Dandiego Posted August 22, 2018 Share Posted August 22, 2018 (edited) Hey I am back. After 30 plus years of building only US aircraft I have decided to go rogue. I recently acquired, from a fellow LSPer, the older Revell F-15 D/E. I built this kit when it first came out way back...when? I remember the landing gear was quite fragile, glad it comes with metal gear. Here you can see what was in the box. The complete kit, resin exhaust nozzles,resin wheels, metal landing gear and extra decals. The extra decals I swapped for the Japanese Aggressor decals and for only $55 (shipping included) I have this gem. Why so low? Because the wings and fuselage were already glued together. Also the CFT's were already glued on, I popped them off as soon as I opened the box. And my references. Progress pics to follow. Dan Edited August 26, 2018 by Dandiego Out2gtcha, MikeMaben, Kagemusha and 4 others 7 Link to comment Share on other sites More sharing options...
Kagemusha Posted August 22, 2018 Share Posted August 22, 2018 Great project Dan, the Model Art book on JASDF F-15's is superb, though it's oop, but you might be able to find a reasonably priced one. Parts r parts make suitable (-ish?) front and rear DJ ip's. Dandiego 1 Link to comment Share on other sites More sharing options...
DonH Posted August 22, 2018 Share Posted August 22, 2018 Welcome back, and you are straight in at the deep end! Dandiego 1 Link to comment Share on other sites More sharing options...
Greg W Posted August 23, 2018 Share Posted August 23, 2018 Great choice for the paint scheme. JASDF colors are very attractive. This is a follow! Dandiego 1 Link to comment Share on other sites More sharing options...
Bill_S Posted August 23, 2018 Share Posted August 23, 2018 Looks like a great project, but beware of those metal legs. They appear to be SAC, and I personally would opt for styrene parts over soft metal. Dandiego 1 Link to comment Share on other sites More sharing options...
Dandiego Posted August 24, 2018 Author Share Posted August 24, 2018 23 hours ago, Bill_S said: Looks like a great project, but beware of those metal legs. They appear to be SAC, and I personally would opt for styrene parts over soft metal. Bill, the metal gear is quite soft, I am not sure if I will use them or not. Dan Link to comment Share on other sites More sharing options...
Dandiego Posted August 24, 2018 Author Share Posted August 24, 2018 (edited) Why the Revell kit when the Tamiya offering is obviously better? It really comes down to a super price on a decent kit. Plus I have spent the better part of the last 2 years on some really intense projects. I wanted something relatively easy and quick to assemble. This kit has good overall shape and allows me to improve it and make it mine. This appeals to me. Also I recently aquired my first new airbrush in 30 years and I wanted a challenging paint scheme to put the new airbrush through the wringer. What paint scheme you ask? Well haven't settled on one yet but it will be something colorful. This kit has engraved panel lines but no rivets, looks almost naked. So I will be adding about six thousand rivets, give or take a few hundred. Pics to follow Dan Edited August 26, 2018 by Dandiego MARU5137 and D.B. Andrus 2 Link to comment Share on other sites More sharing options...
Dandiego Posted August 25, 2018 Author Share Posted August 25, 2018 (edited) Work has begun. The kit seats need to be replaced. I ordered 2 quickboost seats. Great detail but they are too small, they really look lost in the kit cockpit. So I split one of the seats in half and inserted a spacer to make the seat look bigger. The other to follow. I didn't take any photos before sealing up the nose section. However here is what it looks like glued together and installed. Only real changes are a little side wall detail and necessary changes to the rear IP. Next is adding some depth the exhaust cones. What you are seeing is the kit flameholders at the end of a cardboard exhaust tube. Next are some drains on the bottom of the rear fuselage and you can see some of the 6000 rivets that I am adding. The drains will be sanded down to the correct height later. Rudders have been offset. Wing plates have been added. Ailerons have been cut out and will be re-attached in the normal drooped configuration. Static discharers added to the nose cone. These are just fine fishing line super glued in place. Later, Dan Edited August 26, 2018 by Dandiego LSP_Kevin, Out2gtcha, MARU5137 and 3 others 6 Link to comment Share on other sites More sharing options...
Dandiego Posted August 26, 2018 Author Share Posted August 26, 2018 On 8/21/2018 at 11:29 PM, DonH said: Welcome back, and you are straight in at the deep end! Don't consider this the deep end. More of a relaxing build with an intense paint scheme. Looking forward to the challenge of masking and painting this puppy. Dan Link to comment Share on other sites More sharing options...
dmthamade Posted August 26, 2018 Share Posted August 26, 2018 Looking forward to the build, I did a JASDF Aggressor with this kit recently, enjoyed the kit. Relatively straightforward build, the masking and painting took up most of the time. As Kagemusha said, the Model Art book is a great reference for F-15 Aggressors. Use the metal gear for the nose!!!! The kit plastic part will not support the build and will break!! The kit mains are OK but not the nose gear. Paint schemes could be relatively tame to wildly colorful, colorful is nice. I did 92-8095, strange color combos on that one. Fishing line on the radome...what a great idea!! Don Daniel Leduc and Dandiego 1 1 Link to comment Share on other sites More sharing options...
Dandiego Posted August 26, 2018 Author Share Posted August 26, 2018 Don I would love to see your finished build. Dan dmthamade 1 Link to comment Share on other sites More sharing options...
Daniel Leduc Posted August 27, 2018 Share Posted August 27, 2018 Hey Dan, Wich one are planning on..? Dan. Link to comment Share on other sites More sharing options...
dmthamade Posted August 27, 2018 Share Posted August 27, 2018 On 8/26/2018 at 1:24 AM, Dandiego said: Don I would love to see your finished build. Dan Don alain11, Out2gtcha, Dandiego and 4 others 6 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted August 27, 2018 Share Posted August 27, 2018 Great work Dan. At least with this one it will be WAY more relaxing that trying to pull a full scratch build from thin air! Good start, and a cool bit for the static dischargers too. Dandiego 1 Link to comment Share on other sites More sharing options...
Dandiego Posted August 27, 2018 Author Share Posted August 27, 2018 Don, Excellent work. Love the paint work. Thanks for sharing. Where did you get the wing tanks? Dan Link to comment Share on other sites More sharing options...
