artoor_k Posted July 10, 2019 Share Posted July 10, 2019 Hello, I should build P-61 but when I received this kit I just couldn't force myself to not start it. As you probably know - this is more toy than model. Another kit of Veltro is multimedia set of Pacific Coast Models. It's more detailed for sure but after long and exhausting fight (I'm on retreat) with their Spitfire mk XVI I'll buy another their kit only if they pay me ten times more than model price and deliver a cistern of good quality beer So I bought 21st Century Toys Veltro at a reasonable prise. Kit is really good - nice balance between model and toy. But hey! It's a 1/32 model for 10$! Panel lines are deep and wide but after some sanding I think they'll become acceptable. So...let's begin... I'm going for this one, so I have to make a serie I from serie III. It means that I have to cut cannons and drill holes in wing for machine gun barrels: I started with cockpit interior. This is what you get OOB: After raid on scrap box I got this: Instrument panel is quite good although with help of Squadron Signal Veltro Walkaround book I decided to add compass, and two small levers I'd like to know what you think by now Next stop: probably gear wells detailing. Paul in Napier, Sepp, Gazzas and 13 others 16 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted July 10, 2019 Share Posted July 10, 2019 Nice project, Artoor! I didn't realise that the RAAF captured and flew one of these machines, so it should make for a unique model when finished. I've also entered you into this month's prize raffle. Kev coogrfan, Out2gtcha and artoor_k 3 Link to comment Share on other sites More sharing options...
artoor_k Posted July 10, 2019 Author Share Posted July 10, 2019 8 minutes ago, LSP_Kevin said: Nice project, Artoor! I didn't realise that the RAAF captured and flew one of these machines, so it should make for a unique model when finished. I've also entered you into this month's prize raffle. Kev Wow, thanks That's motivational Out2gtcha 1 Link to comment Share on other sites More sharing options...
artoor_k Posted July 11, 2019 Author Share Posted July 11, 2019 Hello, Very small progress... I've drilled a hole in sand filter (flap on front to be mounted later in open position) and in spinner. Oil coolers are also complete: I found that thick glass of gunsight bothers me. Aditionally, whole thing doesn't look like Veltro's gunsight. Another part to be scratchbuilt. Kit's gunsight: Real one: Gazzas, MikeMaben, Whitey and 5 others 8 Link to comment Share on other sites More sharing options...
Biggles87 Posted July 19, 2019 Share Posted July 19, 2019 Good progress so far. I have one of these so I will be watching closely and hoping to pick up some tips. John Link to comment Share on other sites More sharing options...
dennismcc Posted July 19, 2019 Share Posted July 19, 2019 Nice start, I built one those a few years ago, I enjoyed the build and was very pleased with the result, it needed some tweaks, I think the main ones were the wheels and the spinner, have fun Cheers Dennis Link to comment Share on other sites More sharing options...
artoor_k Posted July 21, 2019 Author Share Posted July 21, 2019 Hello, I've just get back home after visiting my friend and since I'm completely sober now I can continue with Veltro This is how gear weels look now: Also Icut out places for wingtip lights: Seversky, Gazzas, Whitey and 9 others 12 Link to comment Share on other sites More sharing options...
Greg W Posted July 21, 2019 Share Posted July 21, 2019 Great project, great job, following with interest! artoor_k 1 Link to comment Share on other sites More sharing options...
artoor_k Posted July 23, 2019 Author Share Posted July 23, 2019 On 7/22/2019 at 1:54 AM, GDW said: Great project, great job, following with interest! Thanks! Yesterday I've sealed screw holes. One thing I'd like to mention. Although wings are styrene, screw plugs are made of very hard rubber which doesn't cooperate well with Tamiya Extra Thin. So I had to seal them completely with Mr.Hobby Surfacer 500: I've scribed four inspection panels on wings , gun barrels were made of thin brass tubes: Because gear doors from set are very thick I made new ones from two pieces of thin styrene. Dremel was used to make wheel mounts more slim. Then tires were modified. Now they have vertical grooves as they are as correct as smooth tires (I'm working with help of Squadron Signal Walkaround no. 5558): LSP_Kevin, Biggles87, Gazzas and 7 others 10 Link to comment Share on other sites More sharing options...
artoor_k Posted July 25, 2019 Author Share Posted July 25, 2019 Nothing to show this time...because of screw plugs. I thought that putty and CA will seal them with wing. Well...not this time. After whole day of PSR I've decided to remove them and put putty alone instead. Rubber plugs were still visible even after sealing them with CA as a putty. So I have to wait till putty will cure comletely. Biggles87 and KUROK 1 1 Link to comment Share on other sites More sharing options...
kikka Posted July 25, 2019 Share Posted July 25, 2019 i have one kit as well and will replace the plugs with evergreen way easier and cheaper . artoor_k 1 Link to comment Share on other sites More sharing options...
artoor_k Posted July 27, 2019 Author Share Posted July 27, 2019 Despite wing problems it's time for some painting. Color is mix of grey and interior green: And first steps to make a italian seatbelts: Seversky, coogrfan, LSP_Kevin and 9 others 12 Link to comment Share on other sites More sharing options...
artoor_k Posted July 29, 2019 Author Share Posted July 29, 2019 Hello, On 7/26/2019 at 1:34 AM, kikka said: i have one kit as well and will replace the plugs with evergreen way easier and cheaper . That was good advice and pity that I've not used evergreen as soon as it was possible - now there was more work. But I'm learning on my mistakes and all rubber plugs were removed and replaced by evergreen pucks Cockpit was mounted in fuselage halves. Fit was quite good. In Veltro Walkaround I found photo of puppy on wing. This puppy was a pet of Veltro Squadron on Sicilia. Because I have Tamiya Livestock Set which includes adult and young dog so my mulling "What put on a vignette with Veltro" came to an end. But just puppy is not enough-too small to be noticed. Because my Veltro will be in RAAF markings so...well...somebody must have paint roundels and code, repaint spinner...I've decided to use another babe from Masterbox Pin Up series. I've put a brush to her hand and made a paint bucket for her Last things for today. New gear well covers - the ones from set were too thick and detail wasn't "sharp" - and weld marks on exhausts. Biggles87, LSP_Kevin, Sepp and 6 others 9 Link to comment Share on other sites More sharing options...
AceofClubs Posted July 30, 2019 Share Posted July 30, 2019 Very nice! I'll follow you with interest! Maybe I'm wrong but gunsight is a replica in 1/1 scale. Anyway it is very useful Ciao F Link to comment Share on other sites More sharing options...
artoor_k Posted July 30, 2019 Author Share Posted July 30, 2019 5 hours ago, AceofClubs said: Very nice! I'll follow you with interest! Maybe I'm wrong but gunsight is a replica in 1/1 scale. Anyway it is very useful Ciao F Well , in book is stated that is a photo of very rare original gunsight San Giorgio type C but who knows Link to comment Share on other sites More sharing options...
