RBrown Posted August 14, 2019 Posted August 14, 2019 Along with several other Revell items...http://spruebrothers.com/ Out2gtcha, D.B. Andrus, LSP_K2 and 1 other 2 2
LSP_K2 Posted August 14, 2019 Posted August 14, 2019 Good news indeed. I need replacement wings for my own 110, and the price on this release is good, so I have hope now.
Patrick HMD Posted August 14, 2019 Posted August 14, 2019 (edited) Yawn, I'll be in my bunk. ZZZzzz... Edited August 15, 2019 by Patrick HMD Rick Griewski 1
ringleheim Posted August 19, 2019 Posted August 19, 2019 And just like that, the Sturmbock is now out of stock at Sprue Bros. Rick Griewski 1
Kaeone57 Posted August 20, 2019 Posted August 20, 2019 It seems that if.the Bf-110 is Dragons original molds it has been re-tooled as it now has seperate ailerons and flaps per the kits specs. Or is it a new mold all together by Revell? Hmmmmm.... Alfonso Rick Griewski 1
Rick Griewski Posted August 20, 2019 Posted August 20, 2019 Flaps would be very nice. Slats even better <comment from a guy that already has three of the Dragon kits>. Rick
Dave Williams Posted August 20, 2019 Posted August 20, 2019 1 hour ago, Kaeone57 said: It seems that if.the Bf-110 is Dragons original molds it has been re-tooled as it now has seperate ailerons and flaps per the kits specs. Or is it a new mold all together by Revell? Hmmmmm.... Alfonso The specs are wrong. It’s the Dragon plastic, unmodified, with fixed control surfaces. You can see the instructions, including the sprue layout here: https://stage.revell.de/fileadmin/import/images/bau/04961_%23BAU_MESSERSCHMITT_BF110C2_C-7.PDF Out2gtcha, D Bellis, MikeMaben and 2 others 3 2
Out2gtcha Posted August 20, 2019 Posted August 20, 2019 1 hour ago, Dave Williams said: The specs are wrong. It’s the Dragon plastic, unmodified, with fixed control surfaces. You can see the instructions, including the sprue layout here: https://stage.revell.de/fileadmin/import/images/bau/04961_%23BAU_MESSERSCHMITT_BF110C2_C-7.PDF Thanks for that. So in light of the previous fact, would it not be possible, even better maybe to use the Revell instructions with a standard DML 110 kit, so save the headache of the horrible DML OOB instructions? LSP_K2 and coogrfan 2
Dave Williams Posted August 20, 2019 Posted August 20, 2019 Just now, Out2gtcha said: Thanks for that. So in light of the previous fact, would it not be possible, even better maybe to use the Revell instructions with a standard DML 110 kit? I downloaded a copy for that very reason. LSP_K2, D Bellis and Out2gtcha 3
mozart Posted August 20, 2019 Posted August 20, 2019 Hmmm, a very interesting engine/nacelle/wing-build sequence. I wonder if it works well? Fanes 1
Kaeone57 Posted August 21, 2019 Posted August 21, 2019 9 hours ago, Dave Williams said: The specs are wrong. It’s the Dragon plastic, unmodified, with fixed control surfaces. You can see the instructions, including the sprue layout here: https://stage.revell.de/fileadmin/import/images/bau/04961_%23BAU_MESSERSCHMITT_BF110C2_C-7.PDF Thanks! Grrrrrrrr, wrong specs....Grrrrr!
