denders Posted April 9, 2021 Author Share Posted April 9, 2021 Okay, it's started. Greg W, BradG, Landrotten Highlander and 5 others 8 Link to comment Share on other sites More sharing options...
MikeMaben Posted April 10, 2021 Share Posted April 10, 2021 Link to comment Share on other sites More sharing options...
denders Posted April 24, 2021 Author Share Posted April 24, 2021 Update. Lost one of the seat PE pieces, PIIIINNNNNNNGGGGGGGGG. Ah, well. The gun sight was a particular chore. mgbooyv8, Fanes, BradG and 7 others 10 Link to comment Share on other sites More sharing options...
BradG Posted April 25, 2021 Share Posted April 25, 2021 You'll find that piece stuck to your foot about 2 days after you finish the model!:) Uncarina, Woody V, denders and 1 other 4 Link to comment Share on other sites More sharing options...
MikeMaben Posted April 26, 2021 Share Posted April 26, 2021 Changed my sheets last week and found a mask made of 810 at the foot of the bed 'under' the sheets. Those things are worse than PE, they stick to everything !! ... yes I'm barefoot when around the house. denders and Ayovan 1 1 Link to comment Share on other sites More sharing options...
denders Posted June 21, 2021 Author Share Posted June 21, 2021 Updates from last week. All the non-colored PE in place. Primed. Color. Colored PE is next. Dave Greg W, mgbooyv8, Fanes and 6 others 9 Link to comment Share on other sites More sharing options...
mgbooyv8 Posted June 21, 2021 Share Posted June 21, 2021 Great progress! Cheers, Peter Link to comment Share on other sites More sharing options...
denders Posted June 29, 2021 Author Share Posted June 29, 2021 (edited) More progress. Although, it just dawned on me last evening that the instrument panel mounting should be green instead of black. This will added to the right side console after the cockpit is installed in the right fuselage side. And then, there's THIS GUY! Edited June 29, 2021 by denders Landrotten Highlander, LSP_Kevin, Greg W and 4 others 7 Link to comment Share on other sites More sharing options...
denders Posted July 6, 2021 Author Share Posted July 6, 2021 Closed up the fuselage. I thought I had the gap taken care of too. Ah well. BradG, LSP_Kevin, Greg W and 2 others 5 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted July 6, 2021 Share Posted July 6, 2021 Nice cockpit, Dave! Kev Link to comment Share on other sites More sharing options...
denders Posted July 29, 2021 Author Share Posted July 29, 2021 Update. That is the engine laying there too. You can see the Prop, Cowling, and the extra wing tanks there too. (sorta) Trak-Tor, BradG, Isar 30/07 and 5 others 8 Link to comment Share on other sites More sharing options...
Alain Gadbois Posted August 9, 2021 Share Posted August 9, 2021 Nice cockpit! Does the windscreen still fit with the extra width caused by the styrene strip? Alain Link to comment Share on other sites More sharing options...
denders Posted August 10, 2021 Author Share Posted August 10, 2021 Yes, it does seem to fit, perhaps a bit tight. Of course, I spent a bit of time fitting the cockpit parts, etc., carefully sanding edges, checking fit, and I thought I had everything to where it closed up nice and tight before gluing anything. But, when it came time, I ended up with that sliver of styrene to close it up. Dave Alain Gadbois 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted August 10, 2021 Share Posted August 10, 2021 Looks great so far! denders 1 Link to comment Share on other sites More sharing options...
denders Posted August 11, 2021 Author Share Posted August 11, 2021 Anyone interested in guessing the size of the fuselage insignia? It's definitely smaller than standard. I'm pretty sure the aircraft was painted the tri-color scheme in the field. I'm thinking 30" or 35".The first photo it has a red surround. Thanks Dave Link to comment Share on other sites More sharing options...
