Lothar Posted August 11, 2019 Share Posted August 11, 2019 Outstanding build so far, the finished model will be a stunner for sure!! Lothar Rick K 1 Link to comment Share on other sites More sharing options...
Guest Vincent Posted August 12, 2019 Share Posted August 12, 2019 Quite impressive work on the gunsight ! Link to comment Share on other sites More sharing options...
Rick K Posted August 12, 2019 Author Share Posted August 12, 2019 One of my favorites...masking. Cockpit, radiator opening and wheel wells get the tape, liquid mask and sponge treatment. Will prime with Gunze 1500 Black. MikeC, Lothar and LSP_Kevin 3 Link to comment Share on other sites More sharing options...
Rick K Posted August 12, 2019 Author Share Posted August 12, 2019 All national markings, ID bands will be painted. Using Maketar masks the 4 color roundel application begin. A base of MRP135 Insignia White is applied for roundels, fin flash and ID bands. I'm applying markings using this method as I want to keep paint build up to minimum. MRP122 RAF Marking Yellow is applied. This late war aircraft, flown by New Zealand ace Evan Mackie, will have C1 roundels in all 6 positions. After yellow cures masks are carefully positioned. MRP183 Oxford Blue is applied. I spend much time deliberating on the correct "blue" for late war RAF a/c. I took the FICE approach and I'm pleased with my decision. The blue has cured and more masks carefully placed. I applied liquid mask on all tape seams to insure no bleeding. MRP123 RAF Marking Red completes the national insignias. Masks removed. No bleeds, no lifting. Win, win. The DSPIAE cutter is nothing short of pure precision. The learning curve on this instrument is very short. Once I learned the razor adjustment I've have zero issues. I am cutting roundel blanks out of mylar to protect the national markings during the camouflage painting. Careful measure and a test cut, it's good. The locator is a must as this component will allow you to make cuts with very little waste of masking material. Precision cuts with very little waste the the locator tool. Blank masks cover the roundels and fin flash. Then black primer lightly covers the white over spray. MRP118 RAF Sky used fuselage ID band. MRP122 RAF Marking Yellow applied to leading edge of wings. While I'm at it I gave the prop tips some yellow love. After ID bands are masked the wing walk is painted using MRP255 Night Camouflage. To determine the proper curve at wing root I placed aluminum foil at the wing walk area and gently burnished. The precise line at wing root is revealed. After careful measuring and using a French Curve I cut the masks out of mylar. Mylar masks for wing walk applied. dennismcc, R Palimaka, GMK and 9 others 12 Link to comment Share on other sites More sharing options...
Rick K Posted August 12, 2019 Author Share Posted August 12, 2019 On 8/11/2019 at 3:05 AM, Lothar said: Outstanding build so far, the finished model will be a stunner for sure!! Lothar I have long ways to go on this. Thanks for the kudos. 5 hours ago, Vincent said: Quite impressive work on the gunsight ! Cheers Vincent. Alain Gadbois 1 Link to comment Share on other sites More sharing options...
Rick K Posted August 12, 2019 Author Share Posted August 12, 2019 On 8/10/2019 at 6:43 PM, LSP_Kevin said: Outstanding work, Rick! Kev Cheers Kev. On 8/10/2019 at 8:44 PM, Troy Molitor said: Excellent updates Rick. I really am enjoying this build. The gunsight came out fantastic. Troy Thanks Troy. I was cross-eyed for a few days. Link to comment Share on other sites More sharing options...
Rick K Posted August 12, 2019 Author Share Posted August 12, 2019 Underside painting MRP112 Medium Sea Grey applied. I did marbling and I lost the images before I blended. After paint cure more masking fun. Alain Gadbois, MikeC, Greg W and 5 others 8 Link to comment Share on other sites More sharing options...
Troy Molitor Posted August 12, 2019 Share Posted August 12, 2019 Your bench is way to clean Rick. The updates are awesome, however. Rick K 1 Link to comment Share on other sites More sharing options...
Alain Gadbois Posted August 12, 2019 Share Posted August 12, 2019 Great work and excellent result with the masking! I was surprised you did the roundels before painting the airframe, but it should make them very flush with the adjoining camouflage paint. Alain Rick K 1 Link to comment Share on other sites More sharing options...
R Palimaka Posted August 12, 2019 Share Posted August 12, 2019 Superb work on that kit! What a beautiful aircraft, and you're doing a splendid job. Thanks also for the comparison photos of the kit nose/Barracuda nose. They make the difference in accuracy very clear and visible. Richard PS: I hate masking too!! MikeC and Rick K 2 Link to comment Share on other sites More sharing options...
Rick K Posted August 12, 2019 Author Share Posted August 12, 2019 7 hours ago, Troy Molitor said: Your bench is way to clean Rick. The updates are awesome, however. Oh, I just cleared a hole in the mmiddle of my bench. Thanks Troy. 6 hours ago, Alain Gadbois said: Great work and excellent result with the masking! I was surprised you did the roundels before painting the airframe, but it should make them very flush with the adjoining camouflage paint. Alain Thanks Alain - That is the plan. Stay tuned. 5 hours ago, R Palimaka said: Superb work on that kit! What a beautiful aircraft, and you're doing a splendid job. Thanks also for the comparison photos of the kit nose/Barracuda nose. They make the difference in accuracy very clear and visible. Richard PS: I hate masking too!! Cheers Richard. Masking and sales reports are very closely matched on my Loathe Meter. R Palimaka 1 Link to comment Share on other sites More sharing options...
Rick K Posted August 12, 2019 Author Share Posted August 12, 2019 More masking. Did I mention how much I do not like masking? Undersides get the full mask treatment. Out2gtcha, Alain Gadbois, Hartmann52 and 7 others 10 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted August 13, 2019 Share Posted August 13, 2019 Excellent masking and painting, Rick! Kev Rick K 1 Link to comment Share on other sites More sharing options...
MikeC Posted August 13, 2019 Share Posted August 13, 2019 "A thing divine, for nothing natural I ever saw so noble." (Miranda, Act I, Scene 2, guess which Shakespeare play) There is some brilliant work here, really looking forward to seeing the finished article. Rick K 1 Link to comment Share on other sites More sharing options...
Rick K Posted August 13, 2019 Author Share Posted August 13, 2019 10 hours ago, LSP_Kevin said: Excellent masking and painting, Rick! Kev Cheers Kev 7 hours ago, MikeC said: "A thing divine, for nothing natural I ever saw so noble." (Miranda, Act I, Scene 2, guess which Shakespeare play) There is some brilliant work here, really looking forward to seeing the finished article. Lovely play on words. Link to comment Share on other sites More sharing options...
