NukerDan Posted March 21, 2018 Share Posted March 21, 2018 (edited) I have to re-work the hole that I made for the astro-dome, I manged somehow to put it in the wrong location, way off....However looking at photos I have been gathering I was looking at one of the astro-dome and to my suprise I never realized that the hole in the aircraft is not round, it's actually square like the window on the earlier A/B models, learn something new every day. [/url]">http:// It almost looks hexagonal to me, or an oblong hexagon maybe? Or possibly even pentagonal. Edited March 21, 2018 by NukerDan Link to comment Share on other sites More sharing options...
p38johnny Posted March 22, 2018 Share Posted March 22, 2018 Hi Patrick, Yes, the Astrodome window on the top of the fuselage didn't change shape, only the covering of the opening. The window in the A/B airplanes was optically flat glass. When they went to the astrodome, it was just attached above the window opening. Here are some pictures that should help. John Clements Greg W, patricksparks, Model_Monkey and 1 other 4 Link to comment Share on other sites More sharing options...
dodgem37 Posted March 22, 2018 Share Posted March 22, 2018 Love what you're doing. Sincerely, Mark patricksparks 1 Link to comment Share on other sites More sharing options...
patricksparks Posted March 29, 2018 Author Share Posted March 29, 2018 (edited) RIBS, RIBS, RIBS and more RIBS, making some progress... ">http:// ">http:// Edited May 4, 2018 by patricksparks LSP_Kevin, Trak-Tor, chukw and 10 others 13 Link to comment Share on other sites More sharing options...
gunpowder Posted March 29, 2018 Share Posted March 29, 2018 Beautiful work patricksparks 1 Link to comment Share on other sites More sharing options...
patricksparks Posted March 29, 2018 Author Share Posted March 29, 2018 (edited) Wondering if anyone has information on this particular B-25C/D. All I have found is 13th Air Force, 42nd Bomb Group(CRUSADERS), 75th Squadron. I haven't been able to find a serial number or any additional images that might show the rear of the aircraft. Any help would be appreciated !!!">http:// ">http:// Edited May 4, 2018 by patricksparks Shawn M, sandokan and BiggTim 3 Link to comment Share on other sites More sharing options...
dodgem37 Posted March 29, 2018 Share Posted March 29, 2018 Great effort. Great show. Love that. Sincerely, Mark patricksparks 1 Link to comment Share on other sites More sharing options...
Guest Posted March 29, 2018 Share Posted March 29, 2018 Beautiful work ! Love the aircraft and the nose art.....Harv Link to comment Share on other sites More sharing options...
Trak-Tor Posted March 29, 2018 Share Posted March 29, 2018 That's some stellar rib-work! Juraj patricksparks 1 Link to comment Share on other sites More sharing options...
alaninaustria Posted March 29, 2018 Share Posted March 29, 2018 Beautiful work so far mate!! Cheers Alan patricksparks 1 Link to comment Share on other sites More sharing options...
Bstarr3 Posted March 30, 2018 Share Posted March 30, 2018 What size strip did you use for the ribs and stringers? patricksparks 1 Link to comment Share on other sites More sharing options...
patricksparks Posted March 30, 2018 Author Share Posted March 30, 2018 What size strip did you use for the ribs and stringers? Ribs are .040 X .100, the stringers are .030 X .030. BloorwestSiR and Greg W 2 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted April 3, 2018 Share Posted April 3, 2018 (edited) Patrick, I was wondering how did you get the vertical ribs to conform to the fuselage? I picked up a couple packs of the strip that you mentioned above but I'd love to know how you got them to fit. Thanks in advance, Carl Edited April 3, 2018 by BloorwestSiR Link to comment Share on other sites More sharing options...
patricksparks Posted April 3, 2018 Author Share Posted April 3, 2018 (edited) Patrick, I was wondering how did you get the vertical ribs to conform to the fuselage? I picked up a couple packs of the strip that you mentioned above but I'd love to know how you got them to fit. Thanks in advance, Carl The ribs on the side walls of the fuselage I "cold" formed by hand with .040 X .100 strips as the sides are almost flat, if you look at interior photos of B-25s you will see that they have larger size horizontal stringers in some areas, behind the cockpit there are more than in the rear fuselage. The rear fuselage is built almost as a "box" if you examine photos you can see that there are four larger horizontal stringers that are basically the same size in height as the ribs, I put the four stringers in first and then glued in the the vertical ribs that I cold formed in between the four large horizontal stringers(I used .040 X .100 for both). The upper and lower ribs above and below the for horizontal stringers I had to make templates and cut them from .040 styrene, you don't need to make a lot of templates, you can make ribs that are close to size and reshape them to fit each station, unless your planing to open up holes in the fuselage much of these fits won't be seen especially if your doing an earlier ABCor D variant with only the original windows. Also the ribs on the lower fuselage don't need to meet as there was much flooring in B-25s that covered a good portion of the ribs except near were the ribs meet the large horizontal stringers. The ribs from the rear end of the bomb bay forward are common shaped, if you use the kits former that goes behind the cockpit and the rear wall of the bomb bay you can get the shape you need for that entire area. Hope this helps !!! Pat Edited April 3, 2018 by patricksparks BloorwestSiR and Greg W 2 Link to comment Share on other sites More sharing options...
Guest Posted April 3, 2018 Share Posted April 3, 2018 Thanks Pat !.....Harv Link to comment Share on other sites More sharing options...
