Oldbat Posted October 9, 2019 Posted October 9, 2019 Hi everybody! I'd like to inroduce my latest project and the very first one here on LSP - the famous WWI Fokker Eindecker 1/24 scale model. I always desired to build something different and original. And I've always been fascinated by models built as such a naked airframe with no (or almost no) cover or fairing. Thinking about what would be the best type to start with, I decided to choose this interesting and, thank's to the synchronization system engaged in it, the very first proper fighter plane Oh yea, another reason why I chose this plane is, that it is a quite simple monoplane! Well, currently, lots of work are already done. All of the original parts or masteres are already finished and a friend of mine, Pavel, was so kind and did a great job with casting the parts for me. A photo etched sheet with some metal parts is also succesfully finished and prepared to use, as well as wooden parts laser-cutted from 0,4 mm plywood. A finished model may look like this Trak-Tor, scvrobeson, Gazzas and 5 others 8
TorbenD Posted October 10, 2019 Posted October 10, 2019 Gotta love a scratch build! to the forum Torben
LSP_Ray Posted October 10, 2019 Posted October 10, 2019 This will be an awesome project! What are you using for reference?
Oldbat Posted October 11, 2019 Author Posted October 11, 2019 Hi everybody! For the beginning, a few photos of an engine. I will add more photos of what is curently done on Sunday Trak-Tor, Gazzas, GMK and 7 others 10
Gazzas Posted October 11, 2019 Posted October 11, 2019 Welcome to the forum! Looking forward to seeing you bring this one to life! Gaz
Oldbat Posted October 14, 2019 Author Posted October 14, 2019 Hi everybody! Here we go - an assembled wing. Coloured and washed 0,4mm plywood... ...an assembled rib.... ... a pile of splinters ... ...and finally an assembled wing. I am just happy with the result! I am pretty surprised with the properties of the plywood. It seems to be very fragile, but even when a single rib is assembled and glued, it is really solid and tough! Love the work with a real wood Trak-Tor, patricksparks, chukw and 5 others 8
TorbenD Posted October 15, 2019 Posted October 15, 2019 Not surprised you’re happy! Delightful stuff. Torben
Out2gtcha Posted October 16, 2019 Posted October 16, 2019 Nothing looks like real metal wood more than real metal wood! I'm still used to doing that with NMF and foil, but using actual wood for a model is great! It really looks the part. Oldbat 1
Oldbat Posted October 23, 2019 Author Posted October 23, 2019 Hi everybody! Thank you all, I appreciate you like my work! On 10/16/2019 at 8:05 PM, Out2gtcha said: Nothing looks like real metal wood more than real metal wood! I'm still used to doing that with NMF and foil, but using actual wood for a model is great! It really looks the part. Absolutely agree, moreover, problems how to dye the surface are gone using real materials Finally, I have gathered some pics of the current state. The fuselage itself is complete, the port side wing needs only a few touches to finish it. I am slowly approaching to the moment, when all the rigging takes it's place. For a long time, I have been thinking about the best way how to make the structure of the fuselage. A friend of mine, who is an RC modeller gave me an advice to try carbon rods or profiles, available at RC models shops. It is quite difficult to glue this material together, as well as it is almost imposible to bend it. BUT, it is a great material as it keeps its straightness. It is very solid and strong, but easy to cut or sand it. I used those rods make all the masters and then as reinforcements whithin the parts when they were casted. Traverse struts of the fuselage are those carbon rods only. The result is satisfactory, strong enough and nice to work with it... airscale, Out2gtcha, Alain Gadbois and 2 others 5
Out2gtcha Posted October 23, 2019 Posted October 23, 2019 Great solution with the carbon tubes! Some of the medium sized ones are the same thing they make arrows out of..........we have an archery cmshop close to me, and they sometimes cut custom arrow lengths, so they have a (literal) barrel full of cut carbon tube leftovers. If you happen to have an archery shop close they normally sell the scraps dirt cheap.
