RBrown Posted March 17, 2018 Share Posted March 17, 2018 (edited) In my opinion Hasegawa's interpretation of the lapped panels and mushroom rivets is on the fuselage is consistent with the real thing... Unlike the wings, which were flush riveted... Edited March 17, 2018 by RBrown Tolga ULGUR, BiggTim, coogrfan and 3 others 6 Link to comment Share on other sites More sharing options...
oyoy5 Posted March 17, 2018 Share Posted March 17, 2018 I agree 110% you are dead on and the Trumpeter kit is not nearly as good. I would take the Trumpeter cockpit and throw the rest of the kit in the garbage. Link to comment Share on other sites More sharing options...
MikeMaben Posted March 18, 2018 Share Posted March 18, 2018 Scott also built a beautiful Corsair out of the old Revell kit... does anybody know if Scott is around on site? Cheers Alan He pops up every now and then at different places. Haven't seen (virtually of course) him recently. Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted March 18, 2018 Author Share Posted March 18, 2018 In my opinion Hasegawa's interpretation of the lapped panels and mushroom rivets is on the fuselage is consistent with the real thing... Unlike the wings, which were flush riveted... Great pictures. Thanks for sharing them. Link to comment Share on other sites More sharing options...
thierry laurent Posted March 18, 2018 Share Posted March 18, 2018 I agree 110% you are dead on and the Trumpeter kit is not nearly as good. I would take the Trumpeter cockpit and throw the rest of the kit in the garbage. This would be a big mistake as the wings with the wheel wells and the engine are also FAR better! The only thing that is better in the Hasegawa kit is the fuselage. Not a minor point for sure but not sufficient either. LSP_K2 and Tolga ULGUR 2 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted March 18, 2018 Author Share Posted March 18, 2018 Kit arrived yesterday. I liked the fuselage details . Looks pretty goods despite its age. But I can not say same thing for the wings. Panel lines are too deep. It needs to be reduced I will post some pictures soon. Troy Molitor 1 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted March 18, 2018 Author Share Posted March 18, 2018 Here are the canals on the surface.. Does it need to be so deep?? Out2gtcha and LSP_K2 2 Link to comment Share on other sites More sharing options...
Out2gtcha Posted March 18, 2018 Share Posted March 18, 2018 Yeah, that is why most of us are planning on using the Trumpy wings if available. The grand Canyons in the Hasegawa wings are definitely fixable, but overall the Trumpeter wings have much better panel lines and detail to them. That being said, if you dont have access to the Trumpy kit which it doesnt sound like you have, fixing those panel lines should be no more work that some filler, masking tape, an Exacto blade (for cutting out the ejection chutes) and some elbow grease with some sanding material. Also, double check your Has wings for warping. I know mine are slightly warped right out of the box, and have had a few guys report the same thing with their Has kits. Just something to look out for that apparently the Has F6F wings may be a bit prone to. Troy Molitor and Tolga ULGUR 2 Link to comment Share on other sites More sharing options...
petrov27 Posted March 18, 2018 Share Posted March 18, 2018 I have a lot of love for the old Hase kit - built a couple over the years, I do think the fuselage is better than the Trumpeter kit in almost every way, but seemed like it would be a real pain to try to get the Hase fuse to mate with the Trump wing (which is IMHO quite nice and much better than the Hase, in particular with the wheel wells, control surfaces etc) here is my current build where I have "forced" the Trump fuselage to at least be shaped more correct (again just my opinion): http://forum.largescaleplanes.com/index.php?showtopic=72085&hl= BiggTim and Tolga ULGUR 2 Link to comment Share on other sites More sharing options...
BiggTim Posted March 18, 2018 Share Posted March 18, 2018 Here are the canals on the surface.. Does it need to be so deep?? No, they don't. I filled them all and re-scribed it. Tolga ULGUR 1 Link to comment Share on other sites More sharing options...
David Hansen Posted March 18, 2018 Share Posted March 18, 2018 Tolga, you're probably aware of this already, but there was a very good issue of the IPMS QUARTERLY dating back to 1975, which reviewed the Hasegawa F6F-3/5, along with the Otaki F6F-3, Monogram F6F-5 as well as the Matchbox and Airfix kits in 72nd. The major takeaways with respect to outline accuracy and shape were that the vertical fin/rudder was slightly too tall ( but correctable), and the drop tank was just a smidge too short at the trailing edge tip. I think the cutout for the tail wheel well at the back end needed to be lengthened or shortened but i cannot remember which. When i look at the kit parts, the profile of the "nose ring" on the front of the cowling seems to my eye to be a little too squared off and blocky, but again i think its correctable with some careful filing and sanding. The only other issue with the Hasegawa kit concerns the canopy. To me the windscreen proportions look a little off. Not the same order of magnitude the Trumpeter canopy is, but i feel like they made the sliding part a little too short in length and compensated by making the windscreen a little long at the base. Don't take my word for it; compare it to photos and draw your own conclusions. Bottom line: +1 for the Hasegawa F6F kit. -d- Tolga ULGUR 1 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted March 18, 2018 Author Share Posted March 18, 2018 Thank you for information and explanation. Very appreciated. It seems that I will continue with Hasegawa by working on the wings. Yeah, that is why most of us are planning on using the Trumpy wings if available. The grand Canyons in the Hasegawa wings are definitely fixable, but overall the Trumpeter wings have much better panel lines and detail to them. That being said, if you dont have access to the Trumpy kit which it doesnt sound like you have, fixing those panel lines should be no more work that some filler, masking tape, an Exacto blade (for cutting out the ejection chutes) and some elbow grease with some sanding material. Also, double check your Has wings for warping. I know mine are slightly warped right out of the box, and have had a few guys report the same thing with their Has kits. Just something to look out for that apparently the Has F6F wings may be a bit prone to. No, they don't. I filled them all and re-scribed it. Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted March 18, 2018 Author Share Posted March 18, 2018 Thanks David Tolga, you're probably aware of this already, but there was a very good issue of the IPMS QUARTERLY dating back to 1975, which reviewed the Hasegawa F6F-3/5, along with the Otaki F6F-3, Monogram F6F-5 as well as the Matchbox and Airfix kits in 72nd. The major takeaways with respect to outline accuracy and shape were that the vertical fin/rudder was slightly too tall ( but correctable), and the drop tank was just a smidge too short at the trailing edge tip. I think the cutout for the tail wheel well at the back end needed to be lengthened or shortened but i cannot remember which. When i look at the kit parts, the profile of the "nose ring" on the front of the cowling seems to my eye to be a little too squared off and blocky, but again i think its correctable with some careful filing and sanding. The only other issue with the Hasegawa kit concerns the canopy. To me the windscreen proportions look a little off. Not the same order of magnitude the Trumpeter canopy is, but i feel like they made the sliding part a little too short in length and compensated by making the windscreen a little long at the base. Don't take my word for it; compare it to photos and draw your own conclusions. Bottom line: +1 for the Hasegawa F6F kit. -d- Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted March 19, 2018 Author Share Posted March 19, 2018 I have just ordered CMK's cockpit set and Barracuda's wheels from Hannants. I will study the kit and start as soon as possible. But I have some ongoings projects to be completed. I will post pictures in WIP when I started the kit. Thanks again to all who share their knowledge, opinions and experiences. Very appreciated indeed. BiggTim and coogrfan 2 Link to comment Share on other sites More sharing options...
Bstarr3 Posted March 19, 2018 Share Posted March 19, 2018 Look forward to seeing your efforts. I love Hellcats! Tolga ULGUR 1 Link to comment Share on other sites More sharing options...
