Cheetah11 Posted July 7, 2020 Posted July 7, 2020 I am looking at doing a 1/48 Hasegawa 109 E-4 and in Galland's markings during Sept 1940.(Can't find a 1/32 kit for the group build in the time left) The kit instructions and some other sources give the colors as 74,75 and 65. Surely at the time it would have been 02, 71 and 65 or did he have an experimental cammo scheme? Thanks Nick Antonio Argudo 1
LSP_Mike Posted July 7, 2020 Posted July 7, 2020 The 02, 70/71, 65 scheme was the experimental scheme. Antonio Argudo, Greif8 and Cheetah11 2 1
RBrown Posted July 8, 2020 Posted July 8, 2020 (edited) Galland had two machines , W. Nr. 5819 and W. Nr. 6714, at the time. Both machines carried the same markings. Galland was asked at a seminar about the colors but stated that he did not remember. His former chief mechanic was also present and advised that Galland's aircraft were camouflaged with gray paint but did not elaborate. Edited July 8, 2020 by RBrown Cheetah11, Antonio Argudo and Greif8 2 1
Greif8 Posted July 8, 2020 Posted July 8, 2020 Hi Nick, it is possible, though highly unlikely the either of Galland's aircraft that he used during the Battle of Britain had the 74,75, 65 scheme. Official instructions to change to that exterior camo scheme were not issued by the Luftwaffe administration until Nov 41. Again, it is possible that RLM 74 and 75 were being experimented with during the BoB timeframe, but it is unlikely that is so. A plausible explanation for the Hasegawa color scheme is that RLM 74 can look a lot like RLM 71 depending on such factors as how the light is striking the painted surface, the amount of wear the painted surface has had and where a particular RLM color was mixed; all of which can effect the color tone. There is nothing absolutely definitive when it comes to RLM colors and how/when they were applied however; so you could justifiably use 74/75 and explain it as one of Galland's innovations along with the forward canopy mounted telescope and ashtray in the cockpit! Ernest Cheetah11, Antonio Argudo, Uncarina and 1 other 3 1
Cheetah11 Posted July 8, 2020 Author Posted July 8, 2020 Thanks for all the information Gents. I think I will go with the standard 02/71/65. Nick MikeMaben, Gazzas and Antonio Argudo 3
Greif8 Posted July 8, 2020 Posted July 8, 2020 Nice picture, given the victory bars it was probably taken sometime between late Nov 40 - the end of Mar 41 I would guess. Ernest Antonio Argudo 1
MikeMaben Posted July 9, 2020 Posted July 9, 2020 (edited) 21 hours ago, Cheetah11 said: I think I will go with the standard 02/71/65. I think you'd be right. Canopy frames look 66 Edited July 9, 2020 by MikeMaben D Bellis, Antonio Argudo, Greif8 and 2 others 3 1 1
Cheetah11 Posted July 9, 2020 Author Posted July 9, 2020 (edited) Thanks for the photos gentleman. There is a lot of information I can use which is a little different from the accepted modeling practices. Maybe more time for cleaning and maintenance during the early war years. The nose cowl is a lot dirtier than I would have expected yet the wings are covered with tarpaulins during cleaning and maintenance leading to most likely very little scuff marks in that area. The fitter seems to be cleaning the side of the fuselage and little exhaust residue is visible. Panel lines and rivets are fairly subdued and the markings are not nearly as crisp and defined as modern decals would portray. The canopy frame is also interesting. As Mike has observed maybe 66 or maybe 70. Thanks again for the info. Edited July 9, 2020 by Cheetah11 Spelling Antonio Argudo 1
Mark P Posted July 9, 2020 Posted July 9, 2020 Be aware the last color photo in this thread is colorized. Mark Proulx D Bellis and Antonio Argudo 2
John1 Posted July 9, 2020 Posted July 9, 2020 1 hour ago, Mark P said: Be aware the last color photo in this thread is colorized. Mark Proulx Correct. You can draw absolutely no conclusions on the colors of the real thing from that picture. Still a nice job, nonetheless. Antonio Argudo 1
Greif8 Posted July 9, 2020 Posted July 9, 2020 Another thing to remember when constructing an aircraft flown by Galland, or any other leading ace for that matter, is that his/their aircraft very likely received more tender loving care than a fighter flown by Joe Nobody meaning it, again generally, looked a bit less beat up. During the BoB timeframe, and for a couple of months afterwards, German JG operated from forward base, very often from grass fields with little to no permanent maintenance structures; and several of the JG had gotten very little break after the Battle of France was completed. So their aircraft were more worn than say later in the war when the JG in the west mostly operated from established airfields. Gives us modelers a lot of latitude when it come to weathering. Ernest Antonio Argudo and Uncarina 2
MikeMaben Posted July 10, 2020 Posted July 10, 2020 14 hours ago, John1 said: Correct. You can draw absolutely no conclusions on the colors of the real thing from that picture. Still a nice job, nonetheless. The nose is yellow. There's one. Basta, Madmax, John1 and 2 others 1 4
Antonio Argudo Posted July 28, 2020 Posted July 28, 2020 Jerry Crandall has asked Galland about it back in their meetings, he said that he order himself to paint his aircraft in the grey scheme because he spent more time over the Channel, Jerry is a member of this forum would be great to hear his account, I made a comparison with my 74/75//6 relics and the only color picture of Galland's aircrafts can see clearly a 75 grey violet on the fuselage, cheers Madmax, MikeMaben, Basta and 1 other 2 2
MikeMaben Posted July 29, 2020 Posted July 29, 2020 Neat, what where are those pieces from Tony ? Antonio Argudo 1
