dodgem37 Posted May 16, 2019 Share Posted May 16, 2019 'The curve was created bending the mold, while the resin was still soft...' You bent the mold and not the casting? Very nice. Good show on the bottom cushion slipping in underneath the arm rests. I like the curve of the seat and back. Sincerely, Mark kkarlsen 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted May 16, 2019 Share Posted May 16, 2019 Brilliant work, Kent! Kev kkarlsen 1 Link to comment Share on other sites More sharing options...
kkarlsen Posted May 17, 2019 Author Share Posted May 17, 2019 (edited) 16 hours ago, dodgem37 said: 'The curve was created bending the mold, while the resin was still soft...' You bent the mold and not the casting? Very nice. Good show on the bottom cushion slipping in underneath the arm rests. I like the curve of the seat and back. Sincerely, Mark Eeehmm, I quess you could do both. This was a first for me. When I did the masters for the cushions, I hadn't noticed the curve. If bending the mold wouldn't have worked, I would probably have tried bending the casting, which would require a little timing... But hey, I didn't get resin on my fingers for this one!!! Cheers: Kent Edited May 17, 2019 by kkarlsen Link to comment Share on other sites More sharing options...
CZPetrP Posted May 17, 2019 Share Posted May 17, 2019 I am in awe. Excelent Job. Your buildings are inspiring. Thank you. Petr kkarlsen 1 Link to comment Share on other sites More sharing options...
kkarlsen Posted May 17, 2019 Author Share Posted May 17, 2019 3 hours ago, CZPetrP said: I am in awe. Excelent Job. Your buildings are inspiring. Thank you. Petr Thank you, appreciate it. This one is a tough one though Cheers: Kent Link to comment Share on other sites More sharing options...
Lothar Posted May 17, 2019 Share Posted May 17, 2019 19 minutes ago, kkarlsen said: Thank you, appreciate it. This one is a tough one though Cheers: Kent But you make look everything so easy..... your builds in general are stunning, hats off to your skills and knowledge Lothar Link to comment Share on other sites More sharing options...
richardchapman5 Posted May 17, 2019 Share Posted May 17, 2019 WOW what stunning craftsmanship. Loving this beautiful build. kkarlsen 1 Link to comment Share on other sites More sharing options...
kkarlsen Posted May 17, 2019 Author Share Posted May 17, 2019 5 hours ago, Lothar said: But you make look everything so easy..... your builds in general are stunning, hats off to your skills and knowledge Lothar , Thank you Lothar, well it isn't. With this build it's really uphill all the way, as there's absolutely nothing that just goes into place. Every part has to be modified/scratched to some degree. I'm actually looking forward to the rigging... Now the fitting of the parts into the converted cockpit, has developed into a bit of a nightmare. It's an endless series of trial and error to get everything fitted into place. There's really no extra room anywhere. I've deliberately postponed working on the piping for the fuel tanks, as there's almost no space for the fuel lines and pipes. But I'm sure they were there... somewhere. . Now the main parts for the cockpit have found their place, I think, the last parts to fabricate, are the rudder pedals... Then again, I have no idea, where to put the gauge panel for the fuel tanks, every little space is already occupied... Cheers: Kent Trak-Tor, BradG, scvrobeson and 7 others 10 Link to comment Share on other sites More sharing options...
kkarlsen Posted May 20, 2019 Author Share Posted May 20, 2019 Cockpit about done... The lower middle wings in place with the brass reinforcements... Cheers: Kent daveculp, Trak-Tor, Jan_G and 9 others 12 Link to comment Share on other sites More sharing options...
dodgem37 Posted May 20, 2019 Share Posted May 20, 2019 Kent, that is remarkable. Sincerely, Mark kkarlsen 1 Link to comment Share on other sites More sharing options...
Trak-Tor Posted May 20, 2019 Share Posted May 20, 2019 That looks about great. Juraj kkarlsen 1 Link to comment Share on other sites More sharing options...
Fvdm Posted May 20, 2019 Share Posted May 20, 2019 that is some real fine modelling. kkarlsen 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted May 21, 2019 Share Posted May 21, 2019 Wow terrific stuff Kent. kkarlsen 1 Link to comment Share on other sites More sharing options...
kkarlsen Posted May 21, 2019 Author Share Posted May 21, 2019 23 hours ago, dodgem37 said: Kent, that is remarkable. Sincerely, Mark 22 hours ago, Trak-Tor said: That looks about great. Juraj 15 hours ago, Fvdm said: that is some real fine modelling. 6 hours ago, Out2gtcha said: Wow terrific stuff Kent. Thank you Guy's appreciate the encouragement... Cheers: Kent Out2gtcha 1 Link to comment Share on other sites More sharing options...
CZPetrP Posted May 21, 2019 Share Posted May 21, 2019 Perfect ad precise work. You just need to fly kkarlsen 1 Link to comment Share on other sites More sharing options...
