Guest Posted January 7, 2017 Share Posted January 7, 2017 Looks splendid, although it's probably a good thing that I picked up the Revell kit at such a bargain price, given what it's likely to cost. Still, it would take me ages to Luckily those parts and get them satisfactory. Luckily I have two !!........Harv Link to comment Share on other sites More sharing options...
wunwinglow Posted January 9, 2017 Author Share Posted January 9, 2017 (edited) A bit more work, the fuel tank mouldings back filled with polycell foam, and a bit more assembly on th fuselage.... Edited January 9, 2017 by wunwinglow mark31, F`s are my favs, Daniel Leduc and 4 others 7 Link to comment Share on other sites More sharing options...
mark31 Posted January 9, 2017 Share Posted January 9, 2017 Looks good for me To where i have to send my money i take one set and a extra set of two intakes Looking forward to see more Mark Link to comment Share on other sites More sharing options...
wunwinglow Posted January 9, 2017 Author Share Posted January 9, 2017 Hi Mark, I'll let you know when it is ready! I still have a lot to sort out, but I am making progress now! Thanks for the vote of confidence! Tim Link to comment Share on other sites More sharing options...
reconspit Posted January 9, 2017 Share Posted January 9, 2017 ...any way to order the parts? :-D Link to comment Share on other sites More sharing options...
Guest Posted January 9, 2017 Share Posted January 9, 2017 Ok Tim, take your time....but hurry up !.......Harv Link to comment Share on other sites More sharing options...
Michael931080 Posted January 9, 2017 Share Posted January 9, 2017 (edited) I was just thinking about this and what happened to the conversion parts the other day. So glad to see they are progressing nicely!! Edited January 9, 2017 by Michael931080 Link to comment Share on other sites More sharing options...
ollieholmes Posted January 10, 2017 Share Posted January 10, 2017 Im glad to see some progress here. Im still interested in two sets. Link to comment Share on other sites More sharing options...
wunwinglow Posted January 10, 2017 Author Share Posted January 10, 2017 And a bit more. Here, the new wing spar and wings are epoxied into place in the fuselage top. The spar is solid so the wings do need a slot sawing in them from the pivot points, so no moving wings, but it does make the assembly completely rigid. Otherwise, it flops about all over the place!! I filled the vacformed fuel tanks with Polycell foam, and when it had set I sawwed away the surplus so they are now ready for sanding down to final size. dutik, Lothar, NavyF4s and 1 other 4 Link to comment Share on other sites More sharing options...
brahman104 Posted January 10, 2017 Share Posted January 10, 2017 Hi Tim, I haven't exactly been following this build along but I see some mighty fine printed parts in there, so I think I'm going to go back to the start and work my way back through what you've done here. Looking sharp! Craig Link to comment Share on other sites More sharing options...
Breaker Posted January 10, 2017 Share Posted January 10, 2017 AH, on my own GR1 build I was wondering about the sloppy wing fit, I'll have to follow your way of doing it! Link to comment Share on other sites More sharing options...
wunwinglow Posted January 10, 2017 Author Share Posted January 10, 2017 (edited) I'll hopefully be able to sell the parts individually, so if you just want a wing spar, no problem. I just want to make sure it does all actually go together reasonably before I start casting them... Notice, I put a load of extra tabs across the joint between the rear top and bottom fuselage areas, interlocking tabs on both sides, and this also greatly helps keep it all lined up. Edited January 10, 2017 by wunwinglow Lothar and Tony C 2 Link to comment Share on other sites More sharing options...
wunwinglow Posted January 10, 2017 Author Share Posted January 10, 2017 Er, I hadn't realised all the Facebook pics would disappear!! I'll try and replace them..... Sorry about that! Tim KiwiZac 1 Link to comment Share on other sites More sharing options...
Michael931080 Posted January 24, 2017 Share Posted January 24, 2017 Hi Tim any updates on the parts and progress of late? Link to comment Share on other sites More sharing options...
wunwinglow Posted January 24, 2017 Author Share Posted January 24, 2017 Sorry, no, last couple of weekends taken up mostly with family stuff, a trip to RAF Hendon, fitting an electric fireplace in the lounge, and at last, the 3D probe and tool length sensor arrived for the CNC machine, so I have been fitting them and getting my head around the software. I need to win the lottery or something, then I might have a bit more time available!! More soon, promise! Link to comment Share on other sites More sharing options...
