EricF Posted January 26, 2019 Author Share Posted January 26, 2019 Still working on the steps F`s are my favs, Starfighter and Marcel111 3 Link to comment Share on other sites More sharing options...
Durangokid Posted January 26, 2019 Share Posted January 26, 2019 You totally have me looking into buying this kit. I'm following this with interest for future reference. Bryan Link to comment Share on other sites More sharing options...
EricF Posted January 26, 2019 Author Share Posted January 26, 2019 Thanks Bryan The first vents Six to come ... step by step Starfighter, LSP_Kevin, Gazzas and 1 other 4 Link to comment Share on other sites More sharing options...
EricF Posted January 28, 2019 Author Share Posted January 28, 2019 Hi everyone ! Tonight the engine bay vents are finished. Next step, I will work on the cockpit. The air duct is ready for paint and the exhaust is in progress. Cheers Eric Marcel111, Starfighter, F`s are my favs and 4 others 7 Link to comment Share on other sites More sharing options...
crobinsonh Posted January 29, 2019 Share Posted January 29, 2019 Lovely detail work. Following closely as i have this in my stash Link to comment Share on other sites More sharing options...
Marcel111 Posted January 29, 2019 Share Posted January 29, 2019 Nice work on the vents, that makes a big difference! Link to comment Share on other sites More sharing options...
Barry Posted January 29, 2019 Share Posted January 29, 2019 Excellent work Eric! Barry Link to comment Share on other sites More sharing options...
EricF Posted January 30, 2019 Author Share Posted January 30, 2019 Hi Thanks Barry and Marcel111 It's time to work on the fore part: the cockpit area. I started with the canopy fairing which is suffering a little bit of the same issue as the 1/48 Hasegawa. This is how I solved the problem here below Both fuselages side by side to compare before and after modification Stay tuned Eric Pfuf, Starfighter, LSP_Kevin and 2 others 5 Link to comment Share on other sites More sharing options...
Squizzy 78 Posted January 30, 2019 Share Posted January 30, 2019 Very nice sharp fine work! Those vents are looking great. I can't wait to see more! Link to comment Share on other sites More sharing options...
EricF Posted February 2, 2019 Author Share Posted February 2, 2019 Hi, I started to work today on the rear part of the cockpit This is the area were we need to pay attention for preparing the adjustment of the Avionics part. If the tub is drop and fit, it is not the case here. Starfighter and Marcel111 2 Link to comment Share on other sites More sharing options...
EricF Posted February 2, 2019 Author Share Posted February 2, 2019 The first aircraft is done. Compare with the non reworked one timvkampen, TorbenD, stusbke and 5 others 8 Link to comment Share on other sites More sharing options...
EricF Posted February 3, 2019 Author Share Posted February 3, 2019 I focused my attention on the cockpit. I have both Avionics and Aires. After checking my doc, even if the Avionics looks good, I find it too wide in between the consoles. The Aires one has side consoles proportion closer the the real thing than the Avionics. And something leads me to find the solution. Take a look at the pic here below....... The Aires cockpit is too short ! Otherwise it is drop and fit in width and height after some sanding at the bottom. Anyway, it has not the LOX compartment that we find in the Avionics kit So the next step will to adapt it on the Aires kit. Cheers, Eric Starfighter and LSP_Kevin 2 Link to comment Share on other sites More sharing options...
EricF Posted February 4, 2019 Author Share Posted February 4, 2019 This is an hybrid between Avionics and Aires and it works good The gap on each side is normal, the side walls are not in place on the pic but it gives an idea of build inside the fuselage jgrease, Starfighter, blackbetty and 2 others 5 Link to comment Share on other sites More sharing options...
EricF Posted February 4, 2019 Author Share Posted February 4, 2019 To avoid troubles when attaching the cockpit tub, I took the option to attach the sidewalls on the fuselage first and not to the tub. I will fill the gaps with Evergreen to center the tub in the fuselage in the end. But first, do not forget the canopy locking system Marcel111, Starfighter, Hetstaine and 4 others 7 Link to comment Share on other sites More sharing options...
Starfighter Posted February 5, 2019 Share Posted February 5, 2019 Great job, very neat! And the best is, almost all of it will be visible at the end. Keep the pics coming! stusbke and EricF 2 Link to comment Share on other sites More sharing options...
