Kendzior Posted September 9, 2019 Posted September 9, 2019 Hi All, Haven't been posting much for a while, as most of my recent projects focused on the smaller scales, but it's time to start something "new" in a larger scale: the Curtiss P-36 Hawk by Special Hobby in its export version built for Netherlands, known as Curtiss H-75 A-7. Surely not a shake'n'bake , taking into account that it is not a new kit, so the moulds show some wear and tear, but anyway - it's the only game in town in an injection mould. Started with glueing the fuselage and engine parts together, deeping some lines and joints, removed the ventilation holes in front of the cockpit, riveted the fuselage and installed the cockpit walls. For now, everything looks quite optimistic. Stay tuned, best Hubert Kagemusha, sandokan, LSP_Kevin and 12 others 15
Kagemusha Posted September 9, 2019 Posted September 9, 2019 Fantastic, really looking forward to following along. Kendzior 1
daveculp Posted September 10, 2019 Posted September 10, 2019 In the 1950's the Wolfhounds arrived at Soesterberg Air Base, Netherlands in F-86's. That's a long history! I'll be following this build. Jack and Kendzior 2
Biggles87 Posted September 10, 2019 Posted September 10, 2019 I’ve had one of these for some time but havn’t got around to building it yet, so I’ll follow this if I may. John Kendzior 1
R Palimaka Posted September 10, 2019 Posted September 10, 2019 Excellent choice, although I understand it is not an easy kit. You will make it work though, looking forward to following your progress. RIchard Kendzior 1
Out2gtcha Posted September 10, 2019 Posted September 10, 2019 Very cool project! The Norwegian Hawk on floats looks very interesting as well - Kendzior 1
dennismcc Posted September 10, 2019 Posted September 10, 2019 (edited) Looking good, will follow with interest Cheers Dennis Edited October 11, 2019 by dennismcc Kendzior 1
Kendzior Posted September 11, 2019 Author Posted September 11, 2019 Thanks for watching Mates. So here we go with the engine: As you can see, it's not bad. However, some improvements will be necessary, did consider a resin replacement from Vector only for a while, but no, I'm sure it will look decent after it is painted and the ignition cables are installed. Some more care is required as regards the engine wall - it is too wide, I think for something around two mm - on the other hand, the shape of it matches the fuselage so well, that I decided to cut it into halves and thus make it narrower by these two mm. I also cut off the engine mount, it will help determine the right place for its installation, after the engine wall is narrower. Most of the interior and engine bits are now ready for the primer. Only the pilot seat needs yet to be slightly reworked and detailed, before it is primed and painted. A copy of 1:32nd scale plans is also ready for riveting the wings and tailplanes. Best Hubert TorbenD, sandokan, Biggles87 and 9 others 12
scvrobeson Posted September 12, 2019 Posted September 12, 2019 On 9/10/2019 at 8:13 AM, Out2gtcha said: Very cool project! The Norwegian Hawk on floats looks very interesting as well - That looks like a Northrop N-3pb, not a Curtiss Hawk. Matt Out2gtcha 1
Out2gtcha Posted September 12, 2019 Posted September 12, 2019 Just now, scvrobeson said: That looks like a Northrop N-3pb, not a Curtiss Hawk. You may very well be right. It was on a page with a ton of Norwegian Hawks (with standard pants) with some dispute as to what color green they were. scvrobeson 1
Kendzior Posted September 16, 2019 Author Posted September 16, 2019 OK, so the engine wall is now perfectly fitting inside the fuselage, a similar operation is necessary as regards the "firewall" too - but this time I will just cut off approximately 1 mm from each side, maybe something from the lower edge too - to be sure that the fuselage isn't too wide where it meets the wings, so that the correct wings' dihedral is ensured. Primed the interior too, with the Mig's One Shot black primer. Kagemusha, Biggles87, MikeMaben and 7 others 10
Kendzior Posted October 6, 2019 Author Posted October 6, 2019 A small progress report. Cockpit green inside of the cockpit and most of the small parts have been painted as well. Have bought the detail-up set for the engines of the HKM's B-17 - got few other kits with the Wright Cyclone engine, so no worry, it is not a regrettable loss. Going to use the pilot's seat from Eduard. Actually, there's a nice photo-etched detail-up set included in the SH's box, so the rest of the Eduard's set will be used in the future, when I start the Trumpy's P-40B. And the P-40's canvas covers for the wheel wells, the fit is really good - don't know yet if I'll use them, or just make me own based on these, will see. Best Hubert sandokan, LSP_Kevin, R Palimaka and 6 others 9
waroff Posted October 10, 2019 Posted October 10, 2019 it's not sure that you can use the wheel pocket of P40 for H75, the wheel diameter is only 27" instead 30" on P40 You can close the hole in the frame behind the seat, there was a armor plate and if it not fitted there was a curtain. MikeMaben and Kendzior 1 1
Kendzior Posted October 11, 2019 Author Posted October 11, 2019 You're absolutely right, considering that the 3" difference should probably be visible. The fact that these covers fit the SH P-36's wheel wells may lead to the conclusion that there's something wrong with the kit or with the covers or both. That's how it looks like (parts just taped together, there's still some flash to be removed) - pretty well to my eyes: And of course I'm going to install the armour plate behind the pilot's seat. Thanks for comment :) Best regards Hubert LSP_Kevin, Biggles87, R Palimaka and 5 others 8
