TimW Posted July 20, 2013 Share Posted July 20, 2013 That is a work of art. I am speechless!! Tim W. Link to comment Share on other sites More sharing options...
fiedotow Posted July 24, 2013 Share Posted July 24, 2013 Tomku! Bravissimo! Niesamowita praca Link to comment Share on other sites More sharing options...
tomaszhajzler Posted July 26, 2013 Author Share Posted July 26, 2013 (edited) Welcome! You are all very kind. Your opinion are very motivated. I'd like to describe how i made this strange, long tube. This is arrester hook control cable drive. I rolled thin aluminium foil in tube. I put inside smooth part of drill the same diametr to make cut-out along the tube. I glued thin self adhesive foil outside the tube. On the end i put transparent stick inside to reinforce construction. Remember to paint the tube first, than put inside stick. I added some small details and that's all. Of course, I made this detail in second attempt, first one in my opinion was to thick, about 0,15 mm in diameter. Regards, Tomasz Edited July 26, 2013 by tomaszhajzler Rdrunner and sandokan 2 Link to comment Share on other sites More sharing options...
Derek B Posted July 27, 2013 Share Posted July 27, 2013 Fantastic work Tomaz - I am extremely impressed, especially your seat, which looks very like a Curtiss P-40 seat! Derek Link to comment Share on other sites More sharing options...
LSP_Ron Posted July 27, 2013 Share Posted July 27, 2013 There is some amazing detail! very well done Link to comment Share on other sites More sharing options...
Rick K Posted July 28, 2013 Share Posted July 28, 2013 wow! really nice job on this. Link to comment Share on other sites More sharing options...
Thomas Lund Posted July 28, 2013 Share Posted July 28, 2013 FIrst class work - I'm very impressed Link to comment Share on other sites More sharing options...
LSP_Mike Posted July 28, 2013 Share Posted July 28, 2013 This will certainly be an inspiration for all who own this kit. Clear-cut explanations are very much appreciated also, as is the photography. Link to comment Share on other sites More sharing options...
tomaszhajzler Posted July 28, 2013 Author Share Posted July 28, 2013 Hi everybody! Thank you for such hot comments. I'm glad that my project could be inspiration for someone. Fantastic work Tomaz - I am extremely impressed, especially your seat, which looks very like a Curtiss P-40 seat! Derek Yes, you are right. I couldn't find picture of all pilot seat, only small fragments. One of them compared to P 40 or P 38 seat. I chose last of them. I took one from Trumpeter kit and made test fitting. Dimensions were OK. So i used it as a master. All detailes were made according photos. I closed fuselage on the end of 2012. Good summary of the year. Regards, Tomasz. sandokan, Rdrunner and Lars Befring 3 Link to comment Share on other sites More sharing options...
tomaszhajzler Posted July 30, 2013 Author Share Posted July 30, 2013 Hi! After closing fuselage i added some details. Pylon under instrument panel was first. Shelf of amunition boxes was next Tomasz Rdrunner and sandokan 2 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted July 30, 2013 Share Posted July 30, 2013 Amazing work Tomasz. A masterclass! Kev Link to comment Share on other sites More sharing options...
Hubert Boillot Posted July 31, 2013 Share Posted July 31, 2013 Excellent ! Hubert Link to comment Share on other sites More sharing options...
tomaszhajzler Posted August 3, 2013 Author Share Posted August 3, 2013 (edited) Hi everybody after break! I decided to close front part of the cockpit making cockpit bulkead. Next step- to creat new skin. I started from the cockpit. You can see closed upper part of fuselage just behind the cockpit on two last photos. I made double skin, the inner one the same way as bottom earlier to creat frames and rivets inside of the fuselage. Tomasz Edited August 3, 2013 by tomaszhajzler sandokan, Rdrunner and red baron 3 Link to comment Share on other sites More sharing options...
Thomas Lund Posted August 3, 2013 Share Posted August 3, 2013 I'm speachless... Link to comment Share on other sites More sharing options...
tomaszhajzler Posted August 3, 2013 Author Share Posted August 3, 2013 and fast as a lightning!!! Thanks Thomas. Link to comment Share on other sites More sharing options...
