John1 Posted April 20, 2022 Author Posted April 20, 2022 (edited) I've been putting off dealing with the wheel wells for a long time. Just wasn't up for the tedious work of adding all the details that Tamiya left out. Also had a hard time finding good reference shots of the nose landing gear bay. Thankfully, a kind gent over on FB came to my rescue with some fantastic personal pictures. Here's one that shows how "busy" the real thing was. Note - the red cover on the sidewall with the thumbscrews was to cover the opening for an avionics air conditioning hose. Those old electronics needed a great deal of cooling and if the A/C was on the ground, with the motors off and the avionics powered up, you had about 5 minutes to get some cold air to them or you'd end up doing some damage. Picture and info courtesy of Scott Wilson, a great guy who worked on USAF Phantoms back in the day. Here is my humble attempt at replicating the nose gear bay. Everything is scratchbuilt. I used a couple of diameters of lead wire (as mentioned, this stuff is great to work with, so much more pliable than copper or stretched sprue), scrap PE for the air conditioning inlet cover and tiny bits of sprue that a crushed one end of with some pliers to replicate the wingnut screws holding the cover in place. Note that as with most of my stuff, this is still a work in progress. It will look "busier" once the landing gear is installed. Once the gear is in, I'll go back and add more hydraulic lines (the black hoses can see in the picture above, plus some more white lines as well). It's not even close to being accurate but I'm just hoping to get a general feel for how cluttered this area was on the real thing. That's it for now, thanks for checking in guys! Edited April 20, 2022 by John1 Uncarina, Cheetah11, johncrow and 12 others 15
alain11 Posted April 20, 2022 Posted April 20, 2022 hi great job inside this bay !! it's not easy to add some wire into this narrow well , it's very convincing, and enough "busy" John1 and Anthony in NZ 1 1
John1 Posted April 21, 2022 Author Posted April 21, 2022 Thanks for the good feedback guys! In preparation for installing the lower wing / fuselage section, I wrapped up my paintwork on the horizontal stabs (these need to be installed with the lower fuselage, so it would be tough to mask off and paint these after installation). I toned down the outline of the internal structure on the stainless steel panels from my initial paint job, I think it was a bit too pronounced before. I also added some Flory Wash to highlight the surface detail and add a bit of grime to the inner sections. This area got pretty filthy on the real jet. Looks like I need to do a bit of cleanup on the aft inner sections. That's the good thing about using Flory's stuff. Just a damp q-tip and off it goes. Same thing for the undersurfaces. I'm going to add more grime to these, the early F-4C's engines were notorious smokers and the areas aft of the exhausts typically had a lot of soot present. Sharp-eyed readers will note that the stabs don't have the bare metal leading edges on the outer sections of the control surfaces. When these first jets were camouflaged in the field, the leading edges were just painted over. Later, the leading edges were left unpainted by the factory. Next up is the lower fuselage / wing section. I wanted to get a start on the weathering while I can easily manipulate this piece. Once it's all assembled, the more moving of the completed fuselage, the more of a chance that I'll break something. Like most aircraft (especially hardworking military ones), the undersides are usually pretty nasty. The F-4 took this to probably a new level of filth. Here are a couple of shots to illustrate my point. Keep in mind that I've seen much worse (just can't locate the pictures online). I just wanted to get the basic wash done before I assemble the fuselage. Nothing more than a couple of different colors of Flory Wash. As I get further into the process, I'll add some oil paints to replicate hydraulic leaks, etc. This is very much just a starting point . I went heaviest on the center fuselage aft of the landing gear bays and inside the speed brake wells. I also used a black enamel wash to highlight the various cooling grates on the forward fuselage. For some reason, a lot of modelers do some fantastic weathering on the upper surfaces but tend to go lightly or just ignore the under-fuselage areas. Never understood why, maybe just out of sight, out of mind? I need to remove that thumbprint of silver paint on the wing's inner surface. That's what I get for trying to rush things. So that's it for now, as always, thanks for checking in! Anthony in NZ, O.W, denders and 10 others 13
Cheetah11 Posted April 23, 2022 Posted April 23, 2022 Hi John very nice build so far and great attention to detail. Just a suggestion/observation. On the two Tamiya Phantoms I have done the rear fuselage was too narrow for the one piece tailplane. I ended up cutting the tailplane assembly in half and fitted them after the fuselage was closed. Cheers Nick Madmax, John1 and Anthony in NZ 2 1
John1 Posted April 23, 2022 Author Posted April 23, 2022 6 hours ago, Cheetah11 said: Hi John very nice build so far and great attention to detail. Just a suggestion/observation. On the two Tamiya Phantoms I have done the rear fuselage was too narrow for the one piece tailplane. I ended up cutting the tailplane assembly in half and fitted them after the fuselage was closed. Cheers Nick Thank you Nick, appreciate the tip. I’ll definitely use this if needed. I dry fitted the rear sections and they fit nicely but that was without the horizontal stabs in place.
