MikeMaben Posted August 13, 2020 Share Posted August 13, 2020 13 hours ago, Antonio Argudo said: Dragon's kit elevator trim tab is the wrong position, Nice catch Link to comment Share on other sites More sharing options...
Antonio Argudo Posted August 15, 2020 Author Share Posted August 15, 2020 (edited) On 8/13/2020 at 8:26 AM, MikeMaben said: Nice catch thanks Mike, I saw that in another build cheers small update on the cockpit, since his 109 had drop tank I had to add the fuel panel under the IP, also the fuel pipe and some gauges and pull handles missed before, also some maps to fill that map case. so the building phase is done, painting coming soon... cheers Edited August 15, 2020 by Antonio Argudo John1, Dany Boy, Landrotten Highlander and 1 other 4 Link to comment Share on other sites More sharing options...
Hartmann52 Posted August 15, 2020 Share Posted August 15, 2020 5 hours ago, Antonio Argudo said: Link to comment Share on other sites More sharing options...
Antonio Argudo Posted August 15, 2020 Author Share Posted August 15, 2020 3 hours ago, Hartmann52 said: not sure I understand what that means Link to comment Share on other sites More sharing options...
Hartmann52 Posted August 15, 2020 Share Posted August 15, 2020 8 minutes ago, Antonio Argudo said: not sure I understand what that means Did Galland's plane have this fuel line? I thought he only went with the E-7 modification? Link to comment Share on other sites More sharing options...
Antonio Argudo Posted August 15, 2020 Author Share Posted August 15, 2020 (edited) 12 minutes ago, Hartmann52 said: Did Galland's plane have this fuel line? I thought he only went with the E-7 modification? if you look closer it's there, it was mention by fellow member Reserve_22 earlier in the thread, Galland had a privileged position in the luftwaffe and had many goodies installed in his aircraft before went applied into production, cheers Edited August 15, 2020 by Antonio Argudo Hartmann52 1 Link to comment Share on other sites More sharing options...
Antonio Argudo Posted August 17, 2020 Author Share Posted August 17, 2020 I tried to improve that hole shape where the guns are visible, I used magic sculpt to fill them and carved a better shape, cheers Uncarina, Elger, LSP_Kevin and 6 others 9 Link to comment Share on other sites More sharing options...
Antonio Argudo Posted August 17, 2020 Author Share Posted August 17, 2020 Thanks for these pictures Reserve_22 Link to comment Share on other sites More sharing options...
Antonio Argudo Posted August 17, 2020 Author Share Posted August 17, 2020 adding more details... the wing root bump panel lower fuselage missing panel tail wheel cover wing slats a view cheers D.B. Andrus, chrish, Dany Boy and 6 others 9 Link to comment Share on other sites More sharing options...
chrish Posted August 17, 2020 Share Posted August 17, 2020 Every detail is looked after! Antonio Argudo 1 Link to comment Share on other sites More sharing options...
Antonio Argudo Posted August 17, 2020 Author Share Posted August 17, 2020 3 hours ago, chrish said: Every detail is looked after! thanks Chrish, until patience allows it cheers primed with RLM 02 thanks for watching, cheers Landrotten Highlander, MikeMaben and Uncarina 3 Link to comment Share on other sites More sharing options...
Antonio Argudo Posted August 17, 2020 Author Share Posted August 17, 2020 1 hour ago, reserve_22 said: Fuselage was primed in Rlm65 only wings are in Rlm02 thanks Reserve_22, will paint Galland's 109 in RLM 74/75/76 grey camo cheers Uncarina 1 Link to comment Share on other sites More sharing options...
Troy Molitor Posted August 18, 2020 Share Posted August 18, 2020 Some really fantastic work going on here Antonio. I love the 109. Antonio Argudo 1 Link to comment Share on other sites More sharing options...
Antonio Argudo Posted August 18, 2020 Author Share Posted August 18, 2020 (edited) 10 hours ago, Troy Molitor said: Some really fantastic work going on here Antonio. I love the 109. Thank you Troy, glad you like it, be careful 109's can become easily an obsession cheers first coats of RLM 76 thanks for watching, cheers Edited August 19, 2020 by Antonio Argudo Lothar, TAG, Uncarina and 2 others 5 Link to comment Share on other sites More sharing options...
Troy Molitor Posted August 18, 2020 Share Posted August 18, 2020 I do not have ANY obsession with the Bf 109 Lothar, D.B. Andrus, Antonio Argudo and 4 others 1 6 Link to comment Share on other sites More sharing options...
