Eli Raphael Posted August 1, 2022 Share Posted August 1, 2022 Gents, Can it be done? Thanks, Eli Link to comment Share on other sites More sharing options...
Dave Williams Posted August 1, 2022 Share Posted August 1, 2022 Sure, with the right conversion parts. If you have the Black Knights boxings, you just need the GE engines and exhaust shrouds, and possibly a new cockpit if you want things like the Sparrowhawk HUD, square PTID, and LANTIRN control stick. Over the years, a number of companies have made conversions for the Tamiya kit. Cutting Edge and Wolfpack to name a couple, but the CE stuff is long OOP. PhilB and LSP_K2 2 Link to comment Share on other sites More sharing options...
Eli Raphael Posted August 1, 2022 Author Share Posted August 1, 2022 Thanking you. Link to comment Share on other sites More sharing options...
Madelf75 Posted August 2, 2022 Share Posted August 2, 2022 I think it be easy to just use Reskit engines ,they have a set just design for Trumpeter or tamiya kit Link to comment Share on other sites More sharing options...
blackbetty Posted August 2, 2022 Share Posted August 2, 2022 i did it with the revell kit: https://forum.largescaleplanes.com/index.php?/topic/16171-revel-f-14b-conversion/ PhilB and Model_Monkey 2 Link to comment Share on other sites More sharing options...
thierry laurent Posted August 2, 2022 Share Posted August 2, 2022 3 hours ago, Madelf75 said: I think it be easy to just use Reskit engines ,they have a set just design for Trumpeter or tamiya kit Are you sure they released a B/D conversion for the Tamiya kit? As far as I know they released detailed resin parts replacing the exhausts parts of both kits and I'm not sure the parts made for the Trumpeter B or D can be used as such on the Tamiya A. Link to comment Share on other sites More sharing options...
Marcel111 Posted August 3, 2022 Share Posted August 3, 2022 I‘m using the Aires GE engines on my current Tamiya F-14D build, they work pretty well. There is obviously some cutting and filling involved but the fit is generally good. Make sure you sand off the little raised detail on the exhaust feathers, which is also super quick to do. Here‘s a better look at the set: https://ipmsusa.org/reviews2/aircraft/details/aires_32/aires_32_f14-exh.htm Cheers, Marcel PS I used the Trumpeter inside intakes to build the intakes on the Tamiya kit… those are easy to find since most Trumpeter Tomcat builders use the Zacto intakes Link to comment Share on other sites More sharing options...
PhilB Posted August 3, 2022 Share Posted August 3, 2022 In a galaxy far, far away and many years ago I did this conversion using Avionix/Black box pit, Aires exhaust cans and a couple of bits from Wolfpack and others. https://forum.largescaleplanes.com/index.php?/topic/30336-f-14b-tomcat-vf-103-jolly-rogers/ Kagemusha, blackbetty and Out2gtcha 3 Link to comment Share on other sites More sharing options...
Out2gtcha Posted August 3, 2022 Share Posted August 3, 2022 1 hour ago, PhilB said: In a galaxy far, far away and many years ago I did this conversion using Avionix/Black box pit, Aires exhaust cans and a couple of bits from Wolfpack and others. https://forum.largescaleplanes.com/index.php?/topic/30336-f-14b-tomcat-vf-103-jolly-rogers/ Still one of the best bloody kitties on the site! PhilB 1 Link to comment Share on other sites More sharing options...
Starfighter Posted August 3, 2022 Share Posted August 3, 2022 The Aires F110 conversion is pretty good and works even with the Revell kit with a bit of cutting. BTW, hard to understand why nobody ever did a set of landing gear bays for the Tamiya kit... Marcel111 1 Link to comment Share on other sites More sharing options...
PhilB Posted August 3, 2022 Share Posted August 3, 2022 3 hours ago, Out2gtcha said: Still one of the best bloody kitties on the site! Tanks ! Tanks a million! What is sad is hovering over the member's avatars who commented on that thread and seeing how many haven't logged in here in years. Also RIP to those no longer with us. We need to get the band back together................................... Out2gtcha 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted August 3, 2022 Share Posted August 3, 2022 Indeed life tends to go in cycles my friend. I just had the biggest modeling show in my country 10 min from my house and still hadn't touched a model in 6 months. I'm hoping to change that soon..... Link to comment Share on other sites More sharing options...
thierry laurent Posted August 8, 2022 Share Posted August 8, 2022 The two B conversion sets for the Tamiya A are available in UK! https://www.kingkit.co.uk/product/teknics-conversion-sets-1-32-32012-f-14b-tomcat-bombcat-cockpit-superset https://www.kingkit.co.uk/product/teknics-conversion-sets-1-32-32013-f-14b-tomcat-bombcat-airframe-conversion- Hth Thierry Link to comment Share on other sites More sharing options...
Eli Raphael Posted September 7, 2022 Author Share Posted September 7, 2022 Merci! Link to comment Share on other sites More sharing options...
Mr.T Posted September 10, 2022 Share Posted September 10, 2022 Of course the elephant in the room: TAMIYA should issue a totally new tool series of the F-14A/B and D in 1/32 scale and send the old molds to the bin. Link to comment Share on other sites More sharing options...
