blackbetty Posted May 6, 2020 Author Share Posted May 6, 2020 (edited) as for the smalll blade antenna, allthough on a Dagger (i think): your measurments are mm i assume there is a pic of a different version (maybe later): Edited May 6, 2020 by blackbetty Kais, 109, Isar 30/07 and 1 other 4 Link to comment Share on other sites More sharing options...
DaxJael Posted May 6, 2020 Share Posted May 6, 2020 Hi. I saw different measures of this part. My references was these photos of the similar plain brothers malvinas time: dutik, blackbetty and HerculesPA_2 2 1 Link to comment Share on other sites More sharing options...
blackbetty Posted May 6, 2020 Author Share Posted May 6, 2020 thanx for the pics, its very difficult to find any any argentinian sites? Link to comment Share on other sites More sharing options...
DaxJael Posted May 6, 2020 Share Posted May 6, 2020 No, you search: mirage IIIea malvinas. Like: www.3040100.com.ar www.amilarg.com.ar Saludos!! Lothar 1 Link to comment Share on other sites More sharing options...
Cheetah11 Posted May 6, 2020 Share Posted May 6, 2020 Hi Karl 12 hours ago, blackbetty said: as for the smalll blade antenna, allthough on a Dagger (i think): your measurments are mm i assume there is a pic of a different version (maybe later): Interesting photos. It shows how much cutting and pasting has gone into Mirage III variants. It is so important to try and get a photo of the time period to get an accurate model. The top photo has the original French factory fitted ILS antenna and an IAI radar warning antenna. The second photo shows a French radar warning antenna with an " aftermarket" ILS antenna. Looks like the same as fitted to UK Tornados. For the first one scale up a 1/48 Mirage F1 antenna and I think you will not be very far off using the Revell Tornado dimensions. I am sure the second photo shows a Mirage IIIC or the equivalent Israeli supplied variant. Cheers Nick blackbetty 1 Link to comment Share on other sites More sharing options...
blackbetty Posted May 8, 2020 Author Share Posted May 8, 2020 sanding required mozart, scvrobeson, johncrow and 4 others 7 Link to comment Share on other sites More sharing options...
blackbetty Posted May 14, 2020 Author Share Posted May 14, 2020 ......well it is one of the most beautiful airplanes ever made the definitive delta..... HerculesPA_2, Out2gtcha, Uncarina and 12 others 15 Link to comment Share on other sites More sharing options...
Kagemusha Posted May 14, 2020 Share Posted May 14, 2020 That's a mighty fine sight Karl. Link to comment Share on other sites More sharing options...
Out2gtcha Posted May 14, 2020 Share Posted May 14, 2020 VERY nice! Looks great in primer Link to comment Share on other sites More sharing options...
DaxJael Posted May 14, 2020 Share Posted May 14, 2020 Hi Karl! Great advance! You already closed it? Remember the machine guns DEFA 552.. under fuselage.. Was very complicated put it on. Saludos! Dragon, Marcel111, scvrobeson and 2 others 5 Link to comment Share on other sites More sharing options...
blackbetty Posted May 14, 2020 Author Share Posted May 14, 2020 those cannon barrels are a new info to me, did i miss something? Link to comment Share on other sites More sharing options...
DaxJael Posted May 14, 2020 Share Posted May 14, 2020 https://images.app.goo.gl/gKkaxAWPgVxtBtNp6 Link to comment Share on other sites More sharing options...
blackbetty Posted May 15, 2020 Author Share Posted May 15, 2020 i found this pic on your build the mirage seems to have this muzzle brake. does the barrel extend through the holes? Link to comment Share on other sites More sharing options...
DaxJael Posted May 15, 2020 Share Posted May 15, 2020 I found nany pictures of plane at the museum without barrels, because take it off. Just looking some photos with cannon... blackbetty 1 Link to comment Share on other sites More sharing options...
DaxJael Posted May 15, 2020 Share Posted May 15, 2020 blackbetty 1 Link to comment Share on other sites More sharing options...