Anthony in NZ Posted April 24, 2022 Posted April 24, 2022 (edited) Great progress John! The weathering on the belly is coming along nicely as are the horizontal stabs. I am nervous for you about maybe ruining the lovely paint work you have done so far by not gluing the wings, but I totally trust your approach and I know I will have nothing to worry about! Cheers Anthony Oh and I ment to congratulate you on that nosewheel well, looks superb mate, wish I could have got mine looking that busy, just looks right Edited April 24, 2022 by Anthony in NZ wheel well comment
John1 Posted April 25, 2022 Author Posted April 25, 2022 13 hours ago, Anthony in NZ said: Great progress John! The weathering on the belly is coming along nicely as are the horizontal stabs. I am nervous for you about maybe ruining the lovely paint work you have done so far by not gluing the wings, but I totally trust your approach and I know I will have nothing to worry about! Cheers Anthony Oh and I ment to congratulate you on that nosewheel well, looks superb mate, wish I could have got mine looking that busy, just looks right Thanks very much Anthony. I thought hard about the sequence of painting. I finally decided the ease of painting the wings and fuselage separately was worth it. I fully expect that I’ll have to sand and repaint along the seams but as long as they fit reasonably well, it shouldn’t be a major task. I’m down in FL on vacation but this will be the next task in the queue as soon as I get back. Anthony in NZ 1
alain11 Posted April 25, 2022 Posted April 25, 2022 it's a not a conventional way to build a kit, even if the Tamiya Phantom is "easy" ( note the quotes ) to build on, I think that you are very confident
John1 Posted April 25, 2022 Author Posted April 25, 2022 4 hours ago, alain11 said: it's a not a conventional way to build a kit, even if the Tamiya Phantom is "easy" ( note the quotes ) to build on, I think that you are very confident A plethora of confidence does not equate to the same level of competence. Could work out nicely, could become a train wreck. GreyGhost 1
alain11 Posted April 25, 2022 Posted April 25, 2022 it could !! does it worth it to take a risk after so much effort ..... I wish it works fine GreyGhost and John1 1 1
John1 Posted April 29, 2022 Author Posted April 29, 2022 So I'm back from the Magic Kingdom, where I caught a great tan and a not-so-great case of Covid. The only upside is that for the next few days, I can model (and flight sim and read) to my heart's content, in splendid isolation from the fam. No more "honey-do's" for a bit. Horray me.... I dove into the fuselage assembly. As I've whined about many times on this build, this was one of those make-it or break-it steps of the build. Given some of the horror stories I've heard, all in all, it went surprisingly well. My advice is pretty basic - test fit every single step (including adding the upper wing surfaces just to make sure nothing is seriously out of wack)and follow the instructions. Easy-peezy. Aside from that, once the sections were held in place by the screws, I went back and moving slowly from aft to forward, started gluing the lower section in place. I used a mix of regular Tamiya liquid glue and for a few spots that needed some persuasion, super glue. I do have some work ahead of me, which I would have expected under any circumstances: Need to fill some gaps and do some touchup painting. For the forward section, I think I can get it glued together and since the joint is on a panel line, nothing else will be required. The section under the intake will require some sanding and rescribing. Not a major issue and I was going to have to paint that area anyway so it should be pretty straightforward. Speaking of painting, I did screw up. I assumed that the color border matched the kit parts but was mistaken. The camouflage colors are actually much lower, below the outline for the air conditioner inlets. Again though, pretty much a 5 minute to mask and respray job. Also, if I do have to use a bit of filler on the gap, I'd be repainting it anyway. Also, one thing I caught after the fact: The lower fuselage panels under the exhaust were nothing more than thin sheet metal on the real thing. The Tamiya plastic equates out to around 1" steel plate. The right way to address this would have been to sand these sections down prior to assembling the two fuselage sections. However, since I caught this after the fact, I had to carefully thin them by wedging the tip of a new Xacto blade between the panels and the engine nozzles and carefully peeling away a bit of plastic from the interior. Got to clean up my work but it looks 100% better than the factory plastic. Some other pics: Should look nice once I get the body work done and hit it with some gloss white! Again, I've got some work to do but overall, I'm pleased with where I am at right now. Thanks for checking in. Uncarina, Landrotten Highlander, Fanes and 16 others 19
easixpedro Posted April 29, 2022 Posted April 29, 2022 (edited) Nicely done! I was worried for you as it came time for assembly, but looks like you've pulled it all off without any major issues. I've never had that sort of luck, but mostly as every Phantom I've built I dropped all the flaps, which introduced all sorts of errors. Looking forward to the rest--get well soon! -Peter Edited April 29, 2022 by easixpedro John1 and Anthony in NZ 1 1
GreyGhost Posted April 29, 2022 Posted April 29, 2022 (edited) That's looking Phantastic ..! Get well John ... Was the Mouse masked up, I've never seen him masked up ... -Gregg Edited April 30, 2022 by GreyGhost
John1 Posted April 30, 2022 Author Posted April 30, 2022 5 hours ago, GreyGhost said: Get well John ... Was the Mouse masked up, I've never seen him masked up ... -Gregg Now that you mention it, no. He was not. Actually, the whole place seemed kinda goofy. I’ll show myself out… easixpedro, Uncarina and GreyGhost 3
Anthony in NZ Posted April 30, 2022 Posted April 30, 2022 Bravo John! I have to say that I was worried for you with this approach (but quietly confident). It really has come up brilliantly! Shane I cant use all the screw holes in my kit due to all the fuse mods, but nice to know it wasnt overly difficult. Thats where the hard work is in all your prep. Well done! Really looking nice
