3 hours ago, geedubelyer said:
is there any mileage in scratchbuilding the whole wing?
Hmmm - you want to add another year to this project?  :D  A very intriguing thought Guy.  The biggest problem would be to attain a good match with the center wing, both its trim or its contour.  Got any ideas?  The rest would be a job for Peter Castle!
Haha, yes. I just don't want this journey to end!:lol:
How do the kit wings look? Are they reasonably accurate in silhouette and cross section? If so, I'd use them as a template and employ techniques similar to how you and Peter have created wing forms before.
Formers + balsa or filler?
Skin with litho.
Roberts your Dad's brother and Fanny's your Mother's sister. ;)
For a man with your talent and joie de vivre, a week, tops......:innocent:
HTH^_^
Edited by geedubelyer
7 hours ago, JayW said:
The wing - I have done one thing only on wings so far, and that is to attempt to break one apart (a top half and a bottom half).  I failed.  Did that a few months ago.  It is glued together so firmly that I am afraid I will destroy it to get it apart.  So that is an issue.
Think about doing it destructively with minimum damage. If you haven't already, try using a jeweler's saw. The blades are available super thin so you won't have to worry about a large gap.
Just throwing this out for consideration.
Woody I have the Tamiya thin saw - is that about the same?
I'm doing a new rudder - I will post progress soon.  Meanwhile - you know squadron commander Tom Blackburn was responsible for the skull and crossbones emblem VF-17 was know by.  Not sure when it happened relative to adoption of the emblem, but VF-17 was also known as the "Jolly Rogers".  That name stuck, and Navy fighter squadrons have used it ever since.  Here is another in series of totally bad-to-the bone naval fighters that have sported the skull and crossbones, and the name Jolly Rogers:
   im04thewallpapersorgphoto18664military aircraft  33jpg
Enjoy.
3 hours ago, Maybach_man said:
Peter does some really fine thin photo etch saws
At this point, I am just beginning to formulate a wing plan.  The way I see it currently, and this might change, I am going to use the existing wings and not do alot of scratch building.  And importantly, I think I will not split them apart, which would mean I don't need the jewelers saw.  The more I research the wing drawings and inspect the wings I have, the more I like them.  The shape and planform appear to be pretty close, and the thickness is as well.  Also, panel lines are not far off.
Soon I will post a much more detailed plan for comments.  At this juncture though, I think it is going to involve a scratch built aileron and flap, dremmeling out the areas where fabric skin is present (I will use 0.005 inch thick plastic sheet like I did on the elevators), and add rib caps in those areas for the sheet to lie on top of, hopefully to give it a bit of drape.  The rest, I will skin in aluminum.  That will include the entire leading edge forward of the spar, the gun bays, and the inboard end at the wing-fold region.
We shall see.
Edited by JayW
Just a couple of shots of the new (and hopefully) improved rudder:
Note the thin plastic skin where the original one has doped tissue.
The major steps:
 1.  Basic skeleton (done)
2.  Basic skin (1 of two done)
3.  circle section leading edge - ribs and skin (in process)
4.  Balance weight tower skeleton  (in process)
5.  P-38 filler - balance weight tower
6.  Tab skeleton, skin, drive rod
A good scratch built rudder is a large project indeed.  I have checked and double checked everything I do, every measurement I make, trying to make sure it is perfect.  So far so good.....  Later.
Edited by JayW
