticus Posted December 14, 2020 Share Posted December 14, 2020 Very very nice! Great, dynamic scene, great idea and greatly executed. Well done sir! red Dog 1 Link to comment Share on other sites More sharing options...
jenshb Posted December 14, 2020 Share Posted December 14, 2020 Excellent presentation, and a very convincing impression of speed. red Dog 1 Link to comment Share on other sites More sharing options...
Starfighter Posted December 15, 2020 Share Posted December 15, 2020 Beautiful as usual, Olivier - and the presentation is stunning again. You have a great feeling for dynamic displays! red Dog and thierry laurent 2 Link to comment Share on other sites More sharing options...
Cheetah11 Posted December 15, 2020 Share Posted December 15, 2020 Magnificent build Olivier. I think few realize all the effort needed to do this build from an old Revell kit. Well done red Dog 1 Link to comment Share on other sites More sharing options...
red Dog Posted December 15, 2020 Author Share Posted December 15, 2020 (edited) On 12/14/2020 at 5:34 PM, easixpedro said: Love it, brilliantly executed! Always love a dynamic scene and your skills look mighty impressive with that base to make everything pop! -Peter Thank you Peter, coming from you and your splendid build scenes, it is quite a compliment 23 hours ago, Stokey Pete said: That is seriously nice. The lines of that particular type are rather attractive. I doff a virtual cap to you sir. and I salute you in return Stokey Pete 22 hours ago, Grunticus said: Very very nice! Great, dynamic scene, great idea and greatly executed. Well done sir! Thank you Grunticus 22 hours ago, jenshb said: Excellent presentation, and a very convincing impression of speed. Many thanks for your help about the canopy, you were quite right. 8 hours ago, Starfighter said: Beautiful as usual, Olivier - and the presentation is stunning again. You have a great feeling for dynamic displays! You have been of a great support Ben. Thank you. Too bad we can't have our model on the show tables this year. Although I'm pretty sure what the outcome will be 7 hours ago, Cheetah11 said: Magnificent build Olivier. I think few realize all the effort needed to do this build from an old Revell kit. Well done Nick, this build is dedicated to you. Without your resin nose it would have NEVER happened and I took a lot of pleasure building this one So thank you very much. More completed models pictures posted in the RFI form. Edited December 15, 2020 by red Dog Cheetah11, Out2gtcha, Greg W and 1 other 4 Link to comment Share on other sites More sharing options...
Starfighter Posted December 16, 2020 Share Posted December 16, 2020 I hope we can do that in 2021... Out2gtcha 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted December 16, 2020 Share Posted December 16, 2020 I posted in the RFI I believe, but this deserves another round of applause! Really well done, and the feeling of motion/action in the finished product is sensational. red Dog 1 Link to comment Share on other sites More sharing options...
