Jan_G Posted June 15, 2016 Share Posted June 15, 2016 Hi guys, I was planning to finish this one during upcoming weekend and post it to RFI, but will not be at my workbench sooner then on Friday. So just decided to post some WIP pictures here. This is my first WNW kit. And its really amazing. I'm working on it 4 weeks already. I went through several WNW builds to get some know how. This one is build OOB, paints are mostly based on WNW instructions for this kit. will take my time to make better pictures after it is done. thanks for looking jan Wings, elevator and rudder painted with tamiya acrylics. Already started with some scratch effects on roundel decals my first attempt in wooden finish, painted with oil (raw umbra) and fine brush.Aluminium painted with Alclad, wood and red primer effect looks darker on photo. Used brown wash for interior. Uncarina, LSP_K2, LSP_Paul and 4 others 7 Link to comment Share on other sites More sharing options...
Jan_G Posted June 15, 2016 Author Share Posted June 15, 2016 added some wires, painted with Alclad aluminium and applied dark grey wash. for the fabric I used semi gloss GSI varnish, after then I have used matt varnish for ports. At the end it makes nice difference with gentle wash. everything went together easily.... front cowl painted with alclad, rest of fuselage with tamiya acrylics...fabric and front cowl finished with semigloss varnish...wooden part with mat finish thanks for looking jan MikeC, Alburymodeler, Uncarina and 2 others 5 Link to comment Share on other sites More sharing options...
Guest Posted June 15, 2016 Share Posted June 15, 2016 WOW, VERY nice !......Harv Link to comment Share on other sites More sharing options...
Martinnfb Posted June 15, 2016 Share Posted June 15, 2016 Nice start, clean, crisp and precise work. Cheers Martin Link to comment Share on other sites More sharing options...
D.B. Andrus Posted June 15, 2016 Share Posted June 15, 2016 Just beautiful work, Jan! Cheers, D.B. Link to comment Share on other sites More sharing options...
Out2gtcha Posted June 15, 2016 Share Posted June 15, 2016 Great work. I did this exact same scheme when I built my late Snipe, and you are definitely doing it justice! It really is a great kit, just look out for the Aldis sight, its a might tricky, as the brackets are on the top wing but it has to go through the windscreen which is attachec to the fuse. Link to comment Share on other sites More sharing options...
williamj Posted June 15, 2016 Share Posted June 15, 2016 Love it..... Tamiya acrylics look real nice on the Fuselage. have to try that sometime. Link to comment Share on other sites More sharing options...
tucohoward Posted June 15, 2016 Share Posted June 15, 2016 Looks great Jan! Very nice painting inside and out. Jay Link to comment Share on other sites More sharing options...
LSP_Kevin Posted June 15, 2016 Share Posted June 15, 2016 This is fantastic, Jan! Marvellous paint work. Kev Link to comment Share on other sites More sharing options...
LSP_K2 Posted June 15, 2016 Share Posted June 15, 2016 Looking very nice indeed. Link to comment Share on other sites More sharing options...
Jeff T Posted June 16, 2016 Share Posted June 16, 2016 Excellent work Jan! That is looking very nice. Cheer's, Jeff. Link to comment Share on other sites More sharing options...
kkarlsen Posted June 16, 2016 Share Posted June 16, 2016 Very nice! Link to comment Share on other sites More sharing options...
Chek Posted June 16, 2016 Share Posted June 16, 2016 Great looking model! Turnbuckles on the interior bracing tells me you're taking this build very seriously. Just needs a hulking great HKM FGR2 beside it spanning the squadron's 50 years from 1924-74. Link to comment Share on other sites More sharing options...
Jan_G Posted June 20, 2016 Author Share Posted June 20, 2016 Thanks guys for all positive feedbacks reay apreciate Great work. I did this exact same scheme when I built my late Snipe, and you are definitely doing it justice! It really is a great kit, just look out for the Aldis sight, its a might tricky, as the brackets are on the top wing but it has to go through the windscreen which is attachec to the fuse. thanks Brian, I went through your build, You have done a perfect job on it. Was thinking that I will use EZ line for all rigging. But after I saw your build I will give a try that british flat line even it is white will try to paint it with black oils Great looking model! Turnbuckles on the interior bracing tells me you're taking this build very seriously. Just needs a hulking great HKM FGR2 beside it spanning the squadron's 50 years from 1924-74. thanks a lot but to be honest there are no turnbuckles at all yet, just silver paint and there will not be any of them. Im just trying to finish it in easy way and dont want to get stuck because of lost motivation will use them on my next WNW build which should be DH.9a postwar Link to comment Share on other sites More sharing options...
Jan_G Posted June 20, 2016 Author Share Posted June 20, 2016 shart weekend update I have tried Ammo solution for scratch effects on wheels but to be honest probably because I didnt work fast enough at the end i need to use a lot of force with brush to get to base colour so scratches are quite heavy....will put more dust on it MikeC, LSP_Paul and Zero77 3 Link to comment Share on other sites More sharing options...
