pg265 Posted May 26, 2014 Share Posted May 26, 2014 (edited) Hi, I recently started to work on the Pratt and Whitney R-2800 resin kit from Brassin, to add details to the 1/32 Tam Corsair. Parts cut from the resin sprue. Some parts: Original spark plugs are not bad, but... details can be added. New connector. Cylinders head drilled to receive a "real" tube instead of the PE one of the Barssin kit. The box of the lower cylinder is also drilled to be connected to the reductor and the back of the engine. Pascal Edited July 18, 2014 by pg265 D.B. Andrus, Girlscanplay2, lawman56 and 2 others 5 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted May 26, 2014 Share Posted May 26, 2014 Pascal Nice work on the added details Keep 'em coming Peter Link to comment Share on other sites More sharing options...
pg265 Posted May 26, 2014 Author Share Posted May 26, 2014 Me again! Test fit: Early Bendix electrical harness from Barracuda Next step: Paint. So time to mask... Late magnetos are cut off and will be replaced by the Early ones provided by Barracuda: Pascal Sharkmouth and Girlscanplay2 2 Link to comment Share on other sites More sharing options...
pg265 Posted May 26, 2014 Author Share Posted May 26, 2014 Again and again... More mask: ZP primer and black before Alclad, from ZP once again: Short dry time, then grey from Gunze: 307 & 337 with Tamiya thinner. Alclad White Alu for the cylinders. Pascal Tomek, Sharkmouth and Girlscanplay2 3 Link to comment Share on other sites More sharing options...
pg265 Posted May 26, 2014 Author Share Posted May 26, 2014 Guess who?... Black again. Welcome to the Smurfs: Le masque est retiré du bloc: Pascal Sharkmouth and Girlscanplay2 2 Link to comment Share on other sites More sharing options...
pg265 Posted May 26, 2014 Author Share Posted May 26, 2014 Black here too: Pchiiit... Mask off and light first weathering steps. test fit: Pascal Sharkmouth, Girlscanplay2 and Mal_Belford 3 Link to comment Share on other sites More sharing options...
pg265 Posted May 26, 2014 Author Share Posted May 26, 2014 Instruction plate added First row: Test fit again with front end: Bendix magnetos: Time for primer! Grey Micro Filler on few parts. Cylinders: I love the details: Pascal Girlscanplay2, Tomek, Harold and 1 other 4 Link to comment Share on other sites More sharing options...
pg265 Posted May 26, 2014 Author Share Posted May 26, 2014 Other engine parts and cowls: After the grey... BLACK! Gloss Black Base from Alclad. "Engine Manifold" from Alclad. Pascal Girlscanplay2 and Sharkmouth 2 Link to comment Share on other sites More sharing options...
pg265 Posted May 26, 2014 Author Share Posted May 26, 2014 Test fitting for the push rods and spark plugs in place. Well , this is my interpretation of the Monster... I hope you like it. More to come soon. Pascal Girlscanplay2 and Sharkmouth 2 Link to comment Share on other sites More sharing options...
petrov27 Posted May 26, 2014 Share Posted May 26, 2014 amazing work there! Link to comment Share on other sites More sharing options...
shepard Posted May 26, 2014 Share Posted May 26, 2014 hi Pascal, greetings from Brazil! what liquid mask did you use? fantastic job on it shep Link to comment Share on other sites More sharing options...
Guest Posted May 26, 2014 Share Posted May 26, 2014 Dam Pascal ! Great work ! And I love your parts stand.....Harv Link to comment Share on other sites More sharing options...
pg265 Posted May 26, 2014 Author Share Posted May 26, 2014 Thank you mates! @shepard: liquid mask is Micromask from Microscale. Pascal Link to comment Share on other sites More sharing options...
Wurzacher Posted May 26, 2014 Share Posted May 26, 2014 Pascal, this is beautiful! Enjoy watching you build this engine! Link to comment Share on other sites More sharing options...
pg265 Posted May 29, 2014 Author Share Posted May 29, 2014 Hi, Thanks for the comments. Cylinders of the first row are now complete: Time for the back crown. Alu Metal Cote quickly applied with a brush then polshed with a brush once again. Smoke and quick dry brush with "blanc de titane" and black from W&N this time. I don't spend too much time for the details and paint work on these parts as they will not be too visible. Questions and comments are welcome. Pascal Girlscanplay2 and Sharkmouth 2 Link to comment Share on other sites More sharing options...
