DerekB Posted February 10, 2017 Share Posted February 10, 2017 (edited) Hi everyone, a newbie on the forums here, returning to modelling after a 30-year break. My chosen project is the CAC Wirraway (haven't decided which Mark yet), converted from the Kitty Hawk T-6 Texan kit. Two of these arrived last week, along with a few accessories still coming from overseas. The Kitty Hawk T-6 Texan kit is an impressive piece of work, and there will be many usable parts for a Wirraway conversion. When this kit came out several years back, Peter Malone wondered who would be the first to convert it to a Wirraway, and maybe this will be the first, as I haven't seen any others yet. Peter suggested the following: Let's see now:New, shorter fuselage.New interior details with space frame, observers cockpit and equipment etcNew fin and rudder.New tailplane.New outer wing panels.New engine and cowling.New prop.That leaves wing centre section, U/C, and canopy from original kit. Not sure if the latter can be used without modification either.[/size] I think his assessment is pretty close to the mark, but I'll be working on converting a lot of the parts, rather than needing new parts as listed by Peter. I'm also going to be trying some resin casting, so wish me luck! First, I checked if the fuselage frame was going to be re-usable, as the welded steel tube frame in a Texan is almost identical to the frame in a Wirraway. Here's how it compared to my drawings...IMG_4483 by Derek Buckmaster, on Flickr As you can see, apart from the tubes being a bit chunky, several of them are out of place, and the detail along the lower longerons is not anywhere close to reality. Plus the molded panel sections on the upper longeron look like they will be difficult to remove, so I've decided to start from scratch. Since there are two side frames which are mostly identical, I'll make up a jig, the pieces of which are shown below...IMG_4494 by Derek Buckmaster, on Flickr This is cut from 1mm styrene card, as the tubes will be made using 1mm diameter styrene rod, which matches the diameter of the 1.25" tubes in the framework. Some of the tubes are smaller (1" and 0.75") and some are larger (1.5") but I'll live with 1mm for almost all of the tubes. Edited June 18, 2018 by DerekB F`s are my favs, Rocat, KiwiZac and 7 others 10 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted February 10, 2017 Share Posted February 10, 2017 Welcome aboard, Derek! Great project, and I really look forward to following along. Great to have another Melbournian here, too! Kev mpk 1 Link to comment Share on other sites More sharing options...
MikeMaben Posted February 10, 2017 Share Posted February 10, 2017 Hi Derek, looks an interesting project. mpk 1 Link to comment Share on other sites More sharing options...
ClumsyDude Posted February 10, 2017 Share Posted February 10, 2017 Super project Derek! My great uncle was killed in a Wirraway ... so I've been building up my courage to doing a tribute build once I have the skills. Looking good so far. Cheers Jim mpk 1 Link to comment Share on other sites More sharing options...
Guyman1 Posted February 10, 2017 Share Posted February 10, 2017 This will be interesting. Guy mpk and Piprm 2 Link to comment Share on other sites More sharing options...
Lee White Posted February 10, 2017 Share Posted February 10, 2017 Very ambitious!! I'm looking forward to this!! mpk 1 Link to comment Share on other sites More sharing options...
mpk Posted February 10, 2017 Share Posted February 10, 2017 Wirraway! Step 1. Celebrate. Step 2. Follow topic. Step 3.Continue celebration while wishing the good gentleman hello and good luck. "Morituri te salutant." KiwiZac 1 Link to comment Share on other sites More sharing options...
Anthony in NZ Posted February 10, 2017 Share Posted February 10, 2017 Great project Derek! Might need to call it LSP Australia Lol......welcome aboard! mpk 1 Link to comment Share on other sites More sharing options...
mpk Posted February 10, 2017 Share Posted February 10, 2017 LSP Anzac. KiwiZac 1 Link to comment Share on other sites More sharing options...
DerekB Posted February 10, 2017 Author Share Posted February 10, 2017 (edited) Working my way through the parts in the kit, to see what is usable. The wheels are good! In fact the 8-spoke wheels in the kit are perfect for a Wirraway, although the number of spokes will be academic once they are covered over. When Wirraways were in service with the RAAF they always wore wheel covers, fairing over the spokes and reducing the drag of the retracted wheels just a little. They were also fitted with drum brakes. Most people may not realise there were 8-spoke wheels under these covers, and that all the restored Wirraways restored to airworthy condition are fitted with 10-spoke Mustang wheels fitted with disc brakes. Here are the wheels in the kit (inboard half on the left, outboard half on the right): IMG_4489 by Derek Buckmaster, on Flickr Here is the outboard side of a full-size wheel, with its fairing cover in place (A20-10 at Moorabbin, prior to its restoration in 2014): P1010834 by Derek Buckmaster, on Flickr And here is the inboard side of a full-size wheel, with the brake drum cover in place: P1020027 by Derek Buckmaster, on Flickr With the fairing cover removed from the outboard side, you can see the 8 spokes (A20-10 being collected from CAC in 1964, a crop from a Neil Follett photo): A20-010 p1171-0030-071 1964-06-05 Moorabbin AARG (Follett) crop by Derek Buckmaster, on Flickr And finally, a pair of "imposter" 10-spoke Mustang wheels on a Wirraway restored to flying condition (but no longer flown, A20-652 at Queensland Air Museum in Caloundra): P1010887crop by Derek Buckmaster, on Flickr Mustang wheels were also fitted to the CAC Ceres in production, and since they are easily available and the disc brakes work better than the original drum brakes, its understandable that restorers went this way... Edited June 18, 2018 by DerekB mpk, sandokan and Lars Befring 3 Link to comment Share on other sites More sharing options...
EagleAviation Posted February 10, 2017 Share Posted February 10, 2017 That is great subject Derek. Good luck on this one. Will follow mpk 1 Link to comment Share on other sites More sharing options...
Piprm Posted February 10, 2017 Share Posted February 10, 2017 (edited) Welcome Derek, Yes, the fuselage is totally different as are the outer wings, which will be the difficult parts to redesign... but apart from an all - new fuselage, the other challenging bit will be the canopy - which is totally different. I think you'll be remastering these. Adjusting existing parts will require major surgery - close to butchery! Will be following! Phil Edited February 11, 2017 by Piprm mpk 1 Link to comment Share on other sites More sharing options...
Shawn M Posted February 10, 2017 Share Posted February 10, 2017 another cool project! mpk 1 Link to comment Share on other sites More sharing options...
DerekB Posted February 11, 2017 Author Share Posted February 11, 2017 Super project Derek! My great uncle was killed in a Wirraway ... so I've been building up my courage to doing a tribute build once I have the skills. Looking good so far. Cheers Jim What was your great uncle's name Jim? mpk 1 Link to comment Share on other sites More sharing options...
ClumsyDude Posted February 11, 2017 Share Posted February 11, 2017 Tom Power. Don't know what the markings on that Wirraway were - at some point I'm going to do the research. Jim mpk 1 Link to comment Share on other sites More sharing options...
