LSP_Kevin Posted December 1, 2017 Author Share Posted December 1, 2017 Kev, Check out http://forum.largescaleplanes.com/index.php?showtopic=50722 for help in parts alignment. Pascal nailed this engine and I'd use it as a "example" of where the parts should fit any day of the week. The small object at the front of the gearbox is the prop governor, and it mounts to the small "square shaped pad" cast on the gearbox. The bigger "box" is the magneto and goes between the new distributer covers you bought and is set behind the smaller part and towards the back of the gearbox, with the back edge of the part just about to the cylinders. This may help a bit too. http://www.connecticutscorsair.com/pages/r-2800_overhaul_manual_illustrations.htm Paul Thanks, Paul. I know where the parts go, but am confused about why I seem to have a ring-in part, and that the prop governor and magneto don't fit together on the Quickboost engine. And the Quickboost instructions don't really help with the orientation of the prop governor - it's longer in one direction, not square. So I'm not sure if the long side goes front-to-rear, or side-to-side; if the former, then the magneto won't fit behind it, yet the latter orientation appears to be incorrect, from what I can gather. In fact, the parts Pascal used look different again from the ones I have here - the prop governor is square rather than rectangular, and the magneto seems boxier too. Kudos to him for a magnificent engine, however! Kev LSP_Paul 1 Link to comment Share on other sites More sharing options...
LSP_Ron Posted December 1, 2017 Share Posted December 1, 2017 I think that's the heaviest weathering you've done yet and it looks great. Ron LSP_Kevin 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted December 1, 2017 Author Share Posted December 1, 2017 Actually, here's a question: does the magneto part fit to the engine from the lower part in the photo (with the cocktail stick attached), or the top part? Photos suggest the lower part, but if I do it the other way around, the two parts fit together better. However, there's no detail at all on that lower section, which would then be exposed (although probably hardly visible for practical purposes). Kev Link to comment Share on other sites More sharing options...
LSP_Paul Posted December 1, 2017 Share Posted December 1, 2017 Prop governor not fitted, showing orientation of magneto. the prop governor goes on the pad in front and if it has a small "wheel" shaped object as part of the casting on one side, that would mount to the left side from the pilot's perspective in the cockpit. Paul LSP_Kevin and sandokan 2 Link to comment Share on other sites More sharing options...
LSP_Paul Posted December 1, 2017 Share Posted December 1, 2017 Or this with different Distributor covers.. same set up. sandokan 1 Link to comment Share on other sites More sharing options...
Allan Peters Posted December 1, 2017 Share Posted December 1, 2017 (edited) This is from my Quickboost set. The details on the sides seem different than yours. The magneto on the far right is right side up, the square pad on the bottom matches up to the corresponding square on the gear case. I wouldn't worry about the orientation of the prop governor on the front, it doesn't look like any of the photos I have seen. The magneto should be mounted lengthwise front to back. Strange it's so hard to find a photo of an engine with the prop gov installed. An assembly line pic I have shows it with the disc Paul mentioned mounted to the front, I'd guess approximately 2" in diameter... but it won't make or break your engine. I hope this helps. Allan Edited December 1, 2017 by monkeysee MikeMaben, LSP_Paul, sandokan and 1 other 4 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted December 1, 2017 Author Share Posted December 1, 2017 Thanks, fellas. I've seen those photos before, but most of the real magnetos don't resemble the part I have, which is definitely different to what should be in the Quickboost set, and I have no idea of its provenance. Incidentally, I just took a look at the Quickboost engine I bought for the P-47 (32 038), and it looks identical to this one (32 036). A bit of creative marketing, perhaps? In any case, I think I can see away forward now, accurate or not, so it's onward toward the finish line from here. Kev LSP_Paul and dennismcc 2 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted December 2, 2017 Author Share Posted December 2, 2017 OK fellas, I pushed through and completed the engine today: Not the best photo, unfortunately. Since it's going to be enclosed in the cowling, I didn't go overboard with the wiring, or painting and detailing areas that won't really be seen. I didn't have a P&W logo decal, so I tried my hand at painting one. It's just 2 blue blobs and a brown blob, but I think it suggests the real thing convincingly enough. Here's another angle: The data plate on the gearbox housing is from one of airscale's generic cockpit placard sets - again, used more for effect than accuracy. Anyway, next stop: installation! Kev Daniel460, Allan Peters, Sparzanza and 6 others 9 Link to comment Share on other sites More sharing options...
TorbenD Posted December 2, 2017 Share Posted December 2, 2017 Very tidy Kev Torben LSP_Kevin 1 Link to comment Share on other sites More sharing options...
monthebiff Posted December 2, 2017 Share Posted December 2, 2017 Very nice Kev, all coming together really nicely isnt it!! Regards. Andy LSP_Kevin 1 Link to comment Share on other sites More sharing options...
tchwrma Posted December 2, 2017 Share Posted December 2, 2017 OK fellas, I pushed through and completed the engine today: Not the best photo, unfortunately. Since it's going to be enclosed in the cowling, I didn't go overboard with the wiring, or painting and detailing areas that won't really be seen. I didn't have a P&W logo decal, so I tried my hand at painting one. It's just 2 blue blobs and a brown blob, but I think it suggests the real thing convincingly enough. Here's another angle: The data plate on the gearbox housing is from one of airscale's generic cockpit placard sets - again, used more for effect than accuracy. Anyway, next stop: installation! Kev This engine is absolutely perfect! Congratulations! Paulo. LSP_Kevin 1 Link to comment Share on other sites More sharing options...
Gazzas Posted December 2, 2017 Share Posted December 2, 2017 Engine looks great! I like detailing radials even if 90% of the engine will be hidden. Gaz LSP_Kevin 1 Link to comment Share on other sites More sharing options...
LSP_Paul Posted December 2, 2017 Share Posted December 2, 2017 The R-2800 came out well Kev. Great Job Paul LSP_Kevin 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted December 2, 2017 Author Share Posted December 2, 2017 Thanks, fellas. While not perfect or perfectly accurate, I think the engine came out quite well, and looks effective in place - photos soon! Kev Link to comment Share on other sites More sharing options...
Out2gtcha Posted December 2, 2017 Share Posted December 2, 2017 Gone for a day, and this engine got deep. I think it looks great! Overall, the weathering is effective looking and very "likable" if thatvmales sense. LSP_Kevin 1 Link to comment Share on other sites More sharing options...
